eclipse breaks at no breakpoint [message #330932] |
Mon, 18 August 2008 08:27 |
Originally posted by: automatic.javalobby.org
somtimes when i start jboss in debug mode, eclipse tends to break in Timer.class, even though i didn't define any break points there.
public void run() {
try {
mainLoop();
} finally {
// Someone killed this Thread, behave as if Timer cancelled
synchronized(queue) {// eclipse stops here!
newTasksMayBeScheduled = false;
queue.clear(); // Eliminate obsolete references
how can i avoid that?
btw , is there something like javarebel only in open-source, which will allow me to reload java classes in jboss without re-deploy the application? (it takes 20 seconds for the re-deploy)
FUDForum. Page generated in 0.02786 seconds
