[DataBinding] ListBinding issue with uni-directional ON_REQUEST update [message #330772] |
Wed, 13 August 2008 00:32  |
Originally posted by: evolanakis.innoopract.com
please let me know if I should file a bug for this, or I just
misunderstood something.
I'm binding two IObservableLists named target and model. Update from
target to model is automatic. Update from model to target is on request.
The strange thing is that invoking binding.updateModelToTarget() will
not pick up the changes in mdlBean (which properly fires events). This
can be worked around by adding a dummy listener to the model. :-P
Code Example (using Eclipse 3.4)
IObservableList target
= BeansObservables.observeList(realm, tgtBean, tgtProperty);
IObservableList model
= BeansObservables.observeList(realm, mdlBean, mdlPropert);
Binding binding = dbc.bindList(
target,
model,
new UpdateListStrategy(UpdateListStrategy.POLICY_UPDATE),
new UpdateListStrategy(UpdateListStrategy.POLICY_ON_REQUEST));
// try modifying the model
mdlBean.addSomething(...);
binding.updateModelToTarget(); // result: target/tgtBean unchanged
// add listener (once)
binding.getModel().addChangeListener(new IChangeListener() {
public void handleChange(ChangeEvent event) {
// dummy listener
binding.updateModelToTarget(); // result: target/tgtBean changed
Thanks for your response,
Elias.
Elias Volanakis
Innoopract, Inc.
http://www.innoopract.com
Re: [DataBinding] ListBinding issue with uni-directional ON_REQUEST update [message #330812 is a reply to message #330772] |
Wed, 13 August 2008 16:39   |
Please file a bug (or could this be caused by
https://bugs.eclipse.org/bugs/show_bug.cgi?id=236605 ?)
Boris
"Elias Volanakis" <evolanakis@innoopract.com> wrote in message
news:g7to4h$td$1@build.eclipse.org...
> not pick up the changes in mdlBean (which properly fires events). This can
> target,
> model,
> // dummy listener
> Elias.
> Elias Volanakis
> Innoopract, Inc.
FUDForum. Page generated in 0.33649 seconds
