Test framework problem: TestListener NoClassDefFoundError [message #330724] |
Tue, 12 August 2008 03:11 |
Originally posted by: erikjv.mac.com
--------------050907060506030802090403
We are developing an Eclipse workbench-based application and we are
using JUnit 3 for various tests. These test run fine when launched from
the workbench. Now I have tried to configure a PDE build to run the
tests using the Eclipse test framework, and I get the dreaded "Failed to
execute runnable (java.lang.NoClassDefFoundError:
junit/framework/TestListener)".
I double-checked the plug-ins and dependencies, and the org.junit
plug-in (3.8.1) is there, org.eclipse.ant.optional.junit is there, and
org.eclipse.core.runtime.compatibility is there. Actually, the complete
Eclipse-SDK, delta-pack and test framework are used for the test
installation (along GEF, EMF, GMF and parts of WST).
Now my guess is that some plug-in dependencies are wrong, or some
plug-ins are not loaded for some reason. What I would like to know, is
how I can debug this. So, is there a way to ask Eclipse to write all
plug-in dependency/load information?
I have attached the workbench log in case anybody is willing to take a
look at it.
Erik Verbruggen.
name="nl.edmond.weaver.gui.AllTests.txt"
Content-Disposition: inline;
filename="nl.edmond.weaver.gui.AllTests.txt"
Install location:
file:/Users/erik/no-backup/trunk/EclipseTest/
Configuration file:
file:/Users/erik/no-backup/trunk/EclipseTest/configuration/c onfig.ini loaded
Configuration location:
Framework located:
file:/Users/erik/no-backup/trunk/EclipseTest/plugins/org.ecl ipse.osgi_3.4.0.v20080605-1900.jar
Framework classpath:
Debug options:
file:/Users/erik/no-backup/trunk/EclipseTest/.options not found
Time to load bundles: 62
!SESSION 2008-08-11 16:44:53.335 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.5.0_13
java.vendor=Apple Inc.
BootLoader constants: OS=macosx, ARCH=x86, WS=carbon, NL=en_US
Framework arguments: -application org.eclipse.test.uitestapplication formatter=org.apache.tools.ant.taskdefs.optional.junit.XMLJU nitResultFormatter,/Users/erik/no-backup/trunk/EclipseTest/n l.edmond.weaver.gui.AllTests.xml -testPluginName nl.edmond.weaver.gui.test -className nl.edmond.weaver.gui.AllTests
Command-line arguments: -application org.eclipse.test.uitestapplication -data /Users/erik/no-backup/trunk/EclipseTest -clean formatter=org.apache.tools.ant.taskdefs.optional.junit.XMLJU nitResultFormatter,/Users/erik/no-backup/trunk/EclipseTest/n l.edmond.weaver.gui.AllTests.xml -testPluginName nl.edmond.weaver.gui.test -className nl.edmond.weaver.gui.AllTests -os macosx -ws carbon -arch x86 -consoleLog -debug
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:54.404
!MESSAGE Unable to find feature.xml in directory: /Users/erik/no-backup/trunk/EclipseTest/features/org.eclipse .nls.nl_0.2.0.v20080629043401.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.436
!MESSAGE Could not install bundle plugins/com.ibm.icu_3.8.1.v20080530.jar Bundle "com.ibm.icu" version "3.8.1.v20080530" has already been installed from: reference:file:plugins/com.ibm.icu_3.8.1.v20080530.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.437
!MESSAGE Could not install bundle plugins/com.jcraft.jsch_0.1.37.v200803061811.jar Bundle "com.jcraft.jsch" version "0.1.37.v200803061811" has already been installed from: reference:file:plugins/com.jcraft.jsch_0.1.37.v200803061811. jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.441
!MESSAGE Could not install bundle plugins/javax.servlet.jsp_2.0.0.v200806031607.jar Bundle "javax.servlet.jsp" version "2.0.0.v200806031607" has already been installed from: reference:file:plugins/javax.servlet.jsp_2.0.0.v200806031607 .jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.443
!MESSAGE Could not install bundle plugins/javax.servlet_2.4.0.v200806031604.jar Bundle "javax.servlet" version "2.4.0.v200806031604" has already been installed from: reference:file:plugins/javax.servlet_2.4.0.v200806031604.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.448
!MESSAGE Could not install bundle plugins/javax.xml_1.3.4.v200806030440.jar Bundle "javax.xml" version "1.3.4.v200806030440" has already been installed from: reference:file:plugins/javax.xml_1.3.4.v200806030440.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.449
!MESSAGE Could not install bundle plugins/nl.edmond.weaver.gui.help_1.0.0/ Bundle "nl.edmond.weaver.gui.help" version "1.0.0" has already been installed from: reference:file:plugins/nl.edmond.weaver.gui.help_1.0.0
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.450
!MESSAGE Could not install bundle plugins/nl.edmond.weaver.gui.product_1.0.0.jar Bundle "nl.edmond.weaver.gui.product" version "1.0.0" has already been installed from: reference:file:plugins/nl.edmond.weaver.gui.product_1.0.0.ja r
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.451
!MESSAGE Could not install bundle plugins/nl.edmond.weaver.gui.translations.gef_1.0.0.jar Bundle "nl.edmond.weaver.gui.translations.gef" version "1.0.0" has already been installed from: reference:file:plugins/nl.edmond.weaver.gui.translations.gef _1.0.0.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.454
!MESSAGE Could not install bundle plugins/nl.edmond.weaver.gui.translations_1.0.0.jar Bundle "nl.edmond.weaver.gui.translations" version "1.0.0" has already been installed from: reference:file:plugins/nl.edmond.weaver.gui.translations_1.0 .0.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.455
!MESSAGE Could not install bundle plugins/nl.edmond.weaver.gui.workflowdiagram.model.translati ons_1.0.0.jar Bundle "nl.edmond.weaver.gui.workflowdiagram.model.translations" version "1.0.0" has already been installed from: reference:file:plugins/nl.edmond.weaver.gui.workflowdiagram. model.translations_1.0.0.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.456
!MESSAGE Could not install bundle plugins/nl.edmond.weaver.gui.workflowdiagram.model_1.0.0.jar Bundle "nl.edmond.weaver.gui.workflowdiagram.model" version "1.0.0" has already been installed from: reference:file:plugins/nl.edmond.weaver.gui.workflowdiagram. model_1.0.0.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.457
!MESSAGE Could not install bundle plugins/nl.edmond.weaver.gui_1.0.0.jar Bundle "nl.edmond.weaver.gui" version "1.0.0" has already been installed from: reference:file:plugins/nl.edmond.weaver.gui_1.0.0.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.459
!MESSAGE Could not install bundle plugins/nl.edmond.weaver.workflow_2_0.translations_1.0.0.jar Bundle "nl.edmond.weaver.workflow_2_0.translations" version "1.0.0" has already been installed from: reference:file:plugins/nl.edmond.weaver.workflow_2_0.transla tions_1.0.0.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.460
!MESSAGE Could not install bundle plugins/nl.edmond.weaver.workflow_2_0_1.0.0.jar Bundle "nl.edmond.weaver.workflow_2_0" version "1.0.0" has already been installed from: reference:file:plugins/nl.edmond.weaver.workflow_2_0_1.0.0.j ar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.470
