Home » Language IDEs » C / C++ IDE (CDT) » F1 release
F1 release [message #33516] |
Wed, 22 May 2002 12:52  |
Is the current version of CDT compatible with the F1 release of eclipse??
Thanx,
Al
Re: F1 release [message #33782 is a reply to message #33714] |
Wed, 22 May 2002 17:01   |
When you say "it doesn't work" do you mean you can't access any CDT stuff from
within this version of Eclipse? CDT should work with F1 - there are a couple
people here that are using CDT with F1. Could you post the .log file
(eclipse/workspace/.metadata/.log)? If you've done your own build from CVS,
you might want to do a clean rebuild before using CDT with F1.
Dave
Allan Clearwaters wrote:
> I tried it on Winodws - it doesn't work. Don't know about Linux.
> Thanx,
> Al
> "Jeff Turnham" <turnham@ca.ibm.com> wrote in message
> news:acglfv$fpe$1@rogue.oti.com...
> > hi,
> > If you are referring to our latest code in CVS, then the answer is
> Yes...our latest code in cvs does build and run with
> > the F1 build.
> > However, if you mean the latest downloadable CDT (20020508), then the
> answer is maybe..I don't think anyone has tried it
> > (we only support CDT builds on the specific Eclipse builds that they were
> built and tested with)...If the 20020508 CDT
> > does not work on the various Eclipse freezes (F1, F2...), then we may
> consider providing a downloadable build of the
> > latest CDT in the meantime. Please report any problems you find here or
> in bugzilla(http://bugs.eclipse.org/).
> > Thanks...
> > Jeff.
> > "Allan Clearwaters" <allan@object-forge.com> wrote in message
> news:acghkf$dsu$1@rogue.oti.com...
> eclipse??
> > > Thanx,
> > > Al
Re: F1 release [message #33816 is a reply to message #33782] |
Thu, 23 May 2002 03:47   |
David,
I will rebuild from the CDT archive - my previous comments a relative to the
cdt version associated with M5. More on News at Ten ... and thanks,
Al
"David McKnight" <dmcknigh@ca.ibm.com> wrote in message
news:3CEC0715.30A254BB@ca.ibm.com...
from
couple
CVS,
> Dave
> > Thanx,
> > Al
> > > hi,
> > > the F1 build.
were
or
> > > Thanks...
> > > Jeff.
> > eclipse??
> > > > Thanx,
> > > > Al
Re: F1 release [message #33850 is a reply to message #33782] |
Thu, 23 May 2002 06:57   |
David,
Where do I find information regarding building from the repository. At the
moment I can't even find the CDT repository itself, much less build from it.
dev.eclipse.org/home/eclipse gives me access to the eclipse stuff itself -
where is CDT??
Thanx,
Al
from
couple
CVS,
> Dave
> > Thanx,
> > Al
> > > hi,
> > > the F1 build.
were
or
> > > Thanks...
> > > Jeff.
> > eclipse??
> > > > Thanx,
> > > > Al
Re: F1 release [message #33878 is a reply to message #33850] |
Thu, 23 May 2002 07:07   |
David,
Cancel my last - figured it out. The repository is at /home/tools - I'm
pulling the code now.
Thanx,
Al
news:acih6q$63s$1@rogue.oti.com...
> David,
the
it.
> where is CDT??
> Thanx,
> Al
stuff
> from
> couple
> CVS,
> > Dave
> > > Thanx,
> > > Al
> > > > hi,
> > > > the F1 build.
the
> were
may
here
> or
> > > > Thanks...
> > > > Jeff.
> > > eclipse??
> > > > > Thanx,
> > > > > Al
Re: F1 release [message #33908 is a reply to message #33782] |
Thu, 23 May 2002 11:20   |
David,
I've been trundling through the checkout process for CDT. Is there a quick
way to add external jar files to a project other than one-by-one popup?
Another question/problem - I don't seem to be able to checkout
com.ibm.debug. When I try, all I get is any empty directory. Any reason
for this?
Thanx,
Al
from
couple
CVS,
> Dave
> > Thanx,
> > Al
> > > hi,
> > > the F1 build.
were
or
> > > Thanks...
> > > Jeff.
> > eclipse??
