Home » Eclipse Projects » Eclipse Platform » Marker attributes representing complex objects
Marker attributes representing complex objects [message #331157] Tue, 26 August 2008 18:56 Go to next message
Originally posted by: rob.brainkandy-dot-org.org
I would like to store objects in markers. These are objects with complicated
heirarchy. They're not terribly big, but big enough that manually serializing
their data and storing them as String objects in the marker means contending
with creating my own pipe-separated protocol.
I'm not in love with this solution. Some other solutions I can think of are:
1. Make the objects serializable, and then store the uuencoded version of that
data as a String.
2. Split the data among several attributes.
3. Some other solution that other people have considered.
What do you think?
Re: Marker attributes representing complex objects [message #331162 is a reply to message #331157] Wed, 27 August 2008 05:23 Go to previous messageGo to next message
Originally posted by: mario.winterer.gmx.net
Hi Robert!
I don't think, resource markers are the right place to store large
amount of data. The concrete usecase behind this requirement would be
interesting...
Maybe you could just store some kind of identifier in the marker and
have the objects itself in a separate data storage (e.g. a file in the
plugin's storage location). A central service could map the identifier
to the object graph and handle loading and saving of those objects.
Use a resource change listener to synchronize the data storage with the
workspace (i.e. delete objects in the storage if the corresponding
resource has been removed or the corresponding id-marker has been
deleted etc.).
Mario
> complicated heirarchy. They're not terribly big, but big enough that
> manually serializing their data and storing them as String objects in
> the marker means contending with creating my own pipe-separated protocol.
> are:
> of that data as a String.
> What do you think?
Re: Marker attributes representing complex objects [message #331199 is a reply to message #331162] Wed, 27 August 2008 22:06 Go to previous message
Thanks for the reply, Mario.
The solution we went for was to serialize the object, get the object bytes and
store it as a UTF-8 string.
Does anyone see any real issues with this?
Mario Winterer wrote:
> Hi Robert!
> interesting...
> deleted etc.).
That's reall overkill. The data isn't _that_ large, it's just non-trivial.
> Mario
>> of are:
>> What do you think?
Previous Topic:Support for labelAttribute metadata
Next Topic:How can I use inplace editing on singleclick and open a dialog on doubleclick ?
Current Time: Thu Jul 24 04:55:34 EDT 2025
Powered by FUDForum. Page generated in 0.30153 seconds
