Home » Eclipse Projects » Eclipse Platform » Eclipse 3.4 crashes
Eclipse 3.4 crashes [message #329906] |
Thu, 10 July 2008 07:39  |
Originally posted by: andreas-scharf.gmx.de
after I imported the plugin org.eclipse.emf.ecore into my project,
Eclipse crashes while building the workspace. Im using 64-bit Vista with
the Sun 64-bit VM (6u7). Does somebody have the same problem?
Zenobios
Re: Eclipse 3.4 crashes [message #329907 is a reply to message #329906] |
Thu, 10 July 2008 07:57   |
--------------040709000408040806000905
I have attached the jvm error log, if that helps.
Andreas Scharf schrieb:
> Cheers,
> Zenobios
name="hs_err_pid4132.log"
Content-Disposition: inline;
filename="hs_err_pid4132.log"
# An unexpected error has been detected by Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x0000000008093e4b, pid=4132, tid=1220
# Java VM: Java HotSpot(TM) 64-Bit Server VM (10.0-b23 mixed mode windows-amd64)
# Problematic frame:
# V
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x0000000005fb1800): JavaThread "CompilerThread1" daemon
siginfo: ExceptionCode=0xc0000005, reading address 0x0000000000000000
Registers:
EAX=0x0000000000000000, EBX=0x000000000dba1c90, ECX=0x0000000000000002, EDX=0x0000000008459d01
ESP=0x00000000067dcab0, EBP=0x0000000000000000, ESI=0x000000000de7d3a8, EDI=0x000000000f444270
EIP=0x0000000008093e4b, EFLAGS=0x0000000000010202
Top of Stack: (sp=0x00000000067dcab0)
0x00000000067dcab0: 000000000db908f0 000000000a58f128
0x00000000067dcac0: 000000000dba1c90 000000000f444270
0x00000000067dcad0: 0000001b00000011 000000000f444270
0x00000000067dcae0: 0000000000000098 0000000000000088
0x00000000067dcaf0: 0000000000000000 0000000000000000
0x00000000067dcb00: 0000000000000000 0000000000000000
0x00000000067dcb10: 000000000d13dd78 0000000000000000
0x00000000067dcb20: 000000000d13d9a0 00000000067dce70
0x00000000067dcb30: 000000000d13d990 0000000008096557
0x00000000067dcb40: 0000000000000013 0000000000000a01
0x00000000067dcb50: 00000000067df070 0000000000000a07
0x00000000067dcb60: 000000000d13d990 000000000db90880
0x00000000067dcb70: 000000000dbb8970 000000000dbb8970
0x00000000067dcb80: 000000000d13dd78 000000000d13d9a0
0x00000000067dcb90: 000000000000000d 00000000067df070
0x00000000067dcba0: 000000000e067aa0 000000007746ec00
Instructions: (pc=0x0000000008093e4b)
0x0000000008093e3b: 51 50 4a 8b 0c c2 f3 0f 10 41 50 0f 2f c1 77 23
0x0000000008093e4b: 8b 00 21 43 38 8b 45 04 21 43 3c 8b 45 08 21 43
Stack: , sp=0x00000000067dcab0, free space=1010k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
V
Current CompileTask:
C2:994 org.eclipse.jdt.internal.compiler.lookup.ParameterizedMethod Binding. <init> (Lorg/eclipse/jdt/internal/compiler/lookup/ParameterizedType Binding;Lorg/eclipse/jdt/internal/compiler/lookup/MethodBind ing;)V (596 bytes)
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x00000000075ca800 JavaThread "Compiler Processing Task" daemon
0x00000000075ca000 JavaThread "SVN Kit 1.1 Connector"
0x00000000075c9800 JavaThread "Worker-7"
0x00000000075c9000 JavaThread "Worker-6"
0x00000000075c8c00 JavaThread "Worker-5"
0x00000000075c8400 JavaThread "Worker-4"
0x00000000075c7c00 JavaThread "Worker-3"
0x00000000075c7800 JavaThread "Worker-2"
0x00000000075c7000 JavaThread "org.eclipse.jdt.internal.ui.text.JavaReconciler" daemon
0x00000000070ec000 JavaThread "Java indexing" daemon
0x0000000006f96800 JavaThread "Worker-1"
0x0000000006fbdc00 JavaThread "Worker-0"
0x0000000006bd1000 JavaThread "Start Level Event Dispatcher" daemon
0x0000000006c6a000 JavaThread "Framework Event Dispatcher" daemon
0x0000000006a04c00 JavaThread "State Data Manager" daemon
0x0000000005fb5400 JavaThread "Low Memory Detector" daemon
=>0x0000000005fb1800 JavaThread "CompilerThread1" daemon