!MESSAGE Could not install bundle plugins/org.apache.ant_1.7.0.v200803061910/ Bundle "org.apache.ant" version "1.7.0.v200803061910" has already been installed from: reference:file:plugins/org.apache.ant_1.7.0.v200803061910
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.474
!MESSAGE Could not install bundle plugins/org.apache.batik.bridge_1.6.0.v200805290154.jar Bundle "org.apache.batik.bridge" version "1.6.0.v200805290154" has already been installed from: reference:file:plugins/org.apache.batik.bridge_1.6.0.v200805 290154.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.477
!MESSAGE Could not install bundle plugins/org.apache.batik.css_1.6.0.v200805290154.jar Bundle "org.apache.batik.css" version "1.6.0.v200805290154" has already been installed from: reference:file:plugins/org.apache.batik.css_1.6.0.v200805290 154.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.479
!MESSAGE Could not install bundle plugins/org.apache.batik.dom.svg_1.6.0.v200805290154.jar Bundle "org.apache.batik.dom.svg" version "1.6.0.v200805290154" has already been installed from: reference:file:plugins/org.apache.batik.dom.svg_1.6.0.v20080 5290154.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.481
!MESSAGE Could not install bundle plugins/org.apache.batik.dom_1.6.0.v200805290154.jar Bundle "org.apache.batik.dom" version "1.6.0.v200805290154" has already been installed from: reference:file:plugins/org.apache.batik.dom_1.6.0.v200805290 154.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.483
!MESSAGE Could not install bundle plugins/org.apache.batik.ext.awt_1.6.0.v200805290154.jar Bundle "org.apache.batik.ext.awt" version "1.6.0.v200805290154" has already been installed from: reference:file:plugins/org.apache.batik.ext.awt_1.6.0.v20080 5290154.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.484
!MESSAGE Could not install bundle plugins/org.apache.batik.parser_1.6.0.v200805290154.jar Bundle "org.apache.batik.parser" version "1.6.0.v200805290154" has already been installed from: reference:file:plugins/org.apache.batik.parser_1.6.0.v200805 290154.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.486
!MESSAGE Could not install bundle plugins/org.apache.batik.pdf_1.6.0.v200806031500.jar Bundle "org.apache.batik.pdf" version "1.6.0.v200806031500" has already been installed from: reference:file:plugins/org.apache.batik.pdf_1.6.0.v200806031 500.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.489
!MESSAGE Could not install bundle plugins/org.apache.batik.svggen_1.6.0.v200805290154.jar Bundle "org.apache.batik.svggen" version "1.6.0.v200805290154" has already been installed from: reference:file:plugins/org.apache.batik.svggen_1.6.0.v200805 290154.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.491
!MESSAGE Could not install bundle plugins/org.apache.batik.transcoder_1.6.0.v200805290154.jar Bundle "org.apache.batik.transcoder" version "1.6.0.v200805290154" has already been installed from: reference:file:plugins/org.apache.batik.transcoder_1.6.0.v20 0805290154.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.493
!MESSAGE Could not install bundle plugins/org.apache.batik.util.gui_1.6.0.v200805290154.jar Bundle "org.apache.batik.util.gui" version "1.6.0.v200805290154" has already been installed from: reference:file:plugins/org.apache.batik.util.gui_1.6.0.v2008 05290154.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.494
!MESSAGE Could not install bundle plugins/org.apache.batik.util_1.6.0.v200805290154.jar Bundle "org.apache.batik.util" version "1.6.0.v200805290154" has already been installed from: reference:file:plugins/org.apache.batik.util_1.6.0.v20080529 0154.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.496
!MESSAGE Could not install bundle plugins/org.apache.batik.xml_1.6.0.v200805290154.jar Bundle "org.apache.batik.xml" version "1.6.0.v200805290154" has already been installed from: reference:file:plugins/org.apache.batik.xml_1.6.0.v200805290 154.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.499
!MESSAGE Could not install bundle plugins/org.apache.commons.el_1.0.0.v200806031608.jar Bundle "org.apache.commons.el" version "1.0.0.v200806031608" has already been installed from: reference:file:plugins/org.apache.commons.el_1.0.0.v20080603 1608.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.500
!MESSAGE Could not install bundle plugins/org.apache.commons.logging_1.0.4.v20080605-1930.jar Bundle "org.apache.commons.logging" version "1.0.4.v20080605-1930" has already been installed from: reference:file:plugins/org.apache.commons.logging_1.0.4.v200 80605-1930.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.506
!MESSAGE Could not install bundle plugins/org.apache.jasper_5.5.17.v200806031609.jar Bundle "org.apache.jasper" version "5.5.17.v200806031609" has already been installed from: reference:file:plugins/org.apache.jasper_5.5.17.v20080603160 9.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.509
!MESSAGE Could not install bundle plugins/org.apache.lucene.analysis_1.9.1.v20080530-1600.jar Bundle "org.apache.lucene.analysis" version "1.9.1.v20080530-1600" has already been installed from: reference:file:plugins/org.apache.lucene.analysis_1.9.1.v200 80530-1600.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.513
!MESSAGE Could not install bundle plugins/org.apache.lucene_1.9.1.v20080530-1600.jar Bundle "org.apache.lucene" version "1.9.1.v20080530-1600" has already been installed from: reference:file:plugins/org.apache.lucene_1.9.1.v20080530-160 0.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.517
!MESSAGE Could not install bundle plugins/org.apache.xerces_2.9.0.v200805270400.jar Bundle "org.apache.xerces" version "2.9.0.v200805270400" has already been installed from: reference:file:plugins/org.apache.xerces_2.9.0.v200805270400 .jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.518
!MESSAGE Could not install bundle plugins/org.apache.xml.resolver_1.2.0.v200806030312.jar Bundle "org.apache.xml.resolver" version "1.2.0.v200806030312" has already been installed from: reference:file:plugins/org.apache.xml.resolver_1.2.0.v200806 030312.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.522
!MESSAGE Could not install bundle plugins/org.apache.xml.serializer_2.7.1.v200806030322.jar Bundle "org.apache.xml.serializer" version "2.7.1.v200806030322" has already been installed from: reference:file:plugins/org.apache.xml.serializer_2.7.1.v2008 06030322.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.573
!MESSAGE Could not install bundle plugins/org.eclipse.compare_3.4.0.I20080604.jar Bundle "org.eclipse.compare" version "3.4.0.I20080604" has already been installed from: reference:file:plugins/org.eclipse.compare_3.4.0.I20080604.j ar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.574
