Home » Eclipse Projects » Eclipse Platform » is org.eclipse.core.internal.dtree.DeltaDataTree leeking memory?
is org.eclipse.core.internal.dtree.DeltaDataTree leeking memory? [message #330663] Thu, 07 August 2008 13:31
I'm using Ganymede right now and noticed that the memory consumption of
my plug-in was growing constantly.
Using the Eclipse Memory Analyzer I found that the class at fault is
org.eclipse.core.internal.dtree.DeltaDataTree (or me doing something wrong).
Basically what I'm doing is just two steps long (done in a loop):
- first I delete a bunch of markers using the IResource#deleteMarkers
function on project level with DEPTH_INFINITE to let it clear all
markers of a type.
- than after some logic I add a lot of markers to several files in the
same project.
This process should not use more memory than actually needed for the
markers (as in the second run of the loop I'm deleting all markers).
Right now I'm a bit puzzled as on the graphical interface the markers
disappear. If I'm searching for the markers with the findMarkers
function it is always finding exactly the same ammount of markers (which
is actually what I expected).
But still the memory consumption continuously grows, with instances of
the DeltaDataTree retaining more and more memory.
Am I doing something wrong, or is this memory leak really existing?
I know it would be more efficient to just modify the markers, but that
is not an option right now.
Previous Topic:Common Navigator Framework: Link with Editor
Next Topic:Writing file to .eclipse (Unix) or Application Data (Win32)
Current Time: Sun Aug 31 09:49:24 EDT 2025
Powered by FUDForum. Page generated in 0.02530 seconds
