Home » Eclipse Projects » Eclipse Platform » Question about Common Navigator and drop adapter assistants
Question about Common Navigator and drop adapter assistants [message #330247] Tue, 22 July 2008 16:30 Go to next message
I've got a common navigator viewer for which I need to do some
specialized drag-and-drop handling. I'm trying to define a
CommonDropAdapterAssistant to be used for certain file types. So in my
plugin.xml I have something like this:
<dropAssistant
class="org.skyway.core.ui.navigator.SkywayDropAssistant"
id="org.skyway.core.ui.navigator.dropAssistant">
<possibleDropTargets>
<adapt type="org.skyway.core.model.Container"></adapt>
</possibleDropTargets>
</dropAssistant>
The problem is, even when the drop target can not be adapted to a
org.skyway.core.model.Container, the drop operation is allowed to proceed.
I think this is because there is always a
org.eclipse.ui.navigator.resources.ResourceDropAdapterAssist ant included
(it is declared by the plugin org.eclipse.ui.navigator.resources) and
it's possibleDropTargets expression includes any target that can be
adapted to an IFile, IFolder, or IProject.
So can I have a drop assistant that controls the validation of drops on
particular files and folders? In other words, can I override this
behavior of ResourceDropAdapterAssistant for certain resources, while
keeping it in place for everything else?
Eric
Re: Question about Common Navigator and drop adapter assistants [message #330269 is a reply to message #330247] Thu, 24 July 2008 02:08 Go to previous message
The org.eclipse.ui.navigator.resources does defined a DropAssistant that
handles resources. However, you don't need to include this with your
instance of the CN.
You probably have something like this as part of your
org.eclipse.ui.navigator.viewer extension:
<viewerContentBinding
viewerId="example.view">
<includes>
<contentExtension
pattern="org.eclipse.ui.navigator.resourceContent" />
<contentExtension
pattern="org.eclipse.ui.navigator.resources.filters.*"/>
<contentExtension
pattern="org.eclipse.ui.navigator.resources.linkHelper"/>
<contentExtension
pattern="org.eclipse.ui.navigator.resources.workingSets"/>
</includes>
</viewerContentBinding>
The first content extension pulls the resourceContent which includes the
dropAssistant. Just remove that reference. If you want some of what's
defined in org.eclipse.ui.navigator, then you can make your own content
extension and copy what you want from the
org.eclipse.ui.navigator.resources plugin.
HTH,
Francis
PS - sorry for the delay in the reply.
> <dropAssistant
> </dropAssistant>
> Eric
*new* Common Navigator Framework section in:
3.4RC4 Platform Plugin Developer Guide (Programmer's Guide)
http://help.eclipse.org/ganymede/topic/org.eclipse.platform. doc.isv/guide/cnf.htm
http://dev.eclipse.org/blogs/francis
http://wiki.eclipse.org/Common_Navigator_Framework
http://wiki.eclipse.org/Common_Navigator_Framework_Use_Cases
You have brains in your head.
You have feet in your shoes.
- Dr Seuss, Oh the Places You'll Go
Previous Topic:How to check out a CVS project of a specific branch AND date?
Next Topic:Modifying plugin.xml file programmatically
Current Time: Sat Jul 26 06:08:20 EDT 2025
Powered by FUDForum. Page generated in 0.29872 seconds