!MESSAGE Could not install bundle plugins/org.eclipse.core.boot_3.1.100.v20080218.jar Bundle "org.eclipse.core.boot" version "3.1.100.v20080218" has already been installed from: reference:file:plugins/org.eclipse.core.boot_3.1.100.v200802 18.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.577
!MESSAGE Could not install bundle plugins/org.eclipse.core.commands_3.4.0.I20080509-2000.jar Bundle "org.eclipse.core.commands" version "3.4.0.I20080509-2000" has already been installed from: reference:file:plugins/org.eclipse.core.commands_3.4.0.I2008 0509-2000.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.580
!MESSAGE Could not install bundle plugins/org.eclipse.core.contenttype_3.3.0.v20080604-1400.ja r Bundle "org.eclipse.core.contenttype" version "3.3.0.v20080604-1400" has already been installed from: reference:file:plugins/org.eclipse.core.contenttype_3.3.0.v2 0080604-1400.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.583
!MESSAGE Could not install bundle plugins/org.eclipse.core.databinding.beans_1.1.0.I20080508-2 000a.jar Bundle "org.eclipse.core.databinding.beans" version "1.1.0.I20080508-2000a" has already been installed from: reference:file:plugins/org.eclipse.core.databinding.beans_1. 1.0.I20080508-2000a.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.593
!MESSAGE Could not install bundle plugins/org.eclipse.core.databinding_1.1.0.I20080527-2000.ja r Bundle "org.eclipse.core.databinding" version "1.1.0.I20080527-2000" has already been installed from: reference:file:plugins/org.eclipse.core.databinding_1.1.0.I2 0080527-2000.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.597
!MESSAGE Could not install bundle plugins/org.eclipse.core.expressions_3.4.0.v20080603-2000.ja r Bundle "org.eclipse.core.expressions" version "3.4.0.v20080603-2000" has already been installed from: reference:file:plugins/org.eclipse.core.expressions_3.4.0.v2 0080603-2000.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.601
!MESSAGE Could not install bundle plugins/org.eclipse.core.filebuffers_3.4.0.v20080603-2000.ja r Bundle "org.eclipse.core.filebuffers" version "3.4.0.v20080603-2000" has already been installed from: reference:file:plugins/org.eclipse.core.filebuffers_3.4.0.v2 0080603-2000.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.604
!MESSAGE Could not install bundle plugins/org.eclipse.core.filesystem.macosx_1.0.0.v20080604-1 400.jar Bundle "org.eclipse.core.filesystem.macosx" version "1.0.0.v20080604-1400" has already been installed from: reference:file:plugins/org.eclipse.core.filesystem.macosx_1. 0.0.v20080604-1400.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.607
!MESSAGE Could not install bundle plugins/org.eclipse.core.filesystem_1.2.0.v20080604-1400.jar Bundle "org.eclipse.core.filesystem" version "1.2.0.v20080604-1400" has already been installed from: reference:file:plugins/org.eclipse.core.filesystem_1.2.0.v20 080604-1400.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.610
!MESSAGE Could not install bundle plugins/org.eclipse.core.jobs_3.4.0.v20080512.jar Bundle "org.eclipse.core.jobs" version "3.4.0.v20080512" has already been installed from: reference:file:plugins/org.eclipse.core.jobs_3.4.0.v20080512 .jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.613
!MESSAGE Could not install bundle plugins/org.eclipse.core.net_1.1.0.I20080604.jar Bundle "org.eclipse.core.net" version "1.1.0.I20080604" has already been installed from: reference:file:plugins/org.eclipse.core.net_1.1.0.I20080604. jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.616
!MESSAGE Could not install bundle plugins/org.eclipse.core.resources.compatibility_3.4.0.v2008 0604-1400.jar Bundle "org.eclipse.core.resources.compatibility" version "3.4.0.v20080604-1400" has already been installed from: reference:file:plugins/org.eclipse.core.resources.compatibil ity_3.4.0.v20080604-1400.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.628
!MESSAGE Could not install bundle plugins/org.eclipse.core.resources_3.4.0.v20080604-1400.jar Bundle "org.eclipse.core.resources" version "3.4.0.v20080604-1400" has already been installed from: reference:file:plugins/org.eclipse.core.resources_3.4.0.v200 80604-1400.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.638
!MESSAGE Could not install bundle plugins/org.eclipse.core.variables_3.2.100.v20080529-1300.ja r Bundle "org.eclipse.core.variables" version "3.2.100.v20080529-1300" has already been installed from: reference:file:plugins/org.eclipse.core.variables_3.2.100.v2 0080529-1300.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.645
!MESSAGE Could not install bundle plugins/org.eclipse.debug.core_3.4.0.v20080612.jar Bundle "org.eclipse.debug.core" version "3.4.0.v20080612" has already been installed from: reference:file:plugins/org.eclipse.debug.core_3.4.0.v2008061 2.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.658
!MESSAGE Could not install bundle plugins/org.eclipse.debug.ui_3.4.0.v20080529-1300.jar Bundle "org.eclipse.debug.ui" version "3.4.0.v20080529-1300" has already been installed from: reference:file:plugins/org.eclipse.debug.ui_3.4.0.v20080529- 1300.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.664
!MESSAGE Could not install bundle plugins/org.eclipse.draw2d_3.4.0.v20080529.jar Bundle "org.eclipse.draw2d" version "3.4.0.v20080529" has already been installed from: reference:file:plugins/org.eclipse.draw2d_3.4.0.v20080529.ja r
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.666
!MESSAGE Could not install bundle plugins/org.eclipse.ecf.filetransfer_2.0.0.v20080611-1715.ja r Bundle "org.eclipse.ecf.filetransfer" version "2.0.0.v20080611-1715" has already been installed from: reference:file:plugins/org.eclipse.ecf.filetransfer_2.0.0.v2 0080611-1715.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.671
!MESSAGE Could not install bundle plugins/org.eclipse.ecf.identity_2.0.0.v20080611-1715.jar Bundle "org.eclipse.ecf.identity" version "2.0.0.v20080611-1715" has already been installed from: reference:file:plugins/org.eclipse.ecf.identity_2.0.0.v20080 611-1715.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.672
!MESSAGE Could not install bundle plugins/org.eclipse.ecf.provider.filetransfer.ssl_1.0.0.v200 80611-1715.jar Bundle "org.eclipse.ecf.provider.filetransfer.ssl" version "1.0.0.v20080611-1715" has already been installed from: reference:file:plugins/org.eclipse.ecf.provider.filetransfer .ssl_1.0.0.v20080611-1715.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.673
!MESSAGE Could not install bundle plugins/org.eclipse.ecf.provider.filetransfer_2.0.0.v2008061 1-1715.jar Bundle "org.eclipse.ecf.provider.filetransfer" version "2.0.0.v20080611-1715" has already been installed from: reference:file:plugins/org.eclipse.ecf.provider.filetransfer _2.0.0.v20080611-1715.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.674
