Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » WorkspaceCommandStackImpl should probably override isSaveNeeded and saveIsDone of BasicCommandStack
WorkspaceCommandStackImpl should probably override isSaveNeeded and saveIsDone of BasicCommandStack [message #33567] Mon, 08 May 2006 07:58 Go to next message
Hallo,
as I was currently not able to connect to the Eclipse bugs portal (reason is
too many connections), I think I could post my bug-report/change-request in
this newsgroup:
I am working with the WorkspaceCommandStackImpl of the
org.eclipse.emf.workspace project. I noticed that it subclasses
org.eclipse.emf.common.command.BasicCommandStack but does not make any use
the of the super implementations of execute, undo and redo.
BasicCommandStack offers some methods to set resp. retrieve the dirty state
of the command stack, namely isSaveNeeded and saveIsDone. The implementation
of these methods is based on correct calls to execute, redo and undo methods
(in BasicCommandStack). As WorkspaceCommandStackImpl does not call the super
implementations, isSaveNeeded and saveIsDone do no longer work when being
called.
I would propose to either reimplement these methods in
WorkspaceCommandStackImpl to give them correct behaviour or at least
override them and raise an UnsupportedOperationException inside, so a caller
of this method gets notified about the missing behaviour.
Alexander Ny
Re: WorkspaceCommandStackImpl should probably override isSaveNeeded and saveIsDone of BasicCommandSt [message #33601 is a reply to message #33567] Mon, 08 May 2006 08:49 Go to previous messageGo to next message
Alexander,
Please open a bugzilla when bugzilla is back on line.
Alexander Nyßen wrote:
>Hallo,
>this newsgroup:
>called.
>Regards
>Alexander Nyßen
Re: WorkspaceCommandStackImpl should probably override isSaveNeeded and saveIsDone of BasicCommandSt [message #33635 is a reply to message #33601] Mon, 08 May 2006 09:16 Go to previous message
Ok, did it. Newly created bug is #140552.
Alexander Ny
Re: WorkspaceCommandStackImpl should probably override isSaveNeeded and saveIsDone of BasicCommandSt [message #577102 is a reply to message #33567] Mon, 08 May 2006 08:49 Go to previous message
Alexander,
>Hallo,
>this newsgroup:
>called.
>Regards
>Alexander Nyßen
Re: WorkspaceCommandStackImpl should probably override isSaveNeeded and saveIsDone of BasicCommandSt [message #577122 is a reply to message #33601] Mon, 08 May 2006 09:16 Go to previous message
Alexander Ny
Previous Topic:WorkspaceCommandStackImpl should probably override isSaveNeeded and saveIsDone of BasicCommandStack
Next Topic:Validation & OCL
Current Time: Fri Jul 18 04:47:13 EDT 2025
Powered by FUDForum. Page generated in 0.10382 seconds
