Home » Eclipse Projects » Eclipse Platform » Code assist
Code assist [message #330372] Sun, 27 July 2008 04:52 Go to next message
Originally posted by: albox.free.fr
Does anybody know how to use the "code assist" feature to search for a
function containing some specific words.
For example, I am currently using the openCV library and I want to search
for all the functions that contains the word "exp". Do you know how to do
that ?
Something simpler would be to export the list of functions found by the
code assistant and then to use a simple text editor to search for the
string.
Thanks for your help
Re: Code assist [message #330412 is a reply to message #330372] Mon, 28 July 2008 08:34 Go to previous messageGo to next message
alboot wrote:
> search for all the functions that contains the word "exp". Do you know
> how to do that ?
> string.
Content Assist won't really help you, but the Java Search can. Use
Ctrl+H to open the Search dialog, select the Java tab, and enter your
search criteria there.
Hope this helps,
Eric
Re: Code assist [message #330425 is a reply to message #330412] Mon, 28 July 2008 12:41 Go to previous messageGo to next message
Thanks. That will do the trick :-)
Re: Code assist [message #330453 is a reply to message #330425] Tue, 29 July 2008 09:24 Go to previous message
Originally posted by: Adam_Neal.ca.ibm.com
I like the CTRL+O feature personally. It will bring a quick list of all the
available methods, and will filter based on what you type....pressing CTRL+O
again while the quick window is still open will add the inherited methods as
well.....
Adam
"alboot" <albox@free.fr> wrote in message
news:26d0e44fc8d8efb714048190f0422820$1@www.eclipse.org...
Previous Topic:Executing a command in an External Tool console
Next Topic:Common filter makes contents of unfilter projects disappearing
Current Time: Sun Jun 29 05:17:14 EDT 2025
Powered by FUDForum. Page generated in 0.02957 seconds