!MESSAGE Could not install bundle plugins/org.eclipse.ecf.ssl_1.0.0.v20080611-1715.jar Bundle "org.eclipse.ecf.ssl" version "1.0.0.v20080611-1715" has already been installed from: reference:file:plugins/org.eclipse.ecf.ssl_1.0.0.v20080611-1 715.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.676
!MESSAGE Could not install bundle plugins/org.eclipse.ecf_2.0.0.v20080611-1715.jar Bundle "org.eclipse.ecf" version "2.0.0.v20080611-1715" has already been installed from: reference:file:plugins/org.eclipse.ecf_2.0.0.v20080611-1715. jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.688
!MESSAGE Could not install bundle plugins/org.eclipse.emf.common_2.4.0.v200806091234.jar Bundle "org.eclipse.emf.common" version "2.4.0.v200806091234" has already been installed from: reference:file:plugins/org.eclipse.emf.common_2.4.0.v2008060 91234.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.734
!MESSAGE Could not install bundle plugins/org.eclipse.emf.ecore.xmi_2.4.0.v200806091234.jar Bundle "org.eclipse.emf.ecore.xmi" version "2.4.0.v200806091234" has already been installed from: reference:file:plugins/org.eclipse.emf.ecore.xmi_2.4.0.v2008 06091234.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.738
!MESSAGE Could not install bundle plugins/org.eclipse.emf.ecore_2.4.0.v200806091234.jar Bundle "org.eclipse.emf.ecore" version "2.4.0.v200806091234" has already been installed from: reference:file:plugins/org.eclipse.emf.ecore_2.4.0.v20080609 1234.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.768
!MESSAGE Could not install bundle plugins/org.eclipse.equinox.app_1.1.0.v20080421-2006.jar Bundle "org.eclipse.equinox.app" version "1.1.0.v20080421-2006" has already been installed from: reference:file:plugins/org.eclipse.equinox.app_1.1.0.v200804 21-2006.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.771
!MESSAGE Could not install bundle plugins/org.eclipse.equinox.common_3.4.0.v20080421-2006.jar Bundle "org.eclipse.equinox.common" version "3.4.0.v20080421-2006" has already been installed from: reference:file:plugins/org.eclipse.equinox.common_3.4.0.v200 80421-2006.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.775
!MESSAGE Could not install bundle plugins/org.eclipse.equinox.frameworkadmin.equinox_1.0.0.v20 080529-1225.jar Bundle "org.eclipse.equinox.frameworkadmin.equinox" version "1.0.0.v20080529-1225" has already been installed from: reference:file:plugins/org.eclipse.equinox.frameworkadmin.eq uinox_1.0.0.v20080529-1225.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.780
!MESSAGE Could not install bundle plugins/org.eclipse.equinox.frameworkadmin_1.0.0.v20080430-1 750.jar Bundle "org.eclipse.equinox.frameworkadmin" version "1.0.0.v20080430-1750" has already been installed from: reference:file:plugins/org.eclipse.equinox.frameworkadmin_1. 0.0.v20080430-1750.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.782
!MESSAGE Could not install bundle plugins/org.eclipse.equinox.http.jetty_1.1.0.v20080425.jar Bundle "org.eclipse.equinox.http.jetty" version "1.1.0.v20080425" has already been installed from: reference:file:plugins/org.eclipse.equinox.http.jetty_1.1.0. v20080425.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.785
!MESSAGE Could not install bundle plugins/org.eclipse.equinox.http.registry_1.0.100.v20080427- 0830.jar Bundle "org.eclipse.equinox.http.registry" version "1.0.100.v20080427-0830" has already been installed from: reference:file:plugins/org.eclipse.equinox.http.registry_1.0 .100.v20080427-0830.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.789
!MESSAGE Could not install bundle plugins/org.eclipse.equinox.http.servlet_1.0.100.v20080427-0 830.jar Bundle "org.eclipse.equinox.http.servlet" version "1.0.100.v20080427-0830" has already been installed from: reference:file:plugins/org.eclipse.equinox.http.servlet_1.0. 100.v20080427-0830.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.791
!MESSAGE Could not install bundle plugins/org.eclipse.equinox.jsp.jasper.registry_1.0.0.v20080 427-0830.jar Bundle "org.eclipse.equinox.jsp.jasper.registry" version "1.0.0.v20080427-0830" has already been installed from: reference:file:plugins/org.eclipse.equinox.jsp.jasper.regist ry_1.0.0.v20080427-0830.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.792
!MESSAGE Could not install bundle plugins/org.eclipse.equinox.jsp.jasper_1.0.100.v20080427-083 0.jar Bundle "org.eclipse.equinox.jsp.jasper" version "1.0.100.v20080427-0830" has already been installed from: reference:file:plugins/org.eclipse.equinox.jsp.jasper_1.0.10 0.v20080427-0830.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.795
!MESSAGE Could not install bundle plugins/org.eclipse.equinox.launcher.carbon.macosx_1.0.100.v 20080509-1800/ Bundle "org.eclipse.equinox.launcher.carbon.macosx" version "1.0.100.v20080509-1800" has already been installed from: reference:file:plugins/org.eclipse.equinox.launcher.carbon.m acosx_1.0.100.v20080509-1800
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.806
!MESSAGE Could not install bundle plugins/org.eclipse.equinox.launcher_1.0.100.v20080509-1800. jar Bundle "org.eclipse.equinox.launcher" version "1.0.100.v20080509-1800" has already been installed from: reference:file:plugins/org.eclipse.equinox.launcher_1.0.100. v20080509-1800.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.811
!MESSAGE Could not install bundle plugins/org.eclipse.equinox.p2.artifact.repository_1.0.0.v20 080609-0850.jar Bundle "org.eclipse.equinox.p2.artifact.repository" version "1.0.0.v20080609-0850" has already been installed from: reference:file:plugins/org.eclipse.equinox.p2.artifact.repos itory_1.0.0.v20080609-0850.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.812
!MESSAGE Could not install bundle plugins/org.eclipse.equinox.p2.console_1.0.0.v20080514-1900. jar Bundle "org.eclipse.equinox.p2.console" version "1.0.0.v20080514-1900" has already been installed from: reference:file:plugins/org.eclipse.equinox.p2.console_1.0.0. v20080514-1900.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.815
!MESSAGE Could not install bundle plugins/org.eclipse.equinox.p2.core_1.0.0.v20080530-1237.jar Bundle "org.eclipse.equinox.p2.core" version "1.0.0.v20080530-1237" has already been installed from: reference:file:plugins/org.eclipse.equinox.p2.core_1.0.0.v20 080530-1237.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.816
!MESSAGE Could not install bundle plugins/org.eclipse.equinox.p2.director.app_1.0.0.v20080604. jar Bundle "org.eclipse.equinox.p2.director.app" version "1.0.0.v20080604" has already been installed from: reference:file:plugins/org.eclipse.equinox.p2.director.app_1 .0.0.v20080604.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.818
!MESSAGE Could not install bundle plugins/org.eclipse.equinox.p2.director_1.0.0.v20080604.jar Bundle "org.eclipse.equinox.p2.director" version "1.0.0.v20080604" has already been installed from: reference:file:plugins/org.eclipse.equinox.p2.director_1.0.0 .v20080604.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.821
