Home » Eclipse Projects » Eclipse Platform » Annotatioin Presentation Layer
Annotatioin Presentation Layer [message #330494] Wed, 30 July 2008 03:39 Go to next message
I want to set the presentation layer of an annotation which is part of my
plugin. (via the org.eclipse.ui.editor.markerAnnotationSpecification
extension point) It had been set at 0 but it would sometimes be
overwritten by the first line of context shading in the java editor ruler.
I found that setting it to 1 solves this current problem, but I'm
wondering, are there any guidelines/conventions as to what value to make
the presentation layer of you're plugin's annotations? I have not been
successful at finding any discussion on the topic.
Re: Annotatioin Presentation Layer [message #330682 is a reply to message #330494] Fri, 08 August 2008 08:17 Go to previous message
> ruler.
This is not exactly specified. Basically the higher the number the
bigger the chance that it isn't hidden by another annotation with a
higher value. I'd look at existing annotation specs and see where yours
fits in. 0 shouldn't be used as you already found out.
Dani
Previous Topic:Does Eclipse 3.3 TextEditor Support DnD ?
Next Topic:IPartListener lifecycle question
Current Time: Sun Aug 31 15:57:14 EDT 2025
Powered by FUDForum. Page generated in 0.05871 seconds
