Home » Eclipse Projects » Eclipse Platform » Re: Ganymede hangs at loading workbench
Re: Ganymede hangs at loading workbench [message #330613] |
Tue, 05 August 2008 11:50  |
Moving this to eclipse.platform, as it does not seem to be SWT-related.
Alex Milanovic wrote:
> Hello,
> I am using Ganymede with plugins for Maven, Mylyn, and Subversion on
> Linux Fedora 8. Ganymede has hung in the past (e.g. upon opening any
> file - the problem went away on its own after several hours), but now it
> does not pass the splash screen stage. I switched from JDK 1.5 to JDK
> 1.6 but that didn't change anything. I've also updated GTK-related
> packages to no avail as well. Eclipse does start up successfully when I
> point it to a different workspace (smaller in size). The problematic
> workspace should be in a good state though because it worked fine with
> Eclipse a few days ago when I used it the last time. Below I pasted the
> content of the log file content followed by the JVM dump (after sending
> it a Quit signal). The messages in the log used to appear even when
> Eclipse did not hang.
> Any idea what this is and how to fix it?
> Alex
> !SESSION 2008-08-05 16:43:35.939
> eclipse.buildId=I20080617-2000
> java.version=1.6.0_07
> java.vendor=Sun Microsystems Inc.
> BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
> Command-line arguments: -os linux -ws gtk -arch x86
> !ENTRY org.eclipse.ui 2 0 2008-08-05 16:43:37.991
> !MESSAGE Warnings while parsing the key bindings from the
> 'org.eclipse.ui.commands' extension point
> !SUBENTRY 1 org.eclipse.ui 2 0 2008-08-05 16:43:37.991
> !MESSAGE Cannot bind to an undefined command:
> plug-in='org.eclipse.tm.terminal', id='org.eclipse.tm.terminal.command1'
> Starting application: 956
> Application Started: 6443
> Start VM: -Dosgi.requiredJavaVersion=1.6
> -Xms256m
> -Xmx1024m
> -XX:PermSize=256m
> -XX:MaxPermSize=1024m
> -Djava.library.path=/usr/local/lib
> -Djava.class.path=/usr/share/eclipse/plugins/org.eclipse.equ inox.launcher_1.0.100.v20080509-1800.jar
> -os linux
> -ws gtk
> -arch x86
> -showsplash
> /usr/share/eclipse//plugins/org.eclipse.platform_3.3.100.v20 0806172000/splash.bmp
> -launcher /usr/share/eclipse/eclipse
> -name Eclipse
> --launcher.library
> /usr/share/eclipse/plugins/org.eclipse.equinox.launcher.gtk. linux.x86_1.0.100.v20080606/eclipse_1114b.so
> -startup
> /usr/share/eclipse/plugins/org.eclipse.equinox.launcher_1.0. 100.v20080509-1800.jar
> -framework plugins/org.eclipse.osgi_3.4.0.v20080605-1900.jar
> -debug
> -data /home/alex/workspace
> -vm /usr/java/jdk1.6.0_07/jre/lib/i386/client/libjvm.so
> -vmargs
> -Xms256m
> -Xmx1024m
> -XX:PermSize=256m
> Install location:
> file:/usr/share/eclipse/
> Configuration file:
> file:/usr/share/eclipse/configuration/config.ini loaded
> Configuration location:
> Framework located:
> file:/usr/share/eclipse/plugins/org.eclipse.osgi_3.4.0.v2008 0605-1900.jar
> Framework classpath:
> Splash location:
> Debug options:
> file:/home/alex/workspace/.options not found
> Time to load bundles: 8
> Starting application: 945
> 2008-08-05 16:56:32
> Full thread dump Java HotSpot(TM) Client VM (10.0-b23 mixed mode, sharing):
> "Worker-1" prio=10 tid=0x08b35800 nid=0x1b56 in Object.wait()
> java.lang.Thread.State: TIMED_WAITING (on object monitor)
> at java.lang.Object.wait(Native Method)
> - waiting on <0x19404af0> (a
> org.eclipse.core.internal.jobs.WorkerPool)
> at
> org.eclipse.core.internal.jobs.WorkerPool.sleep(WorkerPool.j ava:185)
> - locked <0x19404af0> (a org.eclipse.core.internal.jobs.WorkerPool)
> at