!MESSAGE Could not install bundle plugins/org.eclipse.equinox.p2.directorywatcher_1.0.0.v20080 505-1850.jar Bundle "org.eclipse.equinox.p2.directorywatcher" version "1.0.0.v20080505-1850" has already been installed from: reference:file:plugins/org.eclipse.equinox.p2.directorywatch er_1.0.0.v20080505-1850.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.826
!MESSAGE Could not install bundle plugins/org.eclipse.equinox.p2.engine_1.0.0.v20080522-1735.j ar Bundle "org.eclipse.equinox.p2.engine" version "1.0.0.v20080522-1735" has already been installed from: reference:file:plugins/org.eclipse.equinox.p2.engine_1.0.0.v 20080522-1735.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.830
!MESSAGE Could not install bundle plugins/org.eclipse.equinox.p2.exemplarysetup_1.0.0.v2008042 7-2136.jar Bundle "org.eclipse.equinox.p2.exemplarysetup" version "1.0.0.v20080427-2136" has already been installed from: reference:file:plugins/org.eclipse.equinox.p2.exemplarysetup _1.0.0.v20080427-2136.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.832
!MESSAGE Could not install bundle plugins/org.eclipse.equinox.p2.extensionlocation_1.0.0.v2008 0523-0001.jar Bundle "org.eclipse.equinox.p2.extensionlocation" version "1.0.0.v20080523-0001" has already been installed from: reference:file:plugins/org.eclipse.equinox.p2.extensionlocat ion_1.0.0.v20080523-0001.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.833
!MESSAGE Could not install bundle plugins/org.eclipse.equinox.p2.garbagecollector_1.0.0.v20080 506-1939.jar Bundle "org.eclipse.equinox.p2.garbagecollector" version "1.0.0.v20080506-1939" has already been installed from: reference:file:plugins/org.eclipse.equinox.p2.garbagecollect or_1.0.0.v20080506-1939.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.834
!MESSAGE Could not install bundle plugins/org.eclipse.equinox.p2.jarprocessor_1.0.0.v20080514- 1900.jar Bundle "org.eclipse.equinox.p2.jarprocessor" version "1.0.0.v20080514-1900" has already been installed from: reference:file:plugins/org.eclipse.equinox.p2.jarprocessor_1 .0.0.v20080514-1900.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.839
!MESSAGE Could not install bundle plugins/org.eclipse.equinox.p2.metadata.generator_1.0.0.v200 80604.jar Bundle "org.eclipse.equinox.p2.metadata.generator" version "1.0.0.v20080604" has already been installed from: reference:file:plugins/org.eclipse.equinox.p2.metadata.gener ator_1.0.0.v20080604.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.842
!MESSAGE Could not install bundle plugins/org.eclipse.equinox.p2.metadata.repository_1.0.0.v20 080604.jar Bundle "org.eclipse.equinox.p2.metadata.repository" version "1.0.0.v20080604" has already been installed from: reference:file:plugins/org.eclipse.equinox.p2.metadata.repos itory_1.0.0.v20080604.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.845
!MESSAGE Could not install bundle plugins/org.eclipse.equinox.p2.metadata_1.0.0.v20080514-1900 .jar Bundle "org.eclipse.equinox.p2.metadata" version "1.0.0.v20080514-1900" has already been installed from: reference:file:plugins/org.eclipse.equinox.p2.metadata_1.0.0 .v20080514-1900.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.847
!MESSAGE Could not install bundle plugins/org.eclipse.equinox.p2.reconciler.dropins_1.0.0.v200 80611.jar Bundle "org.eclipse.equinox.p2.reconciler.dropins" version "1.0.0.v20080611" has already been installed from: reference:file:plugins/org.eclipse.equinox.p2.reconciler.dro pins_1.0.0.v20080611.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.849
!MESSAGE Could not install bundle plugins/org.eclipse.equinox.p2.touchpoint.eclipse_1.0.0.v200 80529-1225.jar Bundle "org.eclipse.equinox.p2.touchpoint.eclipse" version "1.0.0.v20080529-1225" has already been installed from: reference:file:plugins/org.eclipse.equinox.p2.touchpoint.ecl ipse_1.0.0.v20080529-1225.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.852
!MESSAGE Could not install bundle plugins/org.eclipse.equinox.p2.touchpoint.natives_1.0.0.v200 80505-1850.jar Bundle "org.eclipse.equinox.p2.touchpoint.natives" version "1.0.0.v20080505-1850" has already been installed from: reference:file:plugins/org.eclipse.equinox.p2.touchpoint.nat ives_1.0.0.v20080505-1850.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.854
!MESSAGE Could not install bundle plugins/org.eclipse.equinox.p2.ui.sdk_1.0.0.v20080605-1731.j ar Bundle "org.eclipse.equinox.p2.ui.sdk" version "1.0.0.v20080605-1731" has already been installed from: reference:file:plugins/org.eclipse.equinox.p2.ui.sdk_1.0.0.v 20080605-1731.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.859
!MESSAGE Could not install bundle plugins/org.eclipse.equinox.p2.ui_1.0.0.v20080530-1237.jar Bundle "org.eclipse.equinox.p2.ui" version "1.0.0.v20080530-1237" has already been installed from: reference:file:plugins/org.eclipse.equinox.p2.ui_1.0.0.v2008 0530-1237.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.862
!MESSAGE Could not install bundle plugins/org.eclipse.equinox.p2.updatechecker_1.0.0.v20080427 -2136.jar Bundle "org.eclipse.equinox.p2.updatechecker" version "1.0.0.v20080427-2136" has already been installed from: reference:file:plugins/org.eclipse.equinox.p2.updatechecker_ 1.0.0.v20080427-2136.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.864
!MESSAGE Could not install bundle plugins/org.eclipse.equinox.p2.updatesite_1.0.0.v20080529-18 00.jar Bundle "org.eclipse.equinox.p2.updatesite" version "1.0.0.v20080529-1800" has already been installed from: reference:file:plugins/org.eclipse.equinox.p2.updatesite_1.0 .0.v20080529-1800.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.866
!MESSAGE Could not install bundle plugins/org.eclipse.equinox.preferences_3.2.200.v20080421-20 06.jar Bundle "org.eclipse.equinox.preferences" version "3.2.200.v20080421-2006" has already been installed from: reference:file:plugins/org.eclipse.equinox.preferences_3.2.2 00.v20080421-2006.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.869
!MESSAGE Could not install bundle plugins/org.eclipse.equinox.registry_3.4.0.v20080516-0950.ja r Bundle "org.eclipse.equinox.registry" version "3.4.0.v20080516-0950" has already been installed from: reference:file:plugins/org.eclipse.equinox.registry_3.4.0.v2 0080516-0950.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.872
!MESSAGE Could not install bundle plugins/org.eclipse.equinox.security.macosx_1.0.0.v20080602- 2000.jar Bundle "org.eclipse.equinox.security.macosx" version "1.0.0.v20080602-2000" has already been installed from: reference:file:plugins/org.eclipse.equinox.security.macosx_1 .0.0.v20080602-2000.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.878
!MESSAGE Could not install bundle plugins/org.eclipse.equinox.security.ui_1.0.0.v20080603-1810 .jar Bundle "org.eclipse.equinox.security.ui" version "1.0.0.v20080603-1810" has already been installed from: reference:file:plugins/org.eclipse.equinox.security.ui_1.0.0 .v20080603-1810.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.883