0x0000000005fa9c00 JavaThread "CompilerThread0" daemon
0x0000000005fa6800 JavaThread "Attach Listener" daemon
0x0000000005fa6400 JavaThread "Signal Dispatcher" daemon
0x0000000000a1d400 JavaThread "Finalizer" daemon
0x0000000005f84800 JavaThread "Reference Handler" daemon
0x000000000019fc00 JavaThread "main"
Other Threads:
0x0000000005f80400 VMThread
0x0000000000962400 WatcherThread [id=3616]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
PSYoungGen total 282240K, used 93414K [0x000000004aac0000, 0x000000005f400000, 0x0000000060010000)
eden space 253632K, 25% used [0x000000004aac0000,0x000000004ea0f8a8,0x000000005a270000)
from space 28608K, 99% used [0x000000005c6f0000,0x000000005e2da338,0x000000005e2e0000)
to space 37376K, 0% used [0x000000005a270000,0x000000005a270000,0x000000005c6f0000)
PSOldGen total 174784K, used 44743K [0x0000000020010000, 0x000000002aac0000, 0x000000004aac0000)
object space 174784K, 25% used [0x0000000020010000,0x0000000022bc1d18,0x000000002aac0000)
PSPermGen total 65792K, used 65617K [0x0000000010010000, 0x0000000014050000, 0x0000000020010000)
object space 65792K, 99% used [0x0000000010010000,0x0000000014024678,0x0000000014050000)
Dynamic libraries:
0x0000000000400000 - 0x0000000000410000 C:\Program Files\Eclipse 3.4\eclipse\eclipse.exe
0x0000000077570000 - 0x00000000776ea000 C:\Windows\system32\ntdll.dll
0x0000000077430000 - 0x0000000077561000 C:\Windows\system32\kernel32.dll
0x0000000077360000 - 0x000000007742a000 C:\Windows\system32\USER32.dll
0x000007fefe320000 - 0x000007fefe381000 C:\Windows\system32\GDI32.dll
0x000007fefe6a0000 - 0x000007fefe79f000 C:\Windows\system32\ADVAPI32.dll
0x000007fefe480000 - 0x000007fefe5b9000 C:\Windows\system32\RPCRT4.dll
0x000007fefc620000 - 0x000007fefc810000 C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_65 95b64144ccf1df_6.0.6000.16386_none_1559f1c6f365a7fa\COMCTL32 .dll
0x000007fefe250000 - 0x000007fefe2f1000 C:\Windows\system32\msvcrt.dll
0x000007fefde10000 - 0x000007fefde81000 C:\Windows\system32\SHLWAPI.dll
0x000007fefdde0000 - 0x000007fefde08000 C:\Windows\system32\IMM32.DLL
0x000007feff3e0000 - 0x000007feff4e4000 C:\Windows\system32\MSCTF.dll
0x000007feff860000 - 0x000007feff86c000 C:\Windows\system32\LPK.DLL
0x000007feff7c0000 - 0x000007feff85a000 C:\Windows\system32\USP10.dll
0x0000000072000000 - 0x0000000072018000 C:\Program Files\Eclipse 3.4\eclipse\plugins\org.eclipse.equinox.launcher.win32.win32 .x86_64_1.0.100.v20080509-1800\eclipse_1114.dll
0x000007fefd270000 - 0x000007fefd27b000 C:\Windows\system32\VERSION.dll
0x000007fefc860000 - 0x000007fefc8b2000 C:\Windows\system32\uxtheme.dll
0x000007fefe070000 - 0x000007fefe250000 C:\Windows\system32\ole32.dll
0x000007fefe390000 - 0x000007fefe42c000 C:\Windows\system32\CLBCatQ.DLL
0x000007fefe5c0000 - 0x000007fefe698000 C:\Windows\system32\OLEAUT32.dll
0x0000000008000000 - 0x00000000085aa000 C:\Program Files\Java\jdk1.6.0_07\jre\bin\server\jvm.dll
0x000007fefbc80000 - 0x000007fefbcba000 C:\Windows\system32\WINMM.dll
0x000007fefbc30000 - 0x000007fefbc80000 C:\Windows\system32\OLEACC.dll
0x0000000010000000 - 0x000000001000a000 C:\Program Files\Java\jdk1.6.0_07\jre\bin\hpi.dll
0x000007fefdc30000 - 0x000007fefdc38000 C:\Windows\system32\PSAPI.DLL
0x0000000000200000 - 0x000000000020e000 C:\Program Files\Java\jdk1.6.0_07\jre\bin\verify.dll
0x00000000023e0000 - 0x0000000002407000 C:\Program Files\Java\jdk1.6.0_07\jre\bin\java.dll
0x0000000002590000 - 0x00000000025a2000 C:\Program Files\Java\jdk1.6.0_07\jre\bin\zip.dll
0x00000000076b0000 - 0x00000000076c7000 C:\Program Files\Java\jdk1.6.0_07\jre\bin\net.dll
0x000007fefe430000 - 0x000007fefe474000 C:\Windows\system32\WS2_32.dll
0x000007fefe000000 - 0x000007fefe007000 C:\Windows\system32\NSI.dll