> org.eclipse.core.internal.jobs.WorkerPool.startJob(WorkerPoo l.java:217)
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:51)
> "Thread-2" prio=10 tid=0xb7971400 nid=0x1b55 in Object.wait()
> java.lang.Thread.State: WAITING (on object monitor)
> - waiting on <0x15430690> (a org.eclipse.swt.widgets.RunnableLock)
> at java.lang.Object.wait(Object.java:485)
> at
> org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.j ava:185)
> - locked <0x15430690> (a org.eclipse.swt.widgets.RunnableLock)
> at
> org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchroniz er.java:150)
> at org.eclipse.swt.widgets.Display.syncExec(Display.java:4021)
> at
> org.eclipse.ui.internal.StartupThreading.runWithThrowable(St artupThreading.java:85)
> at
> org.eclipse.ui.internal.EditorManager.restoreState(EditorMan ager.java:938)
> at
> org.eclipse.ui.internal.WorkbenchPage.restoreState(Workbench Page.java:3131)
> at
> org.eclipse.ui.internal.WorkbenchWindow.restoreState(Workben chWindow.java:2102)
> at
> org.eclipse.ui.internal.Workbench.doRestoreState(Workbench.j ava:3357)
> at org.eclipse.ui.internal.Workbench.access$30(Workbench.java:3 299)
> at org.eclipse.ui.internal.Workbench$53.run(Workbench.java:2091 )
> at
> org.eclipse.ui.internal.Workbench.runStartupWithProgress(Wor kbench.java:1804)
> at
> org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:2089)
> at org.eclipse.ui.internal.Workbench.access$28(Workbench.java:2 060)
> at org.eclipse.ui.internal.Workbench$48.run(Workbench.java:1923 )
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
> at
> org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1867)
> at
> org.eclipse.ui.internal.WorkbenchConfigurer.restoreState(Wor kbenchConfigurer.java:183)
> at
> org.eclipse.ui.application.WorkbenchAdvisor$1.run(WorkbenchA dvisor.java:781)
> "Thread-1" prio=10 tid=0x0869ac00 nid=0x1b53 in Object.wait()
> - waiting on <0x198dafe0> (a org.eclipse.swt.widgets.RunnableLock)
> at
> - locked <0x198dafe0> (a org.eclipse.swt.widgets.RunnableLock)
> at
> at
> org.eclipse.ui.internal.StartupThreading.runWithoutException s(StartupThreading.java:94)
> at org.eclipse.ui.internal.Workbench.init(Workbench.java:1356)
> at org.eclipse.ui.internal.Workbench.access$32(Workbench.java:1 278)
> at org.eclipse.ui.internal.Workbench$57.run(Workbench.java:2281 )
> "Worker-0" prio=10 tid=0x08536000 nid=0x1b52 in Object.wait()
> at
> at
> "Start Level Event Dispatcher" daemon prio=10 tid=0x0835b000 nid=0x1b51
> in Object.wait()
> - waiting on <0x191738e8> (a
> org.eclipse.osgi.framework.eventmgr.EventManager$EventThread )
> at
> org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .getNextEvent(EventManager.java:377)
> - locked <0x191738e8> (a
> at
> org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:317)
> "Framework Event Dispatcher" daemon prio=10 tid=0x08376800 nid=0x1b50 in
> Object.wait()
> - waiting on <0x19173960> (a
> at
> - locked <0x19173960> (a
> at
> "State Data Manager" daemon prio=10 tid=0x08389800 nid=0x1b4f waiting on
> condition
> java.lang.Thread.State: TIMED_WAITING (sleeping)
> at java.lang.Thread.sleep(Native Method)
> at
> org.eclipse.osgi.internal.baseadaptor.StateManager.run(State Manager.java:297)
> at java.lang.Thread.run(Thread.java:619)
> "Low Memory Detector" daemon prio=10 tid=0x08132c00 nid=0x1b4d runnable
> java.lang.Thread.State: RUNNABLE
> "CompilerThread0" daemon prio=10 tid=0x08128000 nid=0x1b4c waiting on
> condition
> "Signal Dispatcher" daemon prio=10 tid=0x08126c00 nid=0x1b4b waiting on
> condition
> "Finalizer" daemon prio=10 tid=0x08122400 nid=0x1b4a in Object.wait()