!MESSAGE Could not install bundle plugins/org.eclipse.equinox.security_1.0.0.v20080512-1800.ja r Bundle "org.eclipse.equinox.security" version "1.0.0.v20080512-1800" has already been installed from: reference:file:plugins/org.eclipse.equinox.security_1.0.0.v2 0080512-1800.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.906
!MESSAGE Could not install bundle plugins/org.eclipse.gef_3.4.0.v20080526.jar Bundle "org.eclipse.gef" version "3.4.0.v20080526" has already been installed from: reference:file:plugins/org.eclipse.gef_3.4.0.v20080526.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.910
!MESSAGE Could not install bundle plugins/org.eclipse.gmf.runtime.common.core_1.1.0.v20080425- 1959.jar Bundle "org.eclipse.gmf.runtime.common.core" version "1.1.0.v20080425-1959" has already been installed from: reference:file:plugins/org.eclipse.gmf.runtime.common.core_1 .1.0.v20080425-1959.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.913
!MESSAGE Could not install bundle plugins/org.eclipse.gmf.runtime.common.ui_1.1.0.v20080512-12 00.jar Bundle "org.eclipse.gmf.runtime.common.ui" version "1.1.0.v20080512-1200" has already been installed from: reference:file:plugins/org.eclipse.gmf.runtime.common.ui_1.1 .0.v20080512-1200.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.916
!MESSAGE Could not install bundle plugins/org.eclipse.gmf.runtime.draw2d.ui.render.awt_1.1.0.v 20080603-1553.jar Bundle "org.eclipse.gmf.runtime.draw2d.ui.render.awt" version "1.1.0.v20080603-1553" has already been installed from: reference:file:plugins/org.eclipse.gmf.runtime.draw2d.ui.ren der.awt_1.1.0.v20080603-1553.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.919
!MESSAGE Could not install bundle plugins/org.eclipse.gmf.runtime.draw2d.ui.render_1.1.0.v2008 0507-2230.jar Bundle "org.eclipse.gmf.runtime.draw2d.ui.render" version "1.1.0.v20080507-2230" has already been installed from: reference:file:plugins/org.eclipse.gmf.runtime.draw2d.ui.ren der_1.1.0.v20080507-2230.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.922
!MESSAGE Could not install bundle plugins/org.eclipse.gmf.runtime.draw2d.ui_1.1.0.v20080610-11 32.jar Bundle "org.eclipse.gmf.runtime.draw2d.ui" version "1.1.0.v20080610-1132" has already been installed from: reference:file:plugins/org.eclipse.gmf.runtime.draw2d.ui_1.1 .0.v20080610-1132.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.924
!MESSAGE Could not install bundle plugins/org.eclipse.help.appserver_3.1.300.v20080507.jar Bundle "org.eclipse.help.appserver" version "3.1.300.v20080507" has already been installed from: reference:file:plugins/org.eclipse.help.appserver_3.1.300.v2 0080507.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.928
!MESSAGE Could not install bundle plugins/org.eclipse.help.base_3.3.100.v20080617.jar Bundle "org.eclipse.help.base" version "3.3.100.v20080617" has already been installed from: reference:file:plugins/org.eclipse.help.base_3.3.100.v200806 17.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.934
!MESSAGE Could not install bundle plugins/org.eclipse.help.ui_3.3.100.v20080521.jar Bundle "org.eclipse.help.ui" version "3.3.100.v20080521" has already been installed from: reference:file:plugins/org.eclipse.help.ui_3.3.100.v20080521 .jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.937
!MESSAGE Could not install bundle plugins/org.eclipse.help.webapp_3.3.100.v20080528.jar Bundle "org.eclipse.help.webapp" version "3.3.100.v20080528" has already been installed from: reference:file:plugins/org.eclipse.help.webapp_3.3.100.v2008 0528.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:55.938
!MESSAGE Could not install bundle plugins/org.eclipse.help_3.3.100.v20080610.jar Bundle "org.eclipse.help" version "3.3.100.v20080610" has already been installed from: reference:file:plugins/org.eclipse.help_3.3.100.v20080610.ja r
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:56.083
!MESSAGE Could not install bundle plugins/org.eclipse.jem.util_2.0.100.v200805140020.jar Bundle "org.eclipse.jem.util" version "2.0.100.v200805140020" has already been installed from: reference:file:plugins/org.eclipse.jem.util_2.0.100.v2008051 40020.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:56.087
!MESSAGE Could not install bundle plugins/org.eclipse.jface.databinding_1.2.0.I20080515-2000a. jar Bundle "org.eclipse.jface.databinding" version "1.2.0.I20080515-2000a" has already been installed from: reference:file:plugins/org.eclipse.jface.databinding_1.2.0.I 20080515-2000a.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:56.099
!MESSAGE Could not install bundle plugins/org.eclipse.jface.text_3.4.0.v20080603-2000.jar Bundle "org.eclipse.jface.text" version "3.4.0.v20080603-2000" has already been installed from: reference:file:plugins/org.eclipse.jface.text_3.4.0.v2008060 3-2000.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:56.103
!MESSAGE Could not install bundle plugins/org.eclipse.jface_3.4.0.I20080606-1300.jar Bundle "org.eclipse.jface" version "3.4.0.I20080606-1300" has already been installed from: reference:file:plugins/org.eclipse.jface_3.4.0.I20080606-130 0.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:56.107
!MESSAGE Could not install bundle plugins/org.eclipse.jsch.core_1.1.100.I20080604.jar Bundle "org.eclipse.jsch.core" version "1.1.100.I20080604" has already been installed from: reference:file:plugins/org.eclipse.jsch.core_1.1.100.I200806 04.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:56.112
!MESSAGE Could not install bundle plugins/org.eclipse.jsch.ui_1.1.100.I20080415.jar Bundle "org.eclipse.jsch.ui" version "1.1.100.I20080415" has already been installed from: reference:file:plugins/org.eclipse.jsch.ui_1.1.100.I20080415 .jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:56.153
!MESSAGE Could not install bundle plugins/org.eclipse.ltk.core.refactoring_3.4.0.v20080603-200 0.jar Bundle "org.eclipse.ltk.core.refactoring" version "3.4.0.v20080603-2000" has already been installed from: reference:file:plugins/org.eclipse.ltk.core.refactoring_3.4. 0.v20080603-2000.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:56.160
!MESSAGE Could not install bundle plugins/org.eclipse.ltk.ui.refactoring_3.4.0.v20080605-1800. jar Bundle "org.eclipse.ltk.ui.refactoring" version "3.4.0.v20080605-1800" has already been installed from: reference:file:plugins/org.eclipse.ltk.ui.refactoring_3.4.0. v20080605-1800.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:56.287
!MESSAGE Could not install bundle plugins/org.eclipse.platform.doc.user_3.4.0.v20080612-1340.j ar Bundle "org.eclipse.platform.doc.user" version "3.4.0.v20080612-1340" has already been installed from: reference:file:plugins/org.eclipse.platform.doc.user_3.4.0.v 20080612-1340.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:56.289
