Home » Eclipse Projects » Eclipse Platform » Hooking existing clipboard commands
Hooking existing clipboard commands [message #330598] Tue, 05 August 2008 04:03 Go to next message
Originally posted by: mba.cosmigo.ru
Hi everyone,
I'm trying to create a plugin like MultiClipboard. I'm a bit new to the
JFace concepts so please bear with me.
What I want to do is to is to add my custom handlers to the
cut/copy/paste commands wrapping the default handlers in them.
Something like this:
case1:
handleCopyCommand()
runCopyCommandAsIfThereNoMyPlugin();
doMySpecificCopyHandling();
or maybe something like this:
case2:
handleMyCustomCopyCommand()
fireStabdardCopyCommand();
As far as I understand the whole thing after reading docs, I need to
play around the org.eclipse.ui.commands extension point, but there are
things I still don't understand:
1. How to add a global command which would be active everywhere? My
plugin does not provide the editor. It provides a view, but it might be
closed. And I still want to have some key combination registered in the
workbench to fire my custom command (case2).
2. How to programmable initiate the command which was defined already
(case2)?
3. Is it possible at all to hook to the command like in case1?
I've tried to search the newsgroups but it seems that I cannot invent
the proper request.. Will be grateful for any help.
Best regards
Mikhail Barg
ICQ: 132560784
Re: Hooking existing clipboard commands [message #330857 is a reply to message #330598] Thu, 14 August 2008 13:33 Go to previous message
org.eclipse.ui defines commands the commands like:
org.eclipse.ui.edit.copy -> CTRL+C
org.eclipse.ui.edit.cut -> CTRL+V
etc
org.eclipse.ui then provides a default handler for each of these
commands, org.eclipse.ui.internal.handlers.WidgetMethodHandler, that
when left alone will invoke the appropriate SWT method on the control in
focus (like focusControl.copy())
Parts then provide their own handlers as they see fit, and the part
handler overrides the default handler for copy.
It would be difficult to to write your own handler that could find the
"handler that would be active now if it wasn't for me" handler, so you
could do your work and delegate.
You might be able to do what you want though, but using
org.eclipse.core.commands.IExecutionListener and attaching it to the
ICommandService. Then you could check for the org.eclipse.ui.edit.copy
commandId in the pre and post execute methods, and add your behaviour as
well.
Later,
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Previous Topic:CVS and Linked Source Folder
Next Topic:Are enabled activities persisted?
Current Time: Tue Jul 22 21:33:24 EDT 2025
Powered by FUDForum. Page generated in 0.02974 seconds
