Home » Language IDEs » C / C++ IDE (CDT) » Debug target pathname
Debug target pathname [message #33448] Wed, 22 May 2002 03:01 Go to next message
Having suffer a problem debugging under Windows with Cygwin installed I
decided to dig a bit further. I loaded the gdbpicl source and had a look at
the pathname generation code. If this is actually tageted at Unix then I
believe the convention should be to escape control and non-printing
charaters in the pathname, ie. the path "/a/b c/d" should be modified to
"a/b\ c/c" according to Unix conventions. This would certainly fix the
problem for me windows and make things much more tranparent (like you
wouldn't have to worry about where your source was in a directory
structure).
In trying to test this mod I'm confused about how the debug inspector works.
It keeps giving me a popup to the effect '... cannot resolve...' name if the
name is anything other than this or one declared in the method. Have I
missed a setting somewhere?
Regarding the pathname stuff, I think this change should be made. For Unix
it's neutral, for windows it's a real bonus.
Thanx,
Al
Re: Debug target pathname [message #33681 is a reply to message #33448] Wed, 22 May 2002 14:53 Go to previous messageGo to next message
Thanks for looking into this problem.
Can you give me more information about the error message you were getting
when you tried to test the modification? Maybe I can help figure out what
was going on.
Samantha
> structure).
> Thanx,
> Al
Re: Debug target pathname [message #33748 is a reply to message #33448] Wed, 22 May 2002 16:18 Go to previous messageGo to next message
Hi Allan,
Could you also let me know what you have modified for this problem?
I would like to take a look at it and test it out as well.
Samantha
> structure).
> Thanx,
> Al
Re: Debug target pathname [message #34273 is a reply to message #33748] Mon, 27 May 2002 04:29 Go to previous messageGo to next message
Samantha,
I've fixed this problem, ie. I now have a version of CDT that properly
handles pathnames with embedded spaces on Windows and cygwin gdb. The
changes (at least as I've done them) are to add a static method to Gdb that
does the work of escaping the filename string and then use this method to
modify the path passed to GetDebugSession.setStartProgramNameString(). I am
now a happy puppy. If you wish to see these changes please contact me at
allan@object-forge.com and I'll ship you the modified gdbPicl package.
Thanx,
Al
"Samantha Chan" <chanskw@ca.ibm.com> wrote in message
news:acgufg$khg$1@rogue.oti.com...
> Hi Allan,
> Thanks
> Samantha
look at
I
> > structure).
works.
the
Unix
> > Thanx,
> > Al
Re: Debug target pathname [message #34305 is a reply to message #34273] Mon, 27 May 2002 17:01 Go to previous messageGo to next message
Hi Allan,
Thanks for letting me know.
I have also put in a fix for this problem.
Instead of just escaping spaces in the filename, I have included other
special characters to escape as well. My fix is in
GdbDebugSession.setStartProgramName.
In addition to spaces, following characters are escaped:
I have checked in the code in CVS. You can get the fix by checking out
the most recent copy of GdbDebugSession.java from CVS.
I hope it solves your problem running GDBPicl on Windows. Let me know if
you experience any problem.
Samantha
> Samantha,
> Thanx,
> Al
> > Hi Allan,
> > Thanks
> > Samantha
> look at
> I
> > > structure).
> works.
> the
> Unix
> > > Thanx,
> > > Al
Re: Debug target pathname [message #34443 is a reply to message #34305] Tue, 28 May 2002 08:49 Go to previous messageGo to next message
Samantha,
Had a look - 2 comments:
1) The interpretation of the '\' char in the input string is ambiguous.
You can either treat it as a character to be escaped (as you have) or assume
the caller has already constructed a string with an escaped character in it.
In the latter case your code adds a newly escaped '\' to the string. I not
sure this what you want. I'm inclined to consider a '\' char in the input
string as being there on purpose and leave the next character alone.
2) I implemented a method rather than simply embed the code since this is a
generally useful utility. That's a matter of taste.
I'd be inclined to change as follows:
private String escapeChars=" ~`!@#$%^&()+={}[];,/:*?\"<>|";
StringBuffer buffer = new StringBuffer();
char[] mainProg = _mainProgram.toCharArray();
boolean escaped = false;
for (int i=0; i<mainProg.length; i++){
if (escapeChars.indexOf(mainProg[i]) >= 0 && !escaped ){
buffer.append('\\');
eacaped = (esacped)? false : (mainProg[i]=='\\' );
buffer.append(mainProg[i]);
news:acu6r3$6uq$1@rogue.oti.com...
> Hi Allan,
> Samantha
> > Samantha,
that
to
I am
> > Thanx,
> > Al
> > > Hi Allan,
> > > Thanks
> > > Samantha
installed I
> > look at
then
> > I
modified to
the
you
> > > > structure).
inspector
> > works.
name if
> > the
Have I
For
> > Unix
> > > > Thanx,
> > > > Al
Re: Debug target pathname [message #35090 is a reply to message #34443] Thu, 30 May 2002 16:30 Go to previous message
Hi Allan,
I agree about the ambiguity of '\'. I will put in your recommended
changes.
Samantha
> Samantha,
> > Hi Allan,
> > Thanks,
> > Samantha
> > > Samantha,
> that
> to
> I am
> at
> > > Thanx,
> > > Al
> > > > Hi Allan,
> > > > Thanks
> > > > Samantha
> installed I
> > > look at
> then
> > > I
> modified to
> the
> you
> > > > > structure).
> inspector
> > > works.
> name if
> > > the
> Have I
> For
> > > Unix
> > > > > Thanx,
> > > > > Al
Previous Topic:New document available describing how to build\run\debug the CDT within Eclipse
Next Topic:Configuring an LPEX parser programmatically
Current Time: Sat Aug 30 21:03:19 EDT 2025
Powered by FUDForum. Page generated in 0.07361 seconds