!MESSAGE Could not install bundle plugins/org.eclipse.platform_3.3.100.v200806172000/ Bundle "org.eclipse.platform" version "3.3.100.v200806172000" has already been installed from: reference:file:plugins/org.eclipse.platform_3.3.100.v2008061 72000
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:56.290
!MESSAGE Could not install bundle plugins/org.eclipse.rcp_3.4.0.v20080507.jar Bundle "org.eclipse.rcp" version "3.4.0.v20080507" has already been installed from: reference:file:plugins/org.eclipse.rcp_3.4.0.v20080507.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:56.302
!MESSAGE Could not install bundle plugins/org.eclipse.search_3.4.0.v20080603-2000.jar Bundle "org.eclipse.search" version "3.4.0.v20080603-2000" has already been installed from: reference:file:plugins/org.eclipse.search_3.4.0.v20080603-20 00.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:56.310
!MESSAGE Could not install bundle plugins/org.eclipse.swt.carbon.macosx_3.4.0.v3448f.jar Bundle "org.eclipse.swt.carbon.macosx" version "3.4.0.v3448f" has already been installed from: reference:file:plugins/org.eclipse.swt.carbon.macosx_3.4.0.v 3448f.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:56.393
!MESSAGE Could not install bundle plugins/org.eclipse.swt_3.4.0.v3448f.jar Bundle "org.eclipse.swt" version "3.4.0.v3448f" has already been installed from: reference:file:plugins/org.eclipse.swt_3.4.0.v3448f.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:56.398
!MESSAGE Could not install bundle plugins/org.eclipse.team.core_3.4.0.I20080605.jar Bundle "org.eclipse.team.core" version "3.4.0.I20080605" has already been installed from: reference:file:plugins/org.eclipse.team.core_3.4.0.I20080605 .jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:56.429
!MESSAGE Could not install bundle plugins/org.eclipse.team.ui_3.4.0.I20080604.jar Bundle "org.eclipse.team.ui" version "3.4.0.I20080604" has already been installed from: reference:file:plugins/org.eclipse.team.ui_3.4.0.I20080604.j ar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:56.436
!MESSAGE Could not install bundle plugins/org.eclipse.text_3.4.0.v20080605-1800.jar Bundle "org.eclipse.text" version "3.4.0.v20080605-1800" has already been installed from: reference:file:plugins/org.eclipse.text_3.4.0.v20080605-1800 .jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:56.440
!MESSAGE Could not install bundle plugins/org.eclipse.ui.browser_3.2.200.v20080507.jar Bundle "org.eclipse.ui.browser" version "3.2.200.v20080507" has already been installed from: reference:file:plugins/org.eclipse.ui.browser_3.2.200.v20080 507.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:56.444
!MESSAGE Could not install bundle plugins/org.eclipse.ui.carbon_4.0.0.I20080610-1200.jar Bundle "org.eclipse.ui.carbon" version "4.0.0.I20080610-1200" has already been installed from: reference:file:plugins/org.eclipse.ui.carbon_4.0.0.I20080610 -1200.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:56.449
!MESSAGE Could not install bundle plugins/org.eclipse.ui.cheatsheets_3.3.100.v20080508.jar Bundle "org.eclipse.ui.cheatsheets" version "3.3.100.v20080508" has already been installed from: reference:file:plugins/org.eclipse.ui.cheatsheets_3.3.100.v2 0080508.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:56.452
!MESSAGE Could not install bundle plugins/org.eclipse.ui.console_3.3.0.v20080529-1300.jar Bundle "org.eclipse.ui.console" version "3.3.0.v20080529-1300" has already been installed from: reference:file:plugins/org.eclipse.ui.console_3.3.0.v2008052 9-1300.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:56.457
!MESSAGE Could not install bundle plugins/org.eclipse.ui.editors_3.4.0.v20080603-2000.jar Bundle "org.eclipse.ui.editors" version "3.4.0.v20080603-2000" has already been installed from: reference:file:plugins/org.eclipse.ui.editors_3.4.0.v2008060 3-2000.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:56.466
!MESSAGE Could not install bundle plugins/org.eclipse.ui.externaltools_3.2.0.v20080514-1542.ja r Bundle "org.eclipse.ui.externaltools" version "3.2.0.v20080514-1542" has already been installed from: reference:file:plugins/org.eclipse.ui.externaltools_3.2.0.v2 0080514-1542.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:56.469
!MESSAGE Could not install bundle plugins/org.eclipse.ui.forms_3.3.100.v20080611.jar Bundle "org.eclipse.ui.forms" version "3.3.100.v20080611" has already been installed from: reference:file:plugins/org.eclipse.ui.forms_3.3.100.v2008061 1.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:56.471
!MESSAGE Could not install bundle plugins/org.eclipse.ui.ide.application_1.0.0.I20080603-2000. jar Bundle "org.eclipse.ui.ide.application" version "1.0.0.I20080603-2000" has already been installed from: reference:file:plugins/org.eclipse.ui.ide.application_1.0.0. I20080603-2000.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:56.481
!MESSAGE Could not install bundle plugins/org.eclipse.ui.ide_3.4.0.I20080606-1300.jar Bundle "org.eclipse.ui.ide" version "3.4.0.I20080606-1300" has already been installed from: reference:file:plugins/org.eclipse.ui.ide_3.4.0.I20080606-13 00.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:56.486
!MESSAGE Could not install bundle plugins/org.eclipse.ui.intro.universal_3.2.200.v20080508/ Bundle "org.eclipse.ui.intro.universal" version "3.2.200.v20080508" has already been installed from: reference:file:plugins/org.eclipse.ui.intro.universal_3.2.20 0.v20080508
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:56.488
!MESSAGE Could not install bundle plugins/org.eclipse.ui.intro_3.2.200.v20080610.jar Bundle "org.eclipse.ui.intro" version "3.2.200.v20080610" has already been installed from: reference:file:plugins/org.eclipse.ui.intro_3.2.200.v2008061 0.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:56.496
!MESSAGE Could not install bundle plugins/org.eclipse.ui.navigator.resources_3.3.100.I20080606 -1300.jar Bundle "org.eclipse.ui.navigator.resources" version "3.3.100.I20080606-1300" has already been installed from: reference:file:plugins/org.eclipse.ui.navigator.resources_3. 3.100.I20080606-1300.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:56.500
!MESSAGE Could not install bundle plugins/org.eclipse.ui.navigator_3.3.100.I20080606-1300.jar Bundle "org.eclipse.ui.navigator" version "3.3.100.I20080606-1300" has already been installed from: reference:file:plugins/org.eclipse.ui.navigator_3.3.100.I200 80606-1300.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:56.502
!MESSAGE Could not install bundle plugins/org.eclipse.ui.net_1.0.0.I20080605.jar Bundle "org.eclipse.ui.net" version "1.0.0.I20080605" has already been installed from: reference:file:plugins/org.eclipse.ui.net_1.0.0.I20080605.ja r
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:56.506
!MESSAGE Could not install bundle plugins/org.eclipse.ui.presentations.r21_3.2.100.I20080512-2 000.jar Bundle "org.eclipse.ui.presentations.r21" version "3.2.100.I20080512-2000" has already been installed from: reference:file:plugins/org.eclipse.ui.presentations.r21_3.2. 100.I20080512-2000.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:56.514
