Home » Eclipse Projects » Eclipse Platform » uitest throws ClassCastException
uitest throws ClassCastException [message #331343] Tue, 02 September 2008 12:13 Go to next message
Hello all,
I've created a TestSuite to be run by uitest in the Eclipse Test
Framework. The TestSuite is simply a collection of my plugin tests. When I
run the tests, I receive the following (abbreviated) stack trace:
<error message="junit.framework.TestSuite cannot be cast to
junit.framework.Test" type="java.lang.ClassCastException"> at
org.eclipse.test.EclipseTestRunner.getTest(EclipseTestRunner .java:265)
org.eclipse.test.EclipseTestRunner.&lt;init&gt;(Ecli pseTestRunner.java:220)
org.eclipse.test.EclipseTestRunner.run(EclipseTestRunner.jav a:204)
org.eclipse.test.UITestApplication$3.run(UITestApplication.j ava:195)
This is very confusing to me junit.framework.TestSuite implments
junit.framework.Test.
There is nothing special about my TestSuite. I simply instantiate it and
then suite.addTest( TestCase ) for several different junit tests. Finally,
my suite() method returns the suite as a Test.
My invocation of uitest is similarly plain vanilla:
<ant target="ui-test" antfile="${library-file}" dir="${eclipse-home}">
<property name="os" value="linux"/>
<property name="ws" value="gtk"/>
<property name="arch" value="${basearch}"/>
<property name="data-dir" value="${eclipse-home}/junit-workspace
-clean" />
<property name="plugin-name" value="com.amd.ngeda.core.test" />
<property name="classname" value="com.amd.ngeda.AllTests" />
<property name="extraVMargs"
value="-Demma.coverage.out.file=${coverageDirectory}/coverage.emma
-Djava.ext.dirs=${ext.dir} -Dosgi.parentClassloader=ext" />
</ant>
I saw this identical question posted to the newsgroup in June
( http://dev.eclipse.org/newslists/news.eclipse.platform/msg76 042.html) so
apparently others have experienced this problem, but unfortunately there
was no response.
Thanks in advance,
Frank
Re: uitest throws ClassCastException [message #331405 is a reply to message #331343] Thu, 04 September 2008 16:26 Go to previous message
FWIW, I found the cause of this problem, just in case anyone else runs
into it. My plugin has a dependency on JUnit4 and so JUnit4 was attempting
to run (and cast) this suite. Presumably the problem arose since JUnit4
uses annotations. The same suite had no problems when run under JUnit3.
Frank
Previous Topic:Menu extensions
Next Topic:How to use EditionSelectionDialog
Current Time: Tue Jul 22 09:09:42 EDT 2025
Powered by FUDForum. Page generated in 0.03711 seconds
