Home » Eclipse Projects » Eclipse Platform » [DataBinding] ListBinding issue with uni-directional ON_REQUEST update
[DataBinding] ListBinding issue with uni-directional ON_REQUEST update [message #330772] Wed, 13 August 2008 00:32 Go to next message
Originally posted by: evolanakis.innoopract.com
please let me know if I should file a bug for this, or I just
misunderstood something.
I'm binding two IObservableLists named target and model. Update from
target to model is automatic. Update from model to target is on request.
The strange thing is that invoking binding.updateModelToTarget() will
not pick up the changes in mdlBean (which properly fires events). This
can be worked around by adding a dummy listener to the model. :-P
Code Example (using Eclipse 3.4)
IObservableList target
= BeansObservables.observeList(realm, tgtBean, tgtProperty);
IObservableList model
= BeansObservables.observeList(realm, mdlBean, mdlPropert);
Binding binding = dbc.bindList(
target,
model,
new UpdateListStrategy(UpdateListStrategy.POLICY_UPDATE),
new UpdateListStrategy(UpdateListStrategy.POLICY_ON_REQUEST));
// try modifying the model
mdlBean.addSomething(...);
binding.updateModelToTarget(); // result: target/tgtBean unchanged
// add listener (once)
binding.getModel().addChangeListener(new IChangeListener() {
public void handleChange(ChangeEvent event) {
// dummy listener
binding.updateModelToTarget(); // result: target/tgtBean changed
Thanks for your response,
Elias.
Elias Volanakis
Innoopract, Inc.
http://www.innoopract.com
Re: [DataBinding] ListBinding issue with uni-directional ON_REQUEST update [message #330812 is a reply to message #330772] Wed, 13 August 2008 16:39 Go to previous messageGo to next message
Please file a bug (or could this be caused by
https://bugs.eclipse.org/bugs/show_bug.cgi?id=236605 ?)
Boris
"Elias Volanakis" <evolanakis@innoopract.com> wrote in message
news:g7to4h$td$1@build.eclipse.org...
> not pick up the changes in mdlBean (which properly fires events). This can
> target,
> model,
> // dummy listener
> Elias.
> Elias Volanakis
> Innoopract, Inc.
Re: [DataBinding] ListBinding issue with uni-directional ON_REQUEST update [message #330814 is a reply to message #330812] Wed, 13 August 2008 19:48 Go to previous messageGo to next message
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=244098
Elias.
Elias Volanakis
Innoopract, Inc.
Re: [DataBinding] ListBinding issue with uni-directional ON_REQUEST update [message #1431332 is a reply to message #330814] Thu, 25 September 2014 10:40 Go to previous message
Just use something good.
Previous Topic:CommonNavigator Filters : how to shown only files (*.xmlprj) and parent folders ?
Next Topic:Platform example for active but disabled handler
Current Time: Tue Dec 02 09:10:45 EST 2025
Powered by FUDForum. Page generated in 0.04994 seconds