> > > > Thanx,
> > > > Al
Re: F1 release [message #34020 is a reply to message #33908] |
Thu, 23 May 2002 13:22   |
If you right-click on the project, and select Properties, then go to Java
Build Path. Click on "Add external JARS", and the dialog pops up will let
you select multiple jar files to add. Hold on to the "CTRL" key will let
you select multiple jar files.
Another way of doing this is to edit the .classpath file of the project.
Add the following entry to your file:
<classpathentry kind="lib" path="../com.ibm.debug.pdt/epdc.jar"/>
will add epdc.jar as an external jar. You can add multiple jar file by
manually adding more entries.
As for com.ibm.debug, this directory was created for R1. You no longer
need this directory. com.ibm.debug.pdt replaces com.ibm.debug in R2.
Hope it helps.
- Samantha
> David,
> for this?
> Thanx,
> Al
> from
> couple
> CVS,
> > Dave
> > > Thanx,
> > > Al
> > > > hi,
> > > > the F1 build.
> were
> or
> > > > Thanks...
> > > > Jeff.
> > > eclipse??
> > > > > Thanx,
> > > > > Al
Re: F1 release [message #34040 is a reply to message #34020] |
Thu, 23 May 2002 14:08   |
We have had some talk about defining a common .classpath file for each of the CDT
plugins. We would check this file into CVS along with our code so that anyone
checking out the CDT code would not have to go through the process of specifying
external jars. I think the Eclipse base does something like this.
Dave
> Hope it helps.
> - Samantha
> > David,
> > for this?
> > Thanx,
> > Al
> > from
> > couple
> > CVS,
> > > Dave
> > > > Thanx,
> > > > Al
> > > > > hi,
> > > > > the F1 build.
> > were
> > or
> > > > > Thanks...
> > > > > Jeff.
> > > > eclipse??
> > > > > > Thanx,
> > > > > > Al
Re: F1 release [message #34140 is a reply to message #34072] |
Fri, 24 May 2002 10:43   |
Hi Allan,
The CDT is currently built and packaged by our overnight build process that is makefile based. Soon we plan to provide
the proper build.xml that can build\package our stuff from both inside and outside Eclipse, but we have been waiting for
Eclipse to publish it's internal build scripts so that we can do it in the same way (which we assume would be the
supported\recommended way ;-). In the meantime the makefile based packaging process is very simple to describe.
Our overnight build scripts really just do the following:
cd <...>/eclipse/plugins
cvs checkout cdt
cd org.eclipse.cdt.dstore.core
make -s production
This "production" target performs a number of steps all in one shot:
1. It generates simple makefiles for every subdirectory of the CDT
2. It builds the entire CDT
3. It creates jars for all the plugins
4. It zips the source for all the plugins
5. It creates the final zip package (leaving out the source trees, makefiles, CVS directories, etc)
So if you followed these steps you should end up with a CDT package that you could then install on your base system.
If you don't need to create the final zip or the zipped up source for each plugin, you could alternatively perform the
following, which would just do steps 1-3:
make -s development (does steps 1 & 2)
make -s jars
I haven't tried it yet, but perhaps you could set this up as what is now called an "External Tool" in Eclipse. Anyway,
there is a document in the works that describes all of this...I will post a note here as soon as I'm done with it.
Hope that helps...
Jeff
"Allan Clearwaters" <allan@object-forge.com> wrote in message news:aclf76$hcf$1@rogue.oti.com...
> I now have the CDT projects loaded on to my Eclipse workbench. At this
> point I can invoke the runtime system and CDT is installed ... well ....
> When the runtime starts up I get the following message on the console:
> Reference action not found: additions
> I assume this wonderfully enegmatic message is something everyone knows
> about ... except me. What do I do to fix this?
> If an when I get all of this stitched together I would like to genertate jar
> files and install CDT on my base system. The documentations says highlight
> plugin.xml and follow the wizard. I pick build.jar and nothing happens; a
> quick look at build.xml shows why. So far as I can see nothing is defined.
> I need a pointer here. How is the CDT installation built and if I'm doing
> here what do I need?
> Thanx,
> Al
> PS. attached is the log for the above error
> !SESSION May 24, 2002
> 14:21:07.249 ---------------------------------------------
> java.version=1.3.1_03
> java.vendor=Sun Microsystems Inc.
