Home » Eclipse Projects » Eclipse Platform » CCombo and Databinding
CCombo and Databinding [message #330213] Mon, 21 July 2008 10:28 Go to next message
I have a list of objects and a CCombo which shows the name attribute of
these objects. I want to bind the objects that when an item is
added/removed from the CCombo the model gets updated (i.e. I want to
create/delete objects from the list). Is this possible?
Matthias
Re: CCombo and Databinding [message #330214 is a reply to message #330213] Mon, 21 July 2008 11:43 Go to previous messageGo to next message
This is easier to do if you use a combo viewer:
ComboViewer viewer = new ComboViewer(ccombo);
ObservableListContentProvider cp = new ObservableListContentProvider();
viewer.setContentProvider(cp);
// (Substitute the actual class and property names in your code)
IObservableMap itemNames = BeansObservables.observeMap(
cp.getKnownElements(), YourModelClass.class, "name");
viewer.setLabelProvider(new ObservableMapLabelProvider(itemNames));
IObservableList list = BeansObservables.observeList(
yourModelContainer, "modelList"); // (substitute real property name)
viewer.setInput(list);
In this setup, any additions or removals to the observable list will be
automatically forwarded to the viewer. This is because
ObservableListContentProvider monitors the input observable list for
changes and updates the viewer accordingly.
As for copying changes back to the model, there are a few different ways
I've seen folks do this:
1) Add and remove elements on the input observable list. Because this
list is backed by your model, changes to the list will be propagated
back to the model.
2) Add and remove elements directly on the model. As long as your model
objects fire property change events for each change, the changes will
show up immediately in the combo.
Hope this helps,
Matthew
Re: CCombo and Databinding [message #330251 is a reply to message #330214] Wed, 23 July 2008 02:31 Go to previous message
>> of these objects. I want to bind the objects that when an item is
> back to the model.
> Hope this helps,
> Matthew
Thanks Matthew, works great. I only need to refresh the ComboViewer when
removing the current selected object as the selection doesn't change.
Matthias
Previous Topic:customizing finish button on org.eclipse.jface.wizard.Wizard
Next Topic:Plugins with different versions, one as project, one as jar
Current Time: Fri Jul 18 02:06:25 EDT 2025
Powered by FUDForum. Page generated in 0.06378 seconds
