Home » Eclipse Projects » Eclipse Platform » Value returned by IConfigurationElement.getAttribute() was not translated
Value returned by IConfigurationElement.getAttribute() was not translated [message #331072] Fri, 22 August 2008 23:13 Go to next message
Hi!
I'm using Eclipse 3.4. I have a plugin, it defines an extension, as below:
<extension
id=" net.yau.test.extensionreg.cosumer.net.yau.test.extensionreg. consumerID "
point="net.yau.test.extensionreg">
<net.yau.test.extensionreg.test
class="net.yau.test.extensionreg.cosumer.TestObjImpl"
name="%consumerName">
<description>
The description
</description>
</net.yau.test.extensionreg.test>
</extension>
The attribute in the "name" attribute of the element
"net.yau.test.extensionreg.test" are translated in plugin.properties.
IDE also displays the correct translation in plugin.xml editor(in the
Extensions page). So I think the translation in plugin.properties is OK.
But in the application, when I do:
IExtension[] exArr = ep.getExtensions();
if (exArr.length > 0) {
IExtension ex = exArr[0];
IConfigurationElement[] elmts = ex.getConfigurationElements();
if (elmts.length > 0) {
IConfigurationElement elmt = elmts[0];
return elmt.getAttribute("name");
The return value is "%consumerName", not the value translated by
plugin.properties.(Plugin developer guide said: Note that any translation
specified in the plug-in manifest file is automatically applied. ).
The fragment of my MANIFEST.MF of the extension point definition bundle:
Require-Bundle: org.eclipse.ui,
org.eclipse.core.runtime,
org.eclipse.update.configurator;bundle-version="3.2.200"
The fragment of my MANIFEST.MF of the extension definition bundle:
net.yau.test.extensionreg.master;bundle-version="1.0.0"
Is the problem due to missing some bundle?
Yau
Re: Value returned by IConfigurationElement.getAttribute() was not translated [message #331075 is a reply to message #331072] Sat, 23 August 2008 02:40 Go to previous messageGo to next message
In the Schema of net.yau.test.extensionreg.test, the translatable should
be set to true for the name atribute
- Prakash
www.eclipse-tips.com
yau wrote:
> Hi!
> <extension
> <description>
> The description
> </description>
> </extension>
> Yau
Re: Value returned by IConfigurationElement.getAttribute() was not translated [message #331076 is a reply to message #331075] Sat, 23 August 2008 02:47 Go to previous messageGo to next message
I already do this:
<attribute name="name" type="string">
<annotation>
<documentation>
</documentation>
<appinfo>
<meta.attribute translatable="true"/>
</appinfo>
</annotation>
</attribute>
"Prakash G.R." <grprakash@gmail.com>
??????:g8obc9$has$1@build.eclipse.org...
> - Prakash
> yau wrote:
>> Hi!
>> below:
>> <extension
>> <description>
>> The description
>> </description>
>> </extension>
>> Yau
Re: Value returned by IConfigurationElement.getAttribute() was not translated [message #331397 is a reply to message #331076] Thu, 04 September 2008 13:57 Go to previous messageGo to next message
Yau, any luck figuring this out? I just ran into this behavior myself,
also marking the field in question as translatable--doesn't translate
though. Also 3.4.
Re: Value returned by IConfigurationElement.getAttribute() was not translated [message #331400 is a reply to message #331397] Thu, 04 September 2008 14:19 Go to previous message
I think I just figured this out. I was missing a line in my Manifest.mf
file. I added "Bundle-Localization: plugin" add now it's retrieving the
values fine.
Previous Topic:[Databinding] Example Application showing Databinding, EMF, Teneo and CDO in action
Next Topic:Menu extensions
Current Time: Sat Jul 26 13:16:40 EDT 2025
Powered by FUDForum. Page generated in 0.25548 seconds