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_GB
> Command-line arguments: -dev bin -data E:\eclipse\runtime-workspace -os
> win32 -ws win32 -arch x86
> !ENTRY org.eclipse.core.resources 1 4 May 24, 2002 14:21:07.249
> !MESSAGE Reference action not found: additions
> > Thanx,
> > Al
Re: F1 release [message #35183 is a reply to message #33782] |
Tue, 04 June 2002 20:17   |
Originally posted by: bighead_yaya.163.com
i can't start cdt too
following .log
!SESSION ??? 05, 2002
08:02:20.981 ----------------------------------------------
java.fullversion=J2RE 1.3.0 IBM build cn130-20020124 (JIT enabled: jitc)
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=zh_CN
Command-line arguments: -os win32 -ws win32 -arch x86 -install
file:G:/eclipse-SDK-20020602-win32/eclipse/
!ENTRY org.eclipse.core.runtime 2 1 ??? 05, 2002 08:02:20.981
!MESSAGE Problems encountered loading the plug-in registry.
!SUBENTRY 1 org.eclipse.core.runtime 2 1 ??? 05, 2002 08:02:20.981
!MESSAGE Unable to satisfy prerequisite constraint from
"org.eclipse.cdt.cpp.miners" to "org.apache.xerces".
!MESSAGE Plug-in "org.eclipse.cdt.cpp.ui" was disabled due to missing or
disabled prerequisite plug-in "org.eclipse.cdt.cpp.miners".
!MESSAGE Plug-in "org.eclipse.cdt.pa.ui" was disabled due to missing or
disabled prerequisite plug-in "org.eclipse.cdt.cpp.ui".
"org.eclipse.cdt.linux.help" to "org.eclipse.cdt.cpp.ui".
from
couple
CVS,
> Dave
> > Thanx,
> > Al
> > > hi,
> > > the F1 build.
were
or
> > > Thanks...
> > > Jeff.
> > eclipse??
> > > > Thanx,
> > > > Al
Re: F1 release [message #35223 is a reply to message #35183] |
Tue, 04 June 2002 22:39  |
Depending on which version of Eclipse you're using, you might have to edit a
file to satisfy the org.apache.xerces contraint. The version of this prereq
changed between F1 and F2.
Open up the file plugins/org.eclipse.cdt.cpp.miners/plugin.xml. In the
requires section, you'll see something like this:
<import plugin="org.apache.lucene" version="1.2.0"/>
<import plugin="org.eclipse.tomcat" version="4.0.3"/>
<import plugin="org.apache.xerces" version="3.2.1"/>
If you're using F1, the version for org.apache.xerces should be "3.2.1". If
you're using F2, the vesrion should be "4.0.3". Try editing version or
leaving it out and see if this fixes the problem.
Dave
> following .log
> from
> couple
> CVS,
> > Dave
> > > Thanx,
> > > Al
> > > > hi,
> > > > the F1 build.
> were
> or
> > > > Thanks...
> > > > Jeff.
> > > eclipse??
> > > > > Thanx,
> > > > > Al
Re: F1 release [message #35238 is a reply to message #35183] |
Tue, 04 June 2002 22:34  |
I believe the problem you are having is due to the fact that for the F2 (or 20020602) version of Eclipse, the version
number of the org.apache.xerces plugin changed from 3.2.1 to 4.0.3. This broke one of our plugins
(org.eclipse.cdt.cpp.miners) that was depending on the 3.2.1 version being present, hence the message from your log:
Can you download the latest CDT nightly build for F2 and see if that fixes your problem?
Jeff.
"mm" <bighead_yaya@163.com> wrote in message news:adjjv2$h1b$1@rogue.oti.com...
> following .log
> from
> couple
> CVS,
> > Dave
> > > Thanx,
> > > Al
> > > > hi,
> > > > the F1 build.
> were
> or
> > > > Thanks...
> > > > Jeff.
> > > eclipse??
> > > > > Thanx,
> > > > > Al
Current Time: Sat Aug 30 23:41:52 EDT 2025
Powered by FUDForum. Page generated in 0.07707 seconds