> - waiting on <0x19173c28> (a java.lang.ref.ReferenceQueue$Lock)
> at java.lang.ref.ReferenceQueue.remove(ReferenceQueue.java:116)
> - locked <0x19173c28> (a java.lang.ref.ReferenceQueue$Lock)
> at java.lang.ref.ReferenceQueue.remove(ReferenceQueue.java:132)
> at java.lang.ref.Finalizer$FinalizerThread.run(Finalizer.java:1 59)
> "Reference Handler" daemon prio=10 tid=0x0811dc00 nid=0x1b49 in
> Object.wait()
> - waiting on <0x19173898> (a java.lang.ref.Reference$Lock)
> at java.lang.ref.Reference$ReferenceHandler.run(Reference.java: 116)
> - locked <0x19173898> (a java.lang.ref.Reference$Lock)
> "main" prio=10 tid=0x080f6000 nid=0x1b02 runnable [0xbfe55000..0xbfe56448]
> at
> org.eclipse.swt.internal.gtk.OS._gtk_enumerate_printers(Nati ve Method)
> at
> org.eclipse.swt.internal.gtk.OS.gtk_enumerate_printers(OS.ja va:6459)
> at org.eclipse.swt.printing.Printer.getPrinterList(Printer.java :88)
> at
> org.eclipse.jface.text.TextViewer.isPrintable(TextViewer.jav a:4160)
> at
> org.eclipse.jface.text.TextViewer.canDoOperation(TextViewer. java:3697)
> at
> org.eclipse.jface.text.source.SourceViewer.canDoOperation(So urceViewer.java:701)
> at
> org.eclipse.jface.text.source.projection.ProjectionViewer.ca nDoOperation(ProjectionViewer.java:1525)
> at
> org.eclipse.wst.sse.ui.internal.StructuredTextViewer.canDoOp eration(StructuredTextViewer.java:149)
> at
> org.eclipse.ui.texteditor.TextOperationAction.update(TextOpe rationAction.java:157)
> at
> org.eclipse.ui.texteditor.TextOperationAction.<init>(TextOperationAction.java:103)
> at
> org.eclipse.ui.texteditor.AbstractTextEditor.createActions(A bstractTextEditor.java:5526)
> at
> org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.create Actions(AbstractDecoratedTextEditor.java:1090)
> at
> org.eclipse.ui.editors.text.TextEditor.createActions(TextEdi tor.java:118)
> at
> org.eclipse.wst.sse.ui.StructuredTextEditor.createActions(St ructuredTextEditor.java:1426)
> at
> org.eclipse.ui.texteditor.AbstractTextEditor.createPartContr ol(AbstractTextEditor.java:3361)
> at
> org.eclipse.ui.texteditor.StatusTextEditor.createPartControl (StatusTextEditor.java:53)
> at
> org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.create PartControl(AbstractDecoratedTextEditor.java:394)
> at
> org.eclipse.wst.sse.ui.StructuredTextEditor.createPartContro l(StructuredTextEditor.java:1583)
> at
> org.eclipse.ui.part.MultiPageEditorPart.addPage(MultiPageEdi torPart.java:217)
> at
> org.eclipse.ui.part.MultiPageEditorPart.addPage(MultiPageEdi torPart.java:187)
> at
> org.eclipse.wst.xml.ui.internal.tabletree.XMLMultiPageEditor Part.addSourcePage(XMLMultiPageEditorPart.java:410)
> at
> org.eclipse.wst.xml.ui.internal.tabletree.XMLMultiPageEditor Part.createPages(XMLMultiPageEditorPart.java:580)
> at
> org.eclipse.ui.part.MultiPageEditorPart.createPartControl(Mu ltiPageEditorPart.java:310)
> at
> org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:661)
> at
> org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:428)
> at
> org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:594)
> at
> org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(Ed itorAreaHelper.java:263)
> at
> org.eclipse.ui.internal.EditorManager.setVisibleEditor(Edito rManager.java:1410)
> at
> org.eclipse.ui.internal.EditorManager$5.runWithException(Edi torManager.java:944)
> at
> org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
> at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
> at
> org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:133)
> at
> org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3378)
> at
