Home » Eclipse Projects » Eclipse Platform » Buttons
Buttons [message #331128] Tue, 26 August 2008 09:41 Go to next message
Originally posted by: mike.moor.gmx.ch
Is there a way to create a button without a border and no margin space
around the image so as to blend the button with its background?
cheers
mike
Re: Buttons [message #331130 is a reply to message #331128] Tue, 26 August 2008 09:52 Go to previous messageGo to next message
Is there a particular reason you would not just use a Label instead? I'm
pretty sure you can add a MouseListener to the Label to behave the same
as a SelectionListener would on a Button.
Eric
Re: Buttons [message #331131 is a reply to message #331130] Tue, 26 August 2008 09:52 Go to previous messageGo to next message
yes, i could use a label. the only thing i miss is the "push"-effect...
Re: Buttons [message #331132 is a reply to message #331130] Tue, 26 August 2008 09:54 Go to previous message
yes, i could. the only thing i miss is the "3d-push"-effect
Previous Topic:Changing button state
Next Topic:Re: JFace Dialog minimization and maximization buttons
Current Time: Fri Nov 21 18:29:35 EST 2025
Powered by FUDForum. Page generated in 0.25595 seconds
