Re: Eclipse doubts [message #1739327 is a reply to message #1739325] |
Fri, 29 July 2016 17:58 |
Images should generally be attached directly, rather than embedded in a proprietary document format.
Can you explain which ones aren't available that should be, as well as exactly what you downloaded?
_
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: Eclipse doubts [message #1739454 is a reply to message #1739325] |
Mon, 01 August 2016 18:48 |
I think you're missing that you're comparing two different Perspectives. Perspectives define the initial layout of views and the contents of the toolbar and menus. You can open different Perspectives from the Window menu or the Perspective switcher, which you'll usually find embedded into the toolbar in the upper right corner. You can move views, their view stacks, hide and show menu and toolbar content, and then save those as named Perspectives of your own.
The Java EE package includes its own Perspective, opening it by default, but the traditional Java Perspective should be there as well--all you need to do is is Open it from the Window menu if it's not already in the switcher.
_
Nitin Dahyabhai
Re: Eclipse doubts [message #1739508 is a reply to message #1739325] |
Mon, 01 August 2016 15:52 |
On 7/29/16, 1:55 PM, sanman Kelkar wrote:
> Hello Experts,
> I have attached a detailed file with all the screenshots. Does the problem lies with version I downloaded or am I missing something ?
> Please Help :(
> Sanman
*Perspectives*. Perspectives define the initial layout of views and the
but the traditional Java Perspective should *also* be there--all you
switcher.
Nitin Dahyabhai
Eclipse WTP
IBM Emerging Technologies
_
Nitin Dahyabhai
FUDForum. Page generated in 0.08301 seconds
