Home » Eclipse Projects » Eclipse Platform » [Databinding] Without PropertyChangeListener
[Databinding] Without PropertyChangeListener [message #330754] Tue, 12 August 2008 11:55 Go to next message
I only need to update my model from the view not vice versa. Therefore I
would like to avoid to implement PropertyChangeListener support in my model.
I assume I can configure UpdateValueStrategy to tell the system that I
want to have only a one direction binding (only Ui to model). Can
someone point me in the right direction on how to do this?
Best regards, Lars
Re: [Databinding] Without PropertyChangeListener [message #330765 is a reply to message #330754] Tue, 12 August 2008 12:15 Go to previous messageGo to next message
You want the PojoObservables coming with 3.4 which don't require
PropertyChangeListeners on the model side.
Tom
Lars Vogel schrieb:
> model.
> Best regards, Lars
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: [Databinding] Without PropertyChangeListener [message #330767 is a reply to message #330765] Tue, 12 August 2008 13:30 Go to previous messageGo to next message
Awesome! Thank you. I uploaded a small example as a reference for
others:
http://www.vogella.de/articles/EclipseDataBinding/article.ht ml#eclipsedatabindingpojo
Re: [Databinding] Without PropertyChangeListener [message #330770 is a reply to message #330767] Tue, 12 August 2008 17:57 Go to previous message
> others:
You should add it to the Data Binding Snippets page in the Eclipse Wiki:
http://wiki.eclipse.org/index.php/JFace_Data_Binding/Snippet s
Eric
Previous Topic:java heap | Out of memory | jobs api
Next Topic:How to get fully qualified names of classes in a project
Current Time: Fri Jul 18 16:56:27 EDT 2025
Powered by FUDForum. Page generated in 0.12558 seconds
