Home » Archived » Visual Editor (VE) » Not able to Add JButton or JLabel to any container
Not able to Add JButton or JLabel to any container [message #33578] Wed, 28 April 2004 16:47 Go to next message
I am not able to add JBurron or JLabel to any of the swing containers. The
log file contains the following stack. Any idea how get this working?
org.eclipse.ve.internal.jfc.core.ContainerProxyAdapter.addCo mponentWithConstraint(ContainerProxyAdapter.java:210)
org.eclipse.ve.internal.jfc.core.ContainerProxyAdapter.addCo mponent(ContainerProxyAdapter.java:178)
org.eclipse.ve.internal.jfc.core.ContainerProxyAdapter.appli ed(ContainerProxyAdapter.java:53)
org.eclipse.ve.internal.java.core.BeanProxyAdapter.notifyCha nged(BeanProxyAdapter.java:120)
org.eclipse.emf.common.notify.impl.NotifierImpl.eNotify(Noti fierImpl.java:243)
org.eclipse.emf.ecore.util.EcoreEList.dispatchNotification(E coreEList.java:216)
org.eclipse.emf.common.notify.impl.NotifyingListImpl.addAllU nique(NotifyingListImpl.java:337)
at org.eclipse.emf.common.util.BasicEList.addAll(BasicEList.jav a:729)
org.eclipse.ve.internal.cde.commands.ApplyAttributeSettingCo mmand.execute(ApplyAttributeSettingCommand.java:94)
org.eclipse.ve.internal.propertysheet.common.commands.Compou ndCommand.execute(CompoundCommand.java:217)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorCommandStack$1.run(JavaVisualEditorCommandStack.java:49)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$JavaModelChangeController.run(JavaVisualEditorPart. java:1029)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorCommandStack.execute(JavaVisualEditorCommandStack.java:4 6)
org.eclipse.gef.tools.AbstractTool.executeCurrentCommand(Abs tractTool.java:416)
org.eclipse.gef.tools.CreationTool.performCreation(CreationT ool.java:198)
org.eclipse.gef.tools.CreationTool.handleButtonUp(CreationTo ol.java:122)
at org.eclipse.gef.tools.AbstractTool.mouseUp(AbstractTool.java :1006)
at org.eclipse.gef.EditDomain.mouseUp(EditDomain.java:232)
org.eclipse.gef.ui.parts.DomainEventDispatcher.dispatchMouse Released(DomainEventDispatcher.java:346)
org.eclipse.draw2d.LightweightSystem$EventHandler.mouseUp(Li ghtweightSystem.java:511)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:132)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :81)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:840)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2022)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1729)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1402)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1385)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:858)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
Re: Not able to Add JButton or JLabel to any container [message #33646 is a reply to message #33578] Wed, 28 April 2004 17:44 Go to previous messageGo to next message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
What version of VE, EMF, GEF, Eclipse, and java do you have?
Thanks, Rich Kulp
Re: Not able to Add JButton or JLabel to any container [message #33885 is a reply to message #33646] Thu, 29 April 2004 14:14 Go to previous messageGo to next message
Here is the versions I am running.
org.eclipse.ve (0.5.0) "org.eclipse.ve"
org.eclipse.emf (1.1.1) "org.eclipse.emf"
org.eclipse.gef (2.1.2) "org.eclipse.gef"
org.eclipse.platform (2.1.2) "org.eclipse.platform"
java.runtime.version=1.4.2_04-b05
I have checked the version requirements and this seems to be right.
Vinodh R.
Re: Not able to Add JButton or JLabel to any container [message #33999 is a reply to message #33885] Thu, 29 April 2004 14:32 Go to previous messageGo to next message
I don't know. That shouldn't of happened. Looking at the code I don't
see how the variable could of been null at that point in the code.
Is this consistent?
Does this occur by just subclassing JPanel, and with no further changes,
you can't drop a JButton or a JLabel?
But you can drop other kind of Swing components?
Is the container you trying to drop on more complicated than just an
empty JPanel?
Thanks, Rich Kulp
Re: Not able to Add JButton or JLabel to any container [message #34008 is a reply to message #33999] Thu, 29 April 2004 17:10 Go to previous messageGo to next message
The container is just a plain JPanel.
I initially had a class which subclassed JInternalFrame. But then I tried
this on a plain JPanel after that. Here is a list of components I could
not add.
JButton
JCheckBox
JRadioButton
JToggleButton (If it had stopped here I would have thought that the
problem had something to do with AbstractButton)
JLabel
JTable on JScrollPane
JScrollPane
Everything else seems to work. And If I add a any of this myself and try
to open the class in Visual editor, it fails with a dialog saying there
was a null pointer exception.
