| Change configuration location dynamically? Best practice? [message #330285] |
Thu, 24 July 2008 09:50 |
Originally posted by: a.heikhaus.cenit.de
I have the following problem: I have to change the configuration location dynamically on startup.
Therefore I can not use the way of editing the ini-file and setting osgi.configuration.area. More precisely: Configuration-area-informations will be provided by the windows registry and can be different for each startup of my rcp-app on the same machine. Now I´m asking by myself: Where is the best point to integrate? Is it a common way to call somewhere
Location confLocation = Platform.getConfigurationLocation();
confLocation.setURL(value, lock);
Where to do it best? Is there still a possible way or is the location already set in each case?
And how to prevent my launch configuration (when runnning my rcp within my IDE) to set no configuration-location? (@noDefault or @none has no effects)
FUDForum. Page generated in 0.24977 seconds
