Home » Eclipse Projects » Eclipse Platform » Signal Error
Signal Error [message #330148] Thu, 17 July 2008 06:24 Go to next message
Originally posted by: fucillax.libero.it
Hi all,
I'm looking for a book about the following libraries:
import org.eclipse.jface.text.source.Annotation;
import org.eclipse.jface.text.source.AnnotationBarHoverManager;
import org.eclipse.jface.text.source.AnnotationModel;
import org.eclipse.jface.text.source.AnnotationPainter;
import org.eclipse.jface.text.source.AnnotationRulerColumn;
import org.eclipse.jface.text.source.CompositeRuler;
import org.eclipse.jface.text.source.IAnnotationAccess;
import org.eclipse.jface.text.source.IAnnotationAccessExtension;
import org.eclipse.jface.text.source.IAnnotationHover;
import org.eclipse.jface.text.source.IAnnotationModel;
import org.eclipse.jface.text.source.ISharedTextColors;
import org.eclipse.jface.text.source.ISourceViewer;
import org.eclipse.jface.text.source.IVerticalRuler;
import org.eclipse.jface.text.source.OverviewRuler;
Thanks in advance
Re: Signal Error [message #330153 is a reply to message #330148] Thu, 17 July 2008 09:14 Go to previous messageGo to next message
Marco Fucilla pisze:
> Hi all,
> Thanks in advance
Do you really need a book? Isn't JavaDoc enough? e.g look here:
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/reference/api/org/eclipse/jface/text/source /class-use/Annotation.html
kind regards,
Jakub
http://eclipser-blog.blogspot.com/
http://eclipse-po-polsku.blogspot.com/
Re: Signal Error [message #330155 is a reply to message #330153] Thu, 17 July 2008 09:42 Go to previous messageGo to next message
Hi Jakub,
thanks for your answer. I need a book because I have to write my
thesis.
Anyway thanks!!!
kind regards, Marco.
Re: Signal Error [message #330156 is a reply to message #330155] Thu, 17 July 2008 09:51 Go to previous messageGo to next message
Marco Fucilla wrote:
> Hi Jakub,
> my thesis.
And why do you absolutely need a book for that?
Dani
> Anyway thanks!!!
Re: Signal Error [message #330157 is a reply to message #330156] Thu, 17 July 2008 10:06 Go to previous messageGo to next message
Hi Dani.
Because I can't made my thesis only with the code...
Marco
Re: Signal Error [message #330178 is a reply to message #330157] Fri, 18 July 2008 07:46 Go to previous messageGo to next message
> Hi Dani.
Sure, but there are articles, tutortials, talks, etc. If that's not
enough then you're probably doomed to fail your thesis ;-)
Dani
> Marco
Re: Signal Error [message #330183 is a reply to message #330178] Fri, 18 July 2008 09:13 Go to previous message
When I'll finish my thesis I'll send you my plugin and my thesis ok..
You have more than ten years? Sure???
Marco
Previous Topic:Cropping SWT image
Next Topic:No required execution environment... Causing Trouble
Current Time: Wed May 07 21:41:27 EDT 2025
Powered by FUDForum. Page generated in 0.07176 seconds