> org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3036)
> at
> org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:803)
> at
> org.eclipse.ui.internal.Workbench$27.runWithException(Workbe nch.java:1361)
> at
> at
> at
> at
> at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2293)
> at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
> at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
> at
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
> at
> org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
> at
> org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:597)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
> "VM Thread" prio=10 tid=0x0811c800 nid=0x1b48 runnable
> "VM Periodic Task Thread" prio=10 tid=0x08146000 nid=0x1b4e waiting on
> condition
> JNI global references: 1322
> Heap
> def new generation total 18176K, used 15501K [0x14270000, 0x15620000,
> 0x19130000)
> eden space 16192K, 83% used [0x14270000, 0x14fa3560, 0x15240000)
> from space 1984K, 100% used [0x15430000, 0x15620000, 0x15620000)
> to space 1984K, 0% used [0x15240000, 0x15240000, 0x15430000)
> tenured generation total 241984K, used 13636K [0x19130000,
> 0x27d80000, 0x54270000)
> the space 241984K, 5% used [0x19130000, 0x19e81030, 0x19e81200,
> 0x27d80000)
> compacting perm gen total 262144K, used 21862K [0x54270000,
> 0x64270000, 0x94270000)
> the space 262144K, 8% used [0x54270000, 0x557c9988, 0x557c9a00,
> 0x64270000)
> ro space 8192K, 73% used [0x94270000, 0x948535a8, 0x94853600,
> 0x94a70000)
> rw space 12288K, 58% used [0x94a70000, 0x95168878, 0x95168a00,
> 0x95670000)
Re: Ganymede hangs at loading workbench [message #330614 is a reply to message #330613] |
Tue, 05 August 2008 12:02   |
This appears to be the smoking gun:
>> at
>> at
>> at
>> at
Could there be some issue finding your networked printers or something
like that (I don't know much about printer support for Linux)?
>> Hello,
>> it does not pass the splash screen stage. I switched from JDK 1.5 to
>> JDK 1.6 but that didn't change anything. I've also updated GTK-related
>> I point it to a different workspace (smaller in size). The problematic
>> the content of the log file content followed by the JVM dump (after
>> sending it a Quit signal). The messages in the log used to appear even
>> when Eclipse did not hang.
>> Thanks,
>> Alex
>> -Xms256m
>> -Xmx1024m
>> -XX:PermSize=256m
>> -os linux
>> -ws gtk
>> -arch x86
>> -showsplash
>> -name Eclipse
>> --launcher.library
>> -startup
>> -debug
>> -vmargs
>> -Xms256m
>> -Xmx1024m
>> -XX:PermSize=256m
>> Install location:
>> Configuration file:
>> Framework located:
>> Splash location:
>> Debug options:
>> 2008-08-05 16:56:32
>> sharing):
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> nid=0x1b51 in Object.wait()
>> at
>> at
>> in Object.wait()
>> at
>> at
>> on condition
>> at
>> runnable
>> condition
>> on condition
>> at
>> Object.wait()
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> condition
>> Heap
>> 0x15620000, 0x19130000)
>> 0x27d80000)
>> 0x64270000)
>> 0x94a70000)
>> 0x95670000)
*new* Common Navigator Framework section in:
3.4RC4 Platform Plugin Developer Guide (Programmer's Guide)
http://help.eclipse.org/ganymede/topic/org.eclipse.platform. doc.isv/guide/cnf.htm
http://dev.eclipse.org/blogs/francis
http://wiki.eclipse.org/Common_Navigator_Framework
http://wiki.eclipse.org/Common_Navigator_Framework_Use_Cases
You have brains in your head.
You have feet in your shoes.
- Dr Seuss, Oh the Places You'll Go
Current Time: Sun Aug 31 14:20:41 EDT 2025
Powered by FUDForum. Page generated in 0.05133 seconds
