Home » Language IDEs » Java Development Tools (JDT) » Debugging with HotSwap No Longer Working...
Debugging with HotSwap No Longer Working... [message #33535] Wed, 21 May 2003 09:38 Go to next message
Originally posted by: jrp.strata-group.com
I am using eclipse 2.1 under win2000. I am debugging my apps with
J2SDK1.4.1. I was able to use HotSwap instantly out of the box. I haven't
used it in a couple of weeks and now I notice it isn't working. I get no
error dialogs when changing/saving/building changes during a debug session.
I have all the flags turned on.
I even tried debugging under jdk1.3.1 because I knew I would get a HotSwap
not supported dialog, but I did not.
I can find no settings that would effect this.
Can anyone give my any clues ? My next move is to reinstall from
scratch....arg ^%(*%^(&.
Thanks In Advance,
Jim
Re: Debugging with HotSwap No Longer Working... [message #33569 is a reply to message #33535] Wed, 21 May 2003 09:46 Go to previous messageGo to next message
Originally posted by: tom.eicher.gmx.ch.nodomain
Are you using eclipse 2.1 or a newer integration build? I experienced the
same behaviour with I20030516.
-tom
"Jim Piersol" <jrp@strata-group.com> wrote in message
news:bafvet$gc3$1@rogue.oti.com...
haven't
session.
> Thanks In Advance,
> Jim
Re: Debugging with HotSwap No Longer Working... [message #33682 is a reply to message #33569] Wed, 21 May 2003 10:20 Go to previous messageGo to next message
Originally posted by: jared-eclipse.mn.rr.com
Bug number?
- Jared
> -tom
> haven't
> session.
>> HotSwap not supported dialog, but I did not.
>> Thanks In Advance,
>> Jim
Re: Debugging with HotSwap No Longer Working... [message #33739 is a reply to message #33682] Wed, 21 May 2003 10:37 Go to previous messageGo to next message
getting lazy...
https://bugs.eclipse.org/bugs/show_bug.cgi?id=37926
-tom
"Jared Burns" <jared-eclipse@mn.rr.com> wrote in message
news:bag1le$ig4$1@rogue.oti.com...
> Bug number?
> - Jared
the
> > -tom
> >> Hi,
> > haven't
no
> > session.
> >> Thanks In Advance,
> >> Jim
Update: Re: Debugging with HotSwap No Longer Working... [message #33907 is a reply to message #33535] Wed, 21 May 2003 11:05 Go to previous message
A quick update. I reinstalled eclipse 2.1 but left all my .metadata intact.
When I restarted eclipse, I noticed that HotSwap was working only when I
explicitly did a Build All after making a change. I found that the
WorkSpace setting for "Build All After Resource Modification" was not set.
Once I set that flag, HotSwap is on again.... Thank God. I am not sure I
could live without it again.....
Jim
haven't
session.
> Thanks In Advance,
> Jim
Previous Topic:compiler bug
Next Topic:[Howto] turn on "Label Decorators" for CVS in Eclipse 2.1?
Current Time: Sun Aug 31 08:20:49 EDT 2025
Powered by FUDForum. Page generated in 0.03475 seconds
