Home » Eclipse Projects » Eclipse Platform » Undoable Operation Not Working
Undoable Operation Not Working [message #331068] Fri, 22 August 2008 15:45 Go to next message
I've made an operation that extends AbstractOperation then executed it
like so:
Operation o = new Operation();
o.addContext(Workbench.getInstance().getOperationSupport().g etUndoContext());
Workbench.getInstance().getOperationSupport().getOperationHi story().execute(o,
monitor, null);
This doesn't seem to add it into the Undo chain, as the undo action icon
doesn't become enabled after I perform the operation.
Is there something wrong with this approach? Is the proper way detailed
somewhere in a tutorial? I have looked at the eclipse help on Undoable
Operations but it seems that I have done everything that's in there.
Philippe
Re: Undoable Operation Not Working [message #331230 is a reply to message #331068] Thu, 28 August 2008 10:40 Go to previous message
Are you saying that Undo becomes enabled after the execute(*) call?
That sounds correct, no? You can only undo it after you've executed it
once.
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Previous Topic:Suppressing lazy loading of a plugin?
Next Topic:Is there any way to control the visibility or enablement of a wizard?
Current Time: Sun Aug 31 21:06:40 EDT 2025
Powered by FUDForum. Page generated in 0.03531 seconds
