Home » Eclipse Projects » Eclipse Platform » Perspective bar programmatically
Perspective bar programmatically [message #330715] Mon, 11 August 2008 15:22 Go to next message
There is a way to control the perspective bar programmatically?
I saw some options from the config.ini, but just that.
Thanks.
Marcelo
Re: Perspective bar programmatically [message #330747 is a reply to message #330715] Tue, 12 August 2008 10:22 Go to previous messageGo to next message
No hints?
"Marcelo Alcantara" <marcelo.alcantara@cshg.com.br> escreveu na mensagem
news:g7q3i9$qlu$1@build.eclipse.org...
> Thanks.
> Marcelo
Re: Perspective bar programmatically [message #331170 is a reply to message #330747] Wed, 27 August 2008 10:22 Go to previous messageGo to next message
As I could see, the Perspective bar control is very limited.
I decided then, to not use the Perspective bar and use the CoolBar which
gives me more code control.
If somebody has any ideas.
Actually, we are doing using eclipse for our main application platform with
many apps loaded on the workbench as plugins. For the first version, the
idea would be to have one perspective per application.
Marcelo
news:g7s6b0$4bo$1@build.eclipse.org...
> No hints?
>> Thanks.
>> Marcelo
Re: Perspective bar programmatically [message #331216 is a reply to message #331170] Thu, 28 August 2008 09:27 Go to previous message
The perspective bar is solely managed through internals, like the
PerspectiveBarManager. It is possible to create your own toolbar in the
main coolbar in an RCP app that represents the open perspectives. You
could then manage them as you want if the PerspectiveBarManager doesn't
do what you want.
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Previous Topic:How can I use inplace editing on singleclick and open a dialog on doubleclick ?
Next Topic:How to programmatically invoke Save All command?
Current Time: Thu Jul 17 02:56:46 EDT 2025
Powered by FUDForum. Page generated in 0.08901 seconds
