Home » Eclipse Projects » Eclipse Platform » Default behaviour for find TableItem associated to a TableViewer element
Default behaviour for find TableItem associated to a TableViewer element [message #330317] Fri, 25 July 2008 03:45 Go to next message
I'm using a TableViewer. Inside the TableViewer I place ArrayList objects.
I had a strange problem. After debugging a while I've discovered that
StructuredViewer#findItem(Object element) fails, it gives me the wrong
index for an element.
The cause is that instead of using reference equality, uses content
equality.
AbstractTableViewer#doFindItem()
So If I ask for the TableItem corresponding to an object whose index is 1,
it returns me the object whose index 0, when it has identical values.
I consider this default behaviour dangerous.
I have redefined the equals method of my ArrayList object:
@Override public boolean equals(Object o) {
return o == this;
and now it works ok.
What do the Eclipse experts think?
Re: Default behaviour for find TableItem associated to a TableViewer element [message #330355 is a reply to message #330317] Fri, 25 July 2008 22:41 Go to previous messageGo to next message
Make sure that you also override hashCode() whenever you override equals().
If the native equals and hashCode implementation is not what you need in the
viewer, you can plug in different implementations, see
StructuredViewer.setComparer(IElementComparer).
Boris
"David Perez" <craquerpro@yahoo.es> wrote in message
news:d98328ea7b101ddb59a99f0dcba46bbf$1@www.eclipse.org...
> objects.
> equality.
> return o == this;
Re: Default behaviour for find TableItem associated to a TableViewer element [message #330387 is a reply to message #330355] Mon, 28 July 2008 05:40 Go to previous messageGo to next message
Thanks Boris,
I didn't take into account the hashCode().
Now, my custom row object is like this:
class MyObject extends ArrayList<Object> {
return o == this;
@Override public int hashCode() {
return System.identityHashCode(this);
It would be nice if the Platform documentation emphasized that the
equals() method implementation is important.
Re: Default behaviour for find TableItem associated to a TableViewer element [message #330579 is a reply to message #330387] Mon, 04 August 2008 08:21 Go to previous message
File a bug and attach a patch against HEAD with your proposed JavaDoc
comment.
Tom
David Perez schrieb:
> Thanks Boris,
> return o == this;
>> equals().
>> in the viewer, you can plug in different implementations, see
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Previous Topic:Updating certain columns in a TableViewer
Next Topic:Why ColumnViewerEditorActivationListener isn't called
Current Time: Sat Nov 29 05:16:23 EST 2025
Powered by FUDForum. Page generated in 0.27532 seconds
