Home » Eclipse Projects » Eclipse Platform » How do I know if Save button is pressed?
How do I know if Save button is pressed? [message #330929] Mon, 18 August 2008 03:11 Go to next message
How do I come to know if user presses 'Save' button in Eclipse IDE?
Is there any listener or some other place where I get a notification about
the save button having been pressed?
Please guide.
Thanks.
Re: How do I know if Save button is pressed? [message #330930 is a reply to message #330929] Mon, 18 August 2008 05:47 Go to previous messageGo to next message
On Mon, 18 Aug 2008 07:11:10 +0000 (UTC), kaprasannagt@gmail.com
(kaprasanna) wrote:
>Hello,
>Please guide.
>Thanks.
I assume you are talking about saving an editor. You save your editor
by implementing IEditorPart (which comes for free if you subclass your
editor from EditorPart). You have to implement the save() and saveAs()
methods.
If you are not using an editor it should be sufficient to implement
ISaveablePart where the save/saveAs methods are introduced.
Achim
Achim Lörke
Eclipse-Stammtisch in the Braunschweig, Germany area:
http://www.bredex.de/de/news/events.html
Re: How do I know if Save button is pressed? [message #330938 is a reply to message #330930] Mon, 18 August 2008 10:52 Go to previous messageGo to next message
> methods.
And if it's just the save command in general (not in your specific part)
then you can use an IExecutionListener and ICommandService to listen for
the save command to be executed. In 3.3, it won't tell you when the
button is pressed, though.
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: How do I know if Save button is pressed? [message #330951 is a reply to message #330938] Tue, 19 August 2008 09:25 Go to previous messageGo to next message
Thanks for the replies.
I am indeed using Eclipse 3.3.2.
I tried with ISaveablePart but it doesn't allow me to save some swing
components which are on top of a view.
As in, when some change happens (say in a text field), I'd like to have
the save button on the toolbar to be enabled and then I can take action in
the doSave() method.
What's the solution?
Thanks in advance.
Re: How do I know if Save button is pressed? [message #330957 is a reply to message #330951] Tue, 19 August 2008 10:12 Go to previous messageGo to next message
> in the doSave() method.
your view needs to both update the isDirty() flag and fire the
PROP_DIRTY property. That tells eclipse to 1) add the '*' to your view
tab and 2) enable the save button/command.
See org.eclipse.ui.part.WorkbenchPart.firePropertyChange(int), which is
often used in a part's implementation of setDirty(boolean)
PW
Paul Webster
Re: How do I know if Save button is pressed? [message #330979 is a reply to message #330957] Wed, 20 August 2008 06:55 Go to previous messageGo to next message
Hi Paul,
My view implements ISaveablePart so I implement following methods :
isSaveOnCloseNeeded, isDirty, doSave.
Save on close works just great..
Problem is I can't get the save buton to be enabled on demand. This is how
isDirty() looks like :
public boolean isDirty () {
if(something) {
firePropertyChange(PROP_DIRTY);
return true;
else
return false;
Not only the save button doesn't get enabled, I get this error : unhandled
event loop exception java.lang.StackOverFlow at the firePropertyChange()
line.
What is wrong? What I must be doing?
Please guide.
Thanks.
Re: How do I know if Save button is pressed? [message #330983 is a reply to message #330979] Wed, 20 August 2008 09:32 Go to previous messageGo to next message
On Wed, 20 Aug 2008 10:55:57 +0000 (UTC), kaprasannagt@gmail.com
(kaprasanna) wrote:
>Hi Paul,
>line.
>Please guide.
>Thanks.
You should implement something like
private boolean isDirty = false;
public boolean isDirty() {
return isDirty;
public void setDirty(boolean dirty) {
isDirty = dirty;
firePropertyChange() whill notify the platform which will in turn call
isDirty() to get the dirty state. Using your implementation triggers
another property change and therefore goes into an indefinite
recursion.
Achim
Achim Lörke
Re: How do I know if Save button is pressed? [message #331010 is a reply to message #330983] Thu, 21 August 2008 03:46 Go to previous message
It all works just great..
Thank you so much for all the replies...
Previous Topic:Host name for Eclipse Application.
Next Topic:Building Eclipse 3.4 From Sources Fails
Current Time: Thu Oct 23 00:47:09 EDT 2025
Powered by FUDForum. Page generated in 0.04956 seconds