!MESSAGE Could not install bundle plugins/org.eclipse.ui.views.properties.tabbed_3.4.0.I200805 27-2000.jar Bundle "org.eclipse.ui.views.properties.tabbed" version "3.4.0.I20080527-2000" has already been installed from: reference:file:plugins/org.eclipse.ui.views.properties.tabbe d_3.4.0.I20080527-2000.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:56.516
!MESSAGE Could not install bundle plugins/org.eclipse.ui.views_3.3.0.I20080509-2000.jar Bundle "org.eclipse.ui.views" version "3.3.0.I20080509-2000" has already been installed from: reference:file:plugins/org.eclipse.ui.views_3.3.0.I20080509- 2000.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:56.519
!MESSAGE Could not install bundle plugins/org.eclipse.ui.workbench.compatibility_3.2.0.I200805 09-2000/ Bundle "org.eclipse.ui.workbench.compatibility" version "3.2.0.I20080509-2000" has already been installed from: reference:file:plugins/org.eclipse.ui.workbench.compatibilit y_3.2.0.I20080509-2000
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:56.531
!MESSAGE Could not install bundle plugins/org.eclipse.ui.workbench.texteditor_3.4.0.v20080603- 2000.jar Bundle "org.eclipse.ui.workbench.texteditor" version "3.4.0.v20080603-2000" has already been installed from: reference:file:plugins/org.eclipse.ui.workbench.texteditor_3 .4.0.v20080603-2000.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:56.543
!MESSAGE Could not install bundle plugins/org.eclipse.ui.workbench_3.4.0.I20080606-1300.jar Bundle "org.eclipse.ui.workbench" version "3.4.0.I20080606-1300" has already been installed from: reference:file:plugins/org.eclipse.ui.workbench_3.4.0.I20080 606-1300.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:56.545
!MESSAGE Could not install bundle plugins/org.eclipse.ui_3.4.0.I20080610-1200.jar Bundle "org.eclipse.ui" version "3.4.0.I20080610-1200" has already been installed from: reference:file:plugins/org.eclipse.ui_3.4.0.I20080610-1200.j ar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:56.548
!MESSAGE Could not install bundle plugins/org.eclipse.update.configurator_3.2.200.v20080417.ja r Bundle "org.eclipse.update.configurator" version "3.2.200.v20080417" has already been installed from: reference:file:plugins/org.eclipse.update.configurator_3.2.2 00.v20080417.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:56.557
!MESSAGE Could not install bundle plugins/org.eclipse.update.core_3.2.200.v20080515.jar Bundle "org.eclipse.update.core" version "3.2.200.v20080515" has already been installed from: reference:file:plugins/org.eclipse.update.core_3.2.200.v2008 0515.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:56.562
!MESSAGE Could not install bundle plugins/org.eclipse.update.scheduler_3.2.100.v20080404.jar Bundle "org.eclipse.update.scheduler" version "3.2.100.v20080404" has already been installed from: reference:file:plugins/org.eclipse.update.scheduler_3.2.100. v20080404.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:56.566
!MESSAGE Could not install bundle plugins/org.eclipse.update.ui_3.2.100.v20080318.jar Bundle "org.eclipse.update.ui" version "3.2.100.v20080318" has already been installed from: reference:file:plugins/org.eclipse.update.ui_3.2.100.v200803 18.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:56.567
!MESSAGE Could not install bundle plugins/org.eclipse.wst.command.env.core_1.0.204.v2008051400 20.jar Bundle "org.eclipse.wst.command.env.core" version "1.0.204.v200805140020" has already been installed from: reference:file:plugins/org.eclipse.wst.command.env.core_1.0. 204.v200805140020.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:56.569
!MESSAGE Could not install bundle plugins/org.eclipse.wst.command.env.infopop_1.0.100.v2008053 01544.jar Bundle "org.eclipse.wst.command.env.infopop" version "1.0.100.v200805301544" has already been installed from: reference:file:plugins/org.eclipse.wst.command.env.infopop_1 .0.100.v200805301544.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:56.571
!MESSAGE Could not install bundle plugins/org.eclipse.wst.command.env.ui_1.1.0.v200805140415.j ar Bundle "org.eclipse.wst.command.env.ui" version "1.1.0.v200805140415" has already been installed from: reference:file:plugins/org.eclipse.wst.command.env.ui_1.1.0. v200805140415.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:56.572
!MESSAGE Could not install bundle plugins/org.eclipse.wst.command.env_1.0.305.v200805281530/ Bundle "org.eclipse.wst.command.env" version "1.0.305.v200805281530" has already been installed from: reference:file:plugins/org.eclipse.wst.command.env_1.0.305.v 200805281530
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:56.577
!MESSAGE Could not install bundle plugins/org.eclipse.wst.common.core_1.1.201.v200806010600.ja r Bundle "org.eclipse.wst.common.core" version "1.1.201.v200806010600" has already been installed from: reference:file:plugins/org.eclipse.wst.common.core_1.1.201.v 200806010600.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:56.580
!MESSAGE Could not install bundle plugins/org.eclipse.wst.common.emf_1.1.200.v200805140020.jar Bundle "org.eclipse.wst.common.emf" version "1.1.200.v200805140020" has already been installed from: reference:file:plugins/org.eclipse.wst.common.emf_1.1.200.v2 00805140020.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:56.583
!MESSAGE Could not install bundle plugins/org.eclipse.wst.common.emfworkbench.integration_1.1. 200.v200805140020.jar Bundle "org.eclipse.wst.common.emfworkbench.integration" version "1.1.200.v200805140020" has already been installed from: reference:file:plugins/org.eclipse.wst.common.emfworkbench.i ntegration_1.1.200.v200805140020.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:56.585
!MESSAGE Could not install bundle plugins/org.eclipse.wst.common.environment_1.0.201.v20080514 0020.jar Bundle "org.eclipse.wst.common.environment" version "1.0.201.v200805140020" has already been installed from: reference:file:plugins/org.eclipse.wst.common.environment_1. 0.201.v200805140020.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:56.587
!MESSAGE Could not install bundle plugins/org.eclipse.wst.common.frameworks.ui_1.1.200.v200805 221400.jar Bundle "org.eclipse.wst.common.frameworks.ui" version "1.1.200.v200805221400" has already been installed from: reference:file:plugins/org.eclipse.wst.common.frameworks.ui_ 1.1.200.v200805221400.jar
!ENTRY org.eclipse.update.configurator 4 0 2008-08-11 16:44:56.588
!MESSAGE Could not install bundle plugins/org.eclipse.wst.common.frameworks_1.1.200.v200805140 020.jar Bundle "org.eclipse.wst.common.frameworks" version "1.1.200.v200805140020" has already been installed from: reference:file:plugins/org.eclipse.wst.common.frameworks_1.1 .200.v200805140020.jar
!ENTRY org.e
FUDForum. Page generated in 0.06622 seconds
