Home » Eclipse Projects » Eclipse Platform » Menu contributions from multiple plugins
Menu contributions from multiple plugins [message #330822] Thu, 14 August 2008 05:01 Go to next message
I have some menu contributions that are made from a base plugin using the
org.eclipse.ui.actionSets extension point.
I now wish to add to those menus from another plugin, but I can't seem to
make it work. The items in my new plugin don't appear anywhere, and I can
see no errors anywhere either.
I'm guessing that the problem is EITHER :
a) The base contributions need to expose something somewhere to allow
other things to add to them, OR
b) I need to add something to the reference to say where the base
definitions reside (ie a pointer to the base plugin), OR
c) something different entirely :-)
Can anyone point me in the right direction please?
Richard
Re: Menu contributions from multiple plugins [message #330837 is a reply to message #330822] Thu, 14 August 2008 09:27 Go to previous messageGo to next message
> the org.eclipse.ui.actionSets extension point.
> to make it work. The items in my new plugin don't appear anywhere, and I
> can see no errors anywhere either.
Action sets are not extensible, as I recently learned. See this message
and the rest of the thread it is part of:
http://dev.eclipse.org/newslists/news.eclipse.platform/msg76 240.html
Hope this helps,
Eric
Re: Menu contributions from multiple plugins [message #330843 is a reply to message #330837] Thu, 14 August 2008 09:55 Go to previous messageGo to next message
Hi Eric,
thanks for the answer - I guess we'll have to do some redefintion of stuff
into MenuContributions....
Richard
> Hope this helps,
> Eric
Re: Menu contributions from multiple plugins [message #330871 is a reply to message #330843] Thu, 14 August 2008 15:28 Go to previous messageGo to next message
> Hi Eric,
> stuff into MenuContributions....
If you get things to work the way you want them, please consider putting
together an article or brief description and example. I find that the
documentation and existing examples of this stuff are scarce.
I'm particularly interested in having a common toolbar that is defined
by one plugin but contributed to by others. I tried a simple example of
that but couldn't get it to work and had to move on to other things for
the time being.
Eric
>>> seem to make it work. The items in my new plugin don't appear
>>> anywhere, and I can see no errors anywhere either.
>> message and the rest of the thread it is part of:
>> Hope this helps,
>> Eric
Re: Menu contributions from multiple plugins [message #330934 is a reply to message #330871] Mon, 18 August 2008 10:25 Go to previous message
>> Hi Eric,
> the time being.
Do you mean within one of your parts, or simply defining a main toolbar
that others can contribute to? The second should work in 3.3:
PluginA:
<extension
point="org.eclipse.ui.menus">
<menuContribution
locationURI="toolbar:org.eclipse.ui.main.toolbar?after=additions ">
<toolbar
id="z.ex.monkey.scripts">
<separator name="group0" visible="false"/>
<separator name="additions" visible="false"/>
<separator name="group1" visible="false"/>
</toolbar>
</menuContribution>
</extension>
[/xml]
PluginB:
<extension
<menuContribution
locationURI="toolbar:z.ex.monkey.scripts?after=additions">
<command commandId="org.eclipse.ui.edit.copy"/>
</menuContribution>
</extension>
[/xml]
Later,
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Previous Topic:Show progress of GUI process
Next Topic:eclipse key bindings
Current Time: Wed Nov 26 00:41:54 EST 2025
Powered by FUDForum. Page generated in 0.25837 seconds
