Home » Eclipse Projects » Eclipse Platform » exit eclipse IPlatformRunnable with error exit code
exit eclipse IPlatformRunnable with error exit code [message #330149] Thu, 17 July 2008 06:24 Go to next message
Originally posted by: kadychevski.magillem.com
i'm trying to make eclipse application return some custom exit code (to
be used in a bash script later). basically the code is
class MyRunnable implements IPlatformRunnable {
public Object run(Object args) throws Exception {
try {
doSomeStuff();
catch(MyExitException e) {
return 1;
return IPlatformRunnable.EXIT_OK;
private doSomeStuff() throws MyExitException {
throw new MyExitException("something went wrong");
this is where i am after browsing through eclipse forums and api
documentation.
the problem is this solution generates a "JVM crashed window" with error
code = 1.
Do someone knows where am i wrong?
thanks,
vladimir
Re: exit eclipse IPlatformRunnable with error exit code [message #330159 is a reply to message #330149] Thu, 17 July 2008 11:31 Go to previous messageGo to next message
Hey Vladimir,
This is expected behaviour in current versions of Eclipse. I think the
dialog you are seeing is not really a JVM "crashed" dialog, but more a JVM
"exited with non-zero exit status" dialog, which is exactly what
happened. The somewhat new behaviour of this dialog being shown has
recently bitten me as well, and there is more information in these bugs
about this issue and how to work around it (I am assuming you are using
Eclipse 3.4):
https://bugs.eclipse.org/bugs/show_bug.cgi?id=209080
https://bugs.eclipse.org/bugs/show_bug.cgi?id=191597
The executive summary? Try adding this line to your run method to avoid
the dialog:
System.getProperties().put("eclipse.exitdata", "");
Mark.
On Thu, 17 Jul 2008 06:24:51 -0400, Vladimir Kadychevski
<kadychevski@magillem.com> wrote:
> Hello,
> try {
> doSomeStuff();
> return 1;
> documentation.
> code = 1.
> thanks,
> vladimir
Re: exit eclipse IPlatformRunnable with error exit code [message #330168 is a reply to message #330159] Thu, 17 July 2008 14:32 Go to previous message
hi Mark,
thanks for your answer. Actually I'm working on eclipse 3.2.2 on linux.
if you say that this is expected behavior it's good enough for me. i'll
wrap eclipse launcher in a script or something like that.
thanks for your help,
Vladimir
Mark Melvin a écrit :
> Hey Vladimir,
> JVM "exited with non-zero exit status" dialog, which is exactly what
> Eclipse 3.4):
> the dialog:
> Mark.
>> Hello,
>> try {
>> doSomeStuff();
>> return 1;
>> documentation.
>> code = 1.
>> thanks,
>> vladimir
Previous Topic:Adding a control to the toolbar
Next Topic:See target platform's plug-ins in plug-in registry
Current Time: Fri Nov 21 21:23:20 EST 2025
Powered by FUDForum. Page generated in 0.04627 seconds
