Home » Eclipse Projects » Eclipse Platform » Packaging rcp application
Packaging rcp application [message #330719] Mon, 11 August 2008 16:57 Go to next message
Originally posted by: prasad.chand.gmail.com
My requirement is to package an eclipse rcp plugin with the eclipse rcp
framework itself (meaning with the eclipse application). It should be a
single or a set of files that must be capable of installing both the
eclipse application as well as the plugin (in multiple environments -
windows,mac,linux). Can anyone please give me pointers or suggestions on
how I can accomplish this?
Thanks in advance,
Prasad
p.s. The target machines have ant capabilities, so can I use ant scripts
to achieve this?
Re: Packaging rcp application [message #330971 is a reply to message #330719] Tue, 19 August 2008 17:07 Go to previous message
you need to create an eclipse product (file -> new -> other -> Plug-in
dev-> Product config), which should contain all your plugins.
-Jeevan
Previous Topic:Problem with IDE.openEditor(URI): cannot open external file in UTF8
Next Topic:[CVS] thank you so much
Current Time: Fri Jul 18 17:32:59 EDT 2025
Powered by FUDForum. Page generated in 0.24689 seconds
