Not able to Add JButton or JLabel to any container [message #33578] |
Wed, 28 April 2004 16:47  |
I am not able to add JBurron or JLabel to any of the swing containers. The
log file contains the following stack. Any idea how get this working?
org.eclipse.ve.internal.jfc.core.ContainerProxyAdapter.addCo mponentWithConstraint(ContainerProxyAdapter.java:210)
org.eclipse.ve.internal.jfc.core.ContainerProxyAdapter.addCo mponent(ContainerProxyAdapter.java:178)
org.eclipse.ve.internal.jfc.core.ContainerProxyAdapter.appli ed(ContainerProxyAdapter.java:53)
org.eclipse.ve.internal.java.core.BeanProxyAdapter.notifyCha nged(BeanProxyAdapter.java:120)
org.eclipse.emf.common.notify.impl.NotifierImpl.eNotify(Noti fierImpl.java:243)
org.eclipse.emf.ecore.util.EcoreEList.dispatchNotification(E coreEList.java:216)
org.eclipse.emf.common.notify.impl.NotifyingListImpl.addAllU nique(NotifyingListImpl.java:337)
at org.eclipse.emf.common.util.BasicEList.addAll(BasicEList.jav a:729)
org.eclipse.ve.internal.cde.commands.ApplyAttributeSettingCo mmand.execute(ApplyAttributeSettingCommand.java:94)
org.eclipse.ve.internal.propertysheet.common.commands.Compou ndCommand.execute(CompoundCommand.java:217)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorCommandStack$1.run(JavaVisualEditorCommandStack.java:49)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$JavaModelChangeController.run(JavaVisualEditorPart. java:1029)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorCommandStack.execute(JavaVisualEditorCommandStack.java:4 6)
org.eclipse.gef.tools.AbstractTool.executeCurrentCommand(Abs tractTool.java:416)
org.eclipse.gef.tools.CreationTool.performCreation(CreationT ool.java:198)
org.eclipse.gef.tools.CreationTool.handleButtonUp(CreationTo ol.java:122)
at org.eclipse.gef.tools.AbstractTool.mouseUp(AbstractTool.java :1006)
at org.eclipse.gef.EditDomain.mouseUp(EditDomain.java:232)
org.eclipse.gef.ui.parts.DomainEventDispatcher.dispatchMouse Released(DomainEventDispatcher.java:346)
org.eclipse.draw2d.LightweightSystem$EventHandler.mouseUp(Li ghtweightSystem.java:511)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:132)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :81)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:840)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2022)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1729)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1402)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1385)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:858)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
Re: Not able to Add JButton or JLabel to any container [message #34113 is a reply to message #34080] |
Fri, 30 April 2004 11:07  |
Originally posted by: richkulp.NO.SPAM.us.ibm.com
Now the problem is I don't see how this is possible.:-(
Try appending the .log as an attachment and I'll see if there is
anything else of interest because so far I can't figure it out.
Rich Kulp wrote:
> Thanks! It is very possible that this NPE could cause the NPE to occur.
> Now the question is why did this NPE occur?
>> java.lang.NullPointerException
>> at
>> org.eclipse.emf.ecore.impl.EStructuralFeatureImpl.getSetting Delegate(EStructuralFeatureImpl.java:840)
>> at
>> org.eclipse.emf.ecore.impl.EObjectImpl.eSettingDelegate(EObj ectImpl.java:671)
>> at
>> org.eclipse.emf.ecore.impl.EObjectImpl.eDynamicIsSet(EObject Impl.java:485)
>> at
>> org.eclipse.emf.ecore.impl.EObjectImpl.eIsSet(EObjectImpl.ja va:472)
>> at
Thanks, Rich Kulp
Re: Not able to Add JButton or JLabel to any container [message #587529 is a reply to message #33646] |
Thu, 29 April 2004 14:14  |
Here is the versions I am running.
org.eclipse.ve (0.5.0) "org.eclipse.ve"
org.eclipse.emf (1.1.1) "org.eclipse.emf"
org.eclipse.gef (2.1.2) "org.eclipse.gef"
org.eclipse.platform (2.1.2) "org.eclipse.platform"
java.runtime.version=1.4.2_04-b05
I have checked the version requirements and this seems to be right.
Vinodh R.
Rich Kulp wrote:
> What version of VE, EMF, GEF, Eclipse, and java do you have?
Re: Not able to Add JButton or JLabel to any container [message #587538 is a reply to message #33885] |
Thu, 29 April 2004 14:32  |
I don't know. That shouldn't of happened. Looking at the code I don't
see how the variable could of been null at that point in the code.
Is this consistent?
Does this occur by just subclassing JPanel, and with no further changes,
you can't drop a JButton or a JLabel?
But you can drop other kind of Swing components?
Is the container you trying to drop on more complicated than just an
empty JPanel?
Thanks, Rich Kulp
Re: Not able to Add JButton or JLabel to any container [message #587545 is a reply to message #33999] |
Thu, 29 April 2004 17:10  |
The container is just a plain JPanel.
I initially had a class which subclassed JInternalFrame. But then I tried
this on a plain JPanel after that. Here is a list of components I could
not add.
JButton
JCheckBox
JRadioButton
JToggleButton (If it had stopped here I would have thought that the
problem had something to do with AbstractButton)
JLabel
JTable on JScrollPane
JScrollPane
Everything else seems to work. And If I add a any of this myself and try
to open the class in Visual editor, it fails with a dialog saying there
was a null pointer exception.
I also tried it with JRE 1.3.1 with the same results.
Vinodh R.
> Is this consistent?
> empty JPanel?
Re: Not able to Add JButton or JLabel to any container [message #587559 is a reply to message #34008] |
Thu, 29 April 2004 18:29  |
I don't know. There is something unusual about your setup. We've never
ran into something like this. And we can't reproduce it. It just
shouldn't be happening. I know of no way to get into that condition.
Thanks, Rich Kulp
Re: Not able to Add JButton or JLabel to any container [message #587568 is a reply to message #34022] |
Thu, 29 April 2004 18:28  |
I also found this Stack trace. See if this helps. If not I guess I will
wait till I upgrade to 3.0 for trying out VE 1.0
Thanks.
Vinodh R.
at org.eclipse.emf.ecore.impl.EObjectImpl.eIsSet(EObjectImpl.ja va:472)
org.eclipse.ve.internal.java.vce.rules.VCEPreSetCommand.hand leValue(VCEPreSetCommand.java:267)
org.eclipse.ve.internal.java.vce.rules.VCEPreSetCommand.hand leValue(VCEPreSetCommand.java:292)
org.eclipse.ve.internal.java.vce.rules.VCEPreSetCommand.exec ute(VCEPreSetCommand.java:121)
Re: Not able to Add JButton or JLabel to any container [message #587575 is a reply to message #34047] |
Thu, 29 April 2004 18:41  |
> at
> at
> at
> at
Thanks, Rich Kulp
Re: Not able to Add JButton or JLabel to any container [message #587587 is a reply to message #34080] |
>> at
>> at
>> at
>> at
>> at
Thanks, Rich Kulp
FUDForum. Page generated in 0.05934 seconds
