Home » Eclipse Projects » Eclipse Platform » How to get rid of "Run as...,Debug As" in my context menu
How to get rid of "Run as...,Debug As" in my context menu [message #330527] Thu, 31 July 2008 09:50 Go to next message
Originally posted by: rudolf.hornig.omnest.com
We have a graphical editor where we registered a context menu. When we open the
context menu on we have several unwanted menu items like Run as...,Debug As...,
Team etc. How can we get rid of them? We would like to keep the
context menu registered.
It seems that org.eclipse.debug.ui registers these contributions to
"java.lang.Object" is there a way to neutralize that?
Thanks, Rudolf
Re: How to get rid of "Run as...,Debug As" in my context menu [message #330533 is a reply to message #330527] Thu, 31 July 2008 10:43 Go to previous messageGo to next message
In a product/RCP, you can use product transforms to remove the unwanted
XML http://wiki.eclipse.org/Product_Customization .
The other option is to use org.eclipse.ui.activities. You can bind an
activity to the contributions you don't want, and have the activity
default be false (although that will remove them from all context menus).
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: How to get rid of "Run as...,Debug As" in my context menu [message #330534 is a reply to message #330533] Thu, 31 July 2008 11:36 Go to previous messageGo to next message
Thanks for the pointers, I have checked them. We want to get rid of these
menus ONLY in our editor window (just not to pollute the context menu),
but still want to register the menu, so some of OUR own other plugins
could be able to contribute to it.
Is there a way to register a menu privately for example?
i.e. contributions going to "org.eclipse.ui.popup.any" would not be added
to this menu, only those that specify the menu/part id explicitly...
>> open the context menu on we have several unwanted menu items like Run
>> as...,Debug As...,
> menus).
> PW
Re: How to get rid of "Run as...,Debug As" in my context menu [message #330536 is a reply to message #330534] Thu, 31 July 2008 12:33 Go to previous messageGo to next message
There used to be ... in the old world, if you didn't add an "additions"
group marker to your registered context menu there was no way of adding
to it (except programmatically). But even that was "accept contribution
v.s. no contributions"
The new system doesn't even have that restriction, since it auto-creates
an additions group if necessary.
I can't think of a workaround. Do the menus still appear after the
org.eclipse.ui.debug plugin has been activated? They usually only
appear if some facet of the editor/selection is launchable.
Perhaps we need an enhancement request to allow a context menu to
"opt-out" of popup:org.eclipse.ui.popup.any
PW
Paul Webster
Re: How to get rid of "Run as...,Debug As" in my context menu [message #330706 is a reply to message #330536] Mon, 11 August 2008 05:41 Go to previous messageGo to next message
>> these menus ONLY in our editor window (just not to pollute the context
>> menu), but still want to register the menu, so some of OUR own other
>> plugins could be able to contribute to it.
>> Is there a way to register a menu privately for example? i.e.
>> contributions going to "org.eclipse.ui.popup.any" would not be added to
It seems that the Debug As menu (and some other) are registered to show
if an Object is selected (ie. practically anything can be launchable)
I would expect to have some marker interface like ILaunchable/IDebuggable
and these menus should be visible only if an object is selected and Adopts
/ Implements these marker interfaces. But unfortunately it is not
implemented this way...
Would love to see this enhancement to...
Thanks, Rudolf
Re: How to get rid of "Run as...,Debug As" in my context menu [message #330768 is a reply to message #330527] Tue, 12 August 2008 13:37 Go to previous messageGo to next message
Originally posted by: felix.mayer.erdas.com
Did you try to override method
org.eclipse.jface.action.ContributionManager.allowItem(ICont ributionItem)?
"Hornig Rudolf" <rudolf.hornig@omnest.com> wrote in message
news:g6sfve$c2m$1@build.eclipse.org...
> open the
> As...,
> Thanks, Rudolf
Re: How to get rid of "Run as...,Debug As" in my context menu [message #330849 is a reply to message #330706] Thu, 14 August 2008 12:39 Go to previous messageGo to next message
It should be ... these menus should show up on any object that adapts
(via adapter factory) to org.eclipse.debug.ui.actions.ILaunchable. That
would include many java elements and IResource elements.
Later,
PW
Paul Webster
Re: How to get rid of &quot;Run as...,Debug As&quot; in my context menu [message #331569 is a reply to message #330849] Thu, 11 September 2008 15:11 Go to previous message
Originally posted by: ralffrotscher.web.de
I override the addListener-method in the ContextMenuProvider in the following way:
public void addMenuListener(IMenuListener listener) {
if (listener instanceof PopupMenuExtender) {
return;
super.addMenuListener(listener);
The PopupMenuExtender would add these contributions to the context menu. It would be better to avoid this by deactivating the PopupMenuExtender but for the moment the solution above works.
Ralf
Previous Topic:Obtaining *all* referenced projects (including plugins and external folders)
Next Topic:how to check in derived resources?
Current Time: Fri Jul 18 21:22:16 EDT 2025
Powered by FUDForum. Page generated in 0.04245 seconds
