Home » Eclipse Projects » Eclipse Platform » Problem starting OSGI with framework.extension
Problem starting OSGI with framework.extension [message #330948] Tue, 19 August 2008 05:37 Go to next message
Hi!
I have a code generator (a headless RCP application) which I'd like to
start within Eclipse from an ANT script. This code generator plug-in is
not installed in Eclipse - it should be rather started from the workspace.
For that I had a solution working nicely with Eclipse 3.3. I used the
osgi.framework.extension property to specifiy the plug-in path (located in
the workspace). All that was fine until I tried to upgrade to Eclipse 3.4.
Now, with Eclipse 3.4 I use the same ANT scripts but it seems that my
additional generator plug-in is not detected anymore although I still use
the framework.extension mechanism. In the Eclipse Platform documentation
the property has still the same description - but something must have been
changed since I cannot run it on 3.4.
Any ideas how I could launch my plug-in with Ganymede?
BTW, if I run the application directly from Eclipse (without ANT) it also
works.
Gernot
Re: Problem starting OSGI with framework.extension [message #330954 is a reply to message #330948] Tue, 19 August 2008 09:48 Go to previous message
Gernot Sch. wrote:
> Hi!
> in the workspace). All that was fine until I tried to upgrade to Eclipse
> 3.4.
> use the framework.extension mechanism. In the Eclipse Platform
> documentation the property has still the same description - but
> something must have been changed since I cannot run it on 3.4.
> also works.
Also asking in equinox, they'll have a better idea
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Previous Topic:Create a plugin manually
Next Topic:Help regarding equinox p2
Current Time: Sun Aug 31 01:41:22 EDT 2025
Powered by FUDForum. Page generated in 0.10704 seconds
