dependent plugins | plugin packaging [message #330874] |
Thu, 14 August 2008 16:26  |
Originally posted by: prasad.chand.gmail.com
I am trying to package a plugin as an rcp application. As a part of that
process I have created a product configuration file where I specify
the splash-screen and the icons (of various sizes).
When I test the product (by clicking the Launch eclipse app) it works
fine.But when I export the product and launch it as an application I am
facing the following two problems.
1. The icons and splashscreen are missing.
> I checked the config.ini its alright but splash.bmp and other icon
files are missing in the plugins/myplugin folder (though they are
present in my workspace when I exported the product).
2.unnecessary plugins are included in the exported application. How do I
just select just the dependent plugins of myplugin alone. I have seen
plug-in dependencies view but I am unable to "copy" them to the
configuration file.
Thanks in advance,
Prasad
Re: dependent plugins | plugin packaging [message #330940 is a reply to message #330927] |
Mon, 18 August 2008 11:58  |
Christophe Fondacci wrote:
> Hello,
> For you first problem, you simply have to tell the build to include the
> files you need (typically your icons / image files).
> You can do this by editing the build.properties file. You can then
> select your resources to include form the "Build" tab (Binary build
> section) or directly by editing the build.properties file through the
> corresponding tab.
> Then reexport and your resources will be there.
Thank you. I an now able to see the icons.
> For your 2nd point (dependencies), i am not quite sure what you need.
> You have to select your plugin dependencies from the "Dependencies" tab
> of the manifest editor of each of your plugin. Then if you have a
> product, you have to select the whole set of plugins (or features) from
> the "Configuration" tab of the product editor. This is what will be
> exported. It might be normal to have "more" plugins exported than what
> you see in these views since your dependent plugin may depend on other
> plugins which may be exported as well. The button "Compute required
> plugins" is the one you need to automatically detect which plugins
> should be exported with your application or product.
I had not taken into account the dependent plugins of plugins I
included. Thanks for your comments.
> Hope this helps.
> Christophe.
> "Prasad Chand" <prasad.chand@gmail.com> a écrit dans le message de
> news:g824dn$t0h$1@build.eclipse.org...
>> that process I have created a product configuration file where I
>> specify the splash-screen and the icons (of various sizes).
>> am facing the following two problems.
>> I just select just the dependent plugins of myplugin alone. I have
>> seen plug-in dependencies view but I am unable to "copy" them to the
>> configuration file.
>> Thanks in advance,
>> Prasad
FUDForum. Page generated in 0.06160 seconds
