Home » Eclipse Projects » Eclipse Platform » Eclipse 3.4 on Windows XP Pro 64-bit
Eclipse 3.4 on Windows XP Pro 64-bit [message #331301] Fri, 29 August 2008 07:20
I want to run "Eclipse 3.4 64 bit" using "jvm 64 bit" on Windoes XP Pro
64-bit. I installed jdk1.6 update7 for windows 64 (jdk-6u7-windows-x64.exe).
I do not have any 32 bit jdk or jre in my computer.
I cannot find the Windows 64bit package on http://www.eclipse.org/downloads
(why?) so I download the drops from
http://download.eclipse.org/eclipse/downloads/drops/R-3.4-20 0806172000/index.php.
I extracted manually them into a folder (e:\eclipse) and run eclipse.exe.
Splash screen pops up then it disappears and a popup appears and says:
Eclipse
An error has occurred. See the log file
E:\eclipse\configuration\1220007627386.log.
OK
And the log is the following:
!SESSION 2008-08-29
14:00:27.183 -----------------------------------------------
eclipse.buildId=@build@
java.version=1.6.0_07
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=tr_TR
Command-line arguments: -os win32 -ws win32 -arch x86_64
!ENTRY org.eclipse.osgi 4 0 2008-08-29 14:00:27.558
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service.
Ensure that the org.eclipse.core.runtime bundle is resolved and started (see
config.ini).
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:74)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
What is the solution?
Kerem
Previous Topic:Making IEditorPart Read Only
Next Topic:Null pointer on workbench close
Current Time: Tue Sep 16 15:17:41 EDT 2025
Powered by FUDForum. Page generated in 0.02967 seconds
