Home » Eclipse Projects » Eclipse Platform » Question on EFS (Eclipse File System) - EFS support on workspace projects
Question on EFS (Eclipse File System) - EFS support on workspace projects [message #331125] Tue, 26 August 2008 08:23 Go to next message
Originally posted by: prashanto.chatterjee.gmail.com
Can EFS be used on projects that reside in the eclipse workspace but needs
to show a different directory structure?
Workspace:
- project A
- folder Aa
- file.abc
- folder Ab
- file.abc
Custom Navigator:
- project A
- type 1
- component1 type1
- component2 type1
- type 2
- component1 type2
- component2 type3
- type 3
- component1 type3
- component2 type3
The custom navigator parses all the files with extension '.abc' and creates
components under respective types which is visible in the navigator. I would
like to have marker support on these components.
Kindly refer to the post titled 'Resource Marker to open custom editor with
custom EditorInput' dated Friday, August 22, 2008 for an overview of my
requirement.
Prashanto
Re: Question on EFS (Eclipse File System) - EFS support on workspace projects [message #331138 is a reply to message #331125] Tue, 26 August 2008 10:40 Go to previous messageGo to next message
I don't know that much about the Marker support, so I can't help you
with your requirements there. But I think your use of the CNF to do
this is the right way. If you are using EFS you are creating an
entirely separate world when all you really want is your view to be
layed out differently. I would strongly recommend against the EFS approach.
Prashanto Chatterjee wrote:
> Workspace:
> - project A
> - folder Aa
> - file.abc
> - folder Ab
> - file.abc
> Custom Navigator:
> - project A
> - type 1
> - component1 type1
> - component2 type1
> - type 2
> - component1 type2
> - component2 type3
> - type 3
> - component1 type3
> - component2 type3
> requirement.
> Prashanto
*new* Common Navigator Framework section in:
3.4RC4 Platform Plugin Developer Guide (Programmer's Guide)
http://help.eclipse.org/ganymede/topic/org.eclipse.platform. doc.isv/guide/cnf.htm
http://dev.eclipse.org/blogs/francis
http://wiki.eclipse.org/Common_Navigator_Framework
http://wiki.eclipse.org/Common_Navigator_Framework_Use_Cases
You have brains in your head.
You have feet in your shoes.
- Dr Seuss, Oh the Places You'll Go
Re: Question on EFS (Eclipse File System) - EFS support on workspace projects [message #331166 is a reply to message #331138] Wed, 27 August 2008 09:37 Go to previous message
Thank you so much for replying. I fully agree with your suggestion. As a
matter of fact, I had stopped exploring EFS after an hour's effort because
it just did not feel right for my requirement.
Thanks again for showing me the correct way.
Good Day,
Prashanto
"Francis Upton (News)" <francisu@ieee.org> wrote in message
news:48B415F3.3010905@ieee.org...
>I don't know that much about the Marker support, so I can't help you with
>your requirements there. But I think your use of the CNF to do this is the
>right way. If you are using EFS you are creating an entirely separate
>world when all you really want is your view to be layed out differently. I
>> needs to show a different directory structure?
>> Workspace:
>> - project A
>> - folder Aa
>> - file.abc
>> - folder Ab
>> - file.abc
>> Custom Navigator:
>> - project A
>> - type 1
>> - component1 type1
>> - component2 type1
>> - type 2
>> - component1 type2
>> - component2 type3
>> - type 3
>> - component1 type3
>> - component2 type3
>> creates components under respective types which is visible in the
>> navigator. I would like to have marker support on these components.
>> with custom EditorInput' dated Friday, August 22, 2008 for an overview of
>> my requirement.
>> Regards,
>> Prashanto
Previous Topic:Resource Marker to open custom editor with custom EditorInput
Next Topic:Eclipse 3.4 - 64 bit UI tests
Current Time: Tue Oct 14 21:57:33 EDT 2025
Powered by FUDForum. Page generated in 0.03791 seconds
