Home » Eclipse Projects » Eclipse Platform » Suppressing lazy loading of a plugin?
Suppressing lazy loading of a plugin? [message #331044] Thu, 21 August 2008 17:48 Go to next message
Originally posted by: nick.allen.onlinehome.de
I would like to add a resource change listener to the workspace when
Eclipse starts. This is of course relatively straight forward. The
problem is that my plugin is not instantiated until the user uses one of
its features (eg selecting a menu item). This is far too late - I need
my plugin to be automatically started when Eclipse starts up.
How do I do that?
Nick
Re: Suppressing lazy loading of a plugin? [message #331045 is a reply to message #331044] Thu, 21 August 2008 17:52 Go to previous messageGo to next message
I'm becoming a master of answering my own questions! It looks like I
just need to change Eclipse-LazyStart to false in MANIFEST.MF.
Nick
Nicholas Allen wrote:
> How do I do that?
> Nick
Re: Suppressing lazy loading of a plugin? [message #331046 is a reply to message #331045] Thu, 21 August 2008 18:01 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
BUT don't do it! It is very expensive. Many plugins think they need this
and then it really slows down the startup.
Instead use the Save Participant interface instead.
See
http://www.eclipse.org/articles/Article-Resource-deltas/reso urce-deltas.html
Rich Kulp
Re: Suppressing lazy loading of a plugin? [message #331047 is a reply to message #331046] Thu, 21 August 2008 18:22 Go to previous messageGo to next message
Ok - but my plugin is tiny (currently 30kb). Will it really be that slow?
Also, if I understood correctly I can only register a save participant
once my plugin is loaded - right? Once I register I get a backlog of
changes sent to me that may have happened a long time ago. If I am
correct in this assumption then this will not work for what I want. Let
me know if I am mistaken - I am still extremely new to Eclipse.
Nick
> See
Re: Suppressing lazy loading of a plugin? [message #331048 is a reply to message #331045] Thu, 21 August 2008 18:30 Go to previous messageGo to next message
Actually, it seems I need to use the org.eclipse.startup extension point
to achieve this. Eclipse-LazyStart false means my plugin never starts...
Nick
Re: Suppressing lazy loading of a plugin? [message #331063 is a reply to message #331047] Fri, 22 August 2008 08:54 Go to previous messageGo to next message
You are one small plugin, but they all add up.
Why can't you respond once your plugin is activated. Why do you need to
listen to the resources immediately? What would you do right away that
couldn't be done later when your plugin is finally activated?
> Cheers,
> Nick
>> See
Rich Kulp
Re: Suppressing lazy loading of a plugin? [message #331081 is a reply to message #331063] Sat, 23 August 2008 12:00 Go to previous messageGo to next message
I am writing a plug-in for the Bazaar version control system. If the
user renames a file (eg by renaming a class) I need to tell Bazaar that
the file has been moved as soon (or shortly after) that happens. If I
have not added a listener when Eclipse starts then I will not hear about
any file moves until the user uses one of my menu commands. This could
be hours (or even days) later - I can't see how this could ever work...
Nick
Re: Suppressing lazy loading of a plugin? [message #331083 is a reply to message #331081] Sun, 24 August 2008 02:22 Go to previous messageGo to next message
Nick,
I might be wrong, but IMHO, if you are creating plugins for the version
control system, probably you should be hooking into the team api. Not
the IResouceChangeListener
- Prakash
www.eclipse-tips.com
> Nick
Re: Suppressing lazy loading of a plugin? [message #331084 is a reply to message #331083] Sun, 24 August 2008 08:49 Go to previous messageGo to next message
AFAICT the Team API is not particularly good for distributed version
control systems. For example, it forces users to register the VCS for
each branch (my plug-in auto detects this). The Team stuff is much more
oriented towards centralized VCS. If it's possible to have rename
support without any configuration from the user (as is currently
possible in my plug-in) then I may consider using it instead. If it
requires the user to invoke Team/Share... from context menu for each
branch (which is what I think is required from my limited
investigations) then I definitely won't use it for rename support...
Nick
Prakash G.R. wrote:
> Nick,
> version control system, probably you should be hooking into the team
> api. Not the IResouceChangeListener
> - Prakash
>> Nick
Re: Suppressing lazy loading of a plugin? [message #331087 is a reply to message #331084] Sun, 24 August 2008 12:32 Go to previous messageGo to next message
I never went thru the team api. But it should provide all the options
like comparing with different versions, replacing the content with a old
version, syncing up a tree etc. It appears that you are looking only for
Save operation?
- Prakash
www.blog.eclipse-tips.com
> Nick
> Prakash G.R. wrote:
>> Nick,
>> - Prakash
>>> Nick
Re: Suppressing lazy loading of a plugin? [message #331225 is a reply to message #331048] Thu, 28 August 2008 10:33 Go to previous message
Right, lazystart (and now autostart) is about automatically activating
the plugin when the first resource/class is loaded from it (as opposed
to manually requesting a start from the OSGi framework).
As for the other suggestions ... don't use org.eclipse.ui.startup!
OK, that being said, there is a cost once a plugin is started, the
framework feels free to load any and all resources (especially UI
resources).
The solution ... a lib/core plugin that uses org.eclipse.ui.startup to
add your resource listener, but contains little beyond your core data
model and contains no UI.
The second plugin that contains your UI and most of your functionality
can then work normally, and you will have minimized both the memory cost
and the performance cost for your early startup.
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Previous Topic:How to get notified when Eclipse renames or deletes a file in the workspace?
Next Topic:Undoable Operation Not Working
Current Time: Thu Jul 17 21:29:04 EDT 2025
Powered by FUDForum. Page generated in 0.29971 seconds