I also tried it with JRE 1.3.1 with the same results.
Vinodh R.
> Is this consistent?
> empty JPanel?
Re: Not able to Add JButton or JLabel to any container [message #34022 is a reply to message #34008] Thu, 29 April 2004 18:29 Go to previous messageGo to next message
I don't know. There is something unusual about your setup. We've never
ran into something like this. And we can't reproduce it. It just
shouldn't be happening. I know of no way to get into that condition.
Thanks, Rich Kulp
Re: Not able to Add JButton or JLabel to any container [message #34047 is a reply to message #34022] Thu, 29 April 2004 18:28 Go to previous messageGo to next message
I also found this Stack trace. See if this helps. If not I guess I will
wait till I upgrade to 3.0 for trying out VE 1.0
Thanks.
Vinodh R.
org.eclipse.emf.ecore.impl.EStructuralFeatureImpl.getSetting Delegate(EStructuralFeatureImpl.java:840)
org.eclipse.emf.ecore.impl.EObjectImpl.eSettingDelegate(EObj ectImpl.java:671)
org.eclipse.emf.ecore.impl.EObjectImpl.eDynamicIsSet(EObject Impl.java:485)
at org.eclipse.emf.ecore.impl.EObjectImpl.eIsSet(EObjectImpl.ja va:472)
org.eclipse.ve.internal.java.vce.rules.VCEPreSetCommand.hand leValue(VCEPreSetCommand.java:267)
org.eclipse.ve.internal.java.vce.rules.VCEPreSetCommand.hand leValue(VCEPreSetCommand.java:292)
org.eclipse.ve.internal.java.vce.rules.VCEPreSetCommand.exec ute(VCEPreSetCommand.java:121)
Re: Not able to Add JButton or JLabel to any container [message #34080 is a reply to message #34047] Thu, 29 April 2004 18:41 Go to previous messageGo to next message
Thanks! It is very possible that this NPE could cause the NPE to occur.
Now the question is why did this NPE occur?
> java.lang.NullPointerException
> at
> at
> at
> at
Thanks, Rich Kulp
Re: Not able to Add JButton or JLabel to any container [message #34113 is a reply to message #34080] Fri, 30 April 2004 11:07 Go to previous message
Now the problem is I don't see how this is possible.:-(
Try appending the .log as an attachment and I'll see if there is
anything else of interest because so far I can't figure it out.
>> at
>> at
>> at
>> at
>> at
Thanks, Rich Kulp
Re: Not able to Add JButton or JLabel to any container [message #587425 is a reply to message #33578] Wed, 28 April 2004 17:44 Go to previous message
Thanks, Rich Kulp
Re: Not able to Add JButton or JLabel to any container [message #587529 is a reply to message #33646] Thu, 29 April 2004 14:14 Go to previous message
Vinodh R.
Re: Not able to Add JButton or JLabel to any container [message #587538 is a reply to message #33885] Thu, 29 April 2004 14:32 Go to previous message
Is this consistent?
empty JPanel?
Thanks, Rich Kulp
Re: Not able to Add JButton or JLabel to any container [message #587545 is a reply to message #33999] Thu, 29 April 2004 17:10 Go to previous message
not add.
JButton
JCheckBox
JRadioButton
JLabel
JScrollPane
Vinodh R.
> Is this consistent?
> empty JPanel?
Re: Not able to Add JButton or JLabel to any container [message #587559 is a reply to message #34008] Thu, 29 April 2004 18:29 Go to previous message
Thanks, Rich Kulp
Re: Not able to Add JButton or JLabel to any container [message #587568 is a reply to message #34022] Thu, 29 April 2004 18:28 Go to previous message
Thanks.
Vinodh R.
Re: Not able to Add JButton or JLabel to any container [message #587575 is a reply to message #34047] Thu, 29 April 2004 18:41 Go to previous message
> at
> at
> at
> at
Thanks, Rich Kulp
Re: Not able to Add JButton or JLabel to any container [message #587587 is a reply to message #34080] Fri, 30 April 2004 11:07 Go to previous message
>> at
>> at
>> at
>> at
>> at
Thanks, Rich Kulp
Previous Topic:New Problem with VE Stable Build: M1RC1
Next Topic:VE M1 RC1 out and posted
Current Time: Tue Jul 08 18:46:02 EDT 2025
Powered by FUDForum. Page generated in 0.09942 seconds