0x000007fefd090000 - 0x000007fefd0e0000 C:\Windows\system32\mswsock.dll
0x000007fefd250000 - 0x000007fefd257000 C:\Windows\System32\wship6.dll
0x0000000000210000 - 0x000000000021b000 C:\Program Files\Java\jdk1.6.0_07\jre\bin\nio.dll
0x00000000076d0000 - 0x0000000007763000 C:\Program Files\Eclipse 3.4\eclipse\configuration\org.eclipse.osgi\bundles\127\1\.cp \swt-win32-3448.dll
0x000007feff6d0000 - 0x000007feff75e000 C:\Windows\system32\comdlg32.dll
0x000007fefe7a0000 - 0x000007feff3d5000 C:\Windows\system32\SHELL32.dll
0x000007fefdce0000 - 0x000007fefdddf000 C:\Windows\system32\WININET.dll
0x0000000077710000 - 0x0000000077714000 C:\Windows\system32\Normaliz.dll
0x000007feff760000 - 0x000007feff7ba000 C:\Windows\system32\iertutil.dll
0x0000000007810000 - 0x000000000782d000 C:\Program Files\Eclipse 3.4\eclipse\configuration\org.eclipse.osgi\bundles\127\1\.cp \swt-gdip-win32-3448.dll
0x000007fefbd20000 - 0x000007fefbf3b000 C:\Windows\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144 ccf1df_1.0.6000.16386_none_56f375c7b4f24821\gdiplus.dll
0x000007fefce10000 - 0x000007fefce53000 C:\Windows\system32\rsaenh.dll
0x000007fefc0b0000 - 0x000007fefc0ed000 C:\Windows\system32\mlang.dll
0x000007fefcc00000 - 0x000007fefcc06000 C:\Windows\system32\msimg32.dll
VM Arguments:
jvm_args: -Xms256m -Xmx1024m -XX:MaxPermSize=256m
java_command: <unknown>
Launcher Type: generic
Environment Variables:
PATH=C:/Program Files/Java/jdk1.6.0_07/bin/../jre/bin/server;C:/Program Files/Java/jdk1.6.0_07/bin/../jre/bin;C:\Windows\system32;C: \Windows;C:\Windows\System32\Wbem;C:\Programme\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files\Java\jdk1.6.0_07\bin
USERNAME=Zenobios
OS=Windows_NT
PROCESSOR_IDENTIFIER=EM64T Family 6 Model 15 Stepping 11, GenuineIntel
--------------- S Y S T E M ---------------
OS: Windows Vista Build 6000
CPU:total 4 (4 cores per cpu, 1 threads per core) family 6 model 15 stepping 11, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3
Memory: 4k page, physical 4192768k(2094796k free), swap 8540224k(5996964k free)
vm_info: Java HotSpot(TM) 64-Bit Server VM (10.0-b23) for windows-amd64 JRE (1.6.0_07-b06), built on Jun 10 2008 01:06:11 by "java_re" with MS VC++ 8.0
time: Thu Jul 10 13:55:56 2008
elapsed time: 13 seconds
--------------040709000408040806000905--
Re: Eclipse 3.4 crashes [message #329920 is a reply to message #329914] |
Thu, 10 July 2008 11:16  |
Grant,
thx for pointing me to that bug. I installed jdk1.5u16, that works. It
also with the ea jdk1.7 but I'll use the jdk5 now.
Grant Gayed schrieb:
> It appears to be a bug in Sun's VM, see:
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=214092#c19
> http://bugs.sun.com/bugdatabase/view_bug.do?bug_id=6614100 (comment 26 May
> 2008)
> Using another VM (eg.- IBM, Sun 1.5.x, etc.) should work for you.
> Grant
> "Andreas Scharf" <andreas-scharf@gmx.de> wrote in message
> news:g54v41$1r2$1@build.eclipse.org...
>> Hi Achim,
>> I'm very sure I installed the 64-bit version of Eclipse, I attached the
>> configuration details of my Eclipse installation. Furhter, I installed
>> this VM:
> http://cds.sun.com/is-bin/INTERSHOP.enfinity/WFS/CDS-CDS_Dev eloper-Site/en_US/-/USD/VerifyItem-Start/jdk-6u7-windows-x64 .exe?BundledLineItemUUID=jdRIBe.mtEgAAAEbrkFTUAzu&OrderI D=11NIBe.m6IgAAAEbmkFTUAzu&ProductID=HgJIBe.o3twAAAEaQ5c GcbZW&FileName=/jdk-6u7-windows-x64.exe
>> Achim Lörke schrieb:
>>> Hi Andreas,
>>> two things look suspicious:
>>> Your VM claims to be a 1.6.10b release which is a beta version which
>>> differs a lot from the 1.6u7 VM.
> 3448.dll
>>> This looks like a 32-bit Version of Eclipse which won't run with a
>>> 64-bit VM. You must either use a 32-bit VM or download the 64-bit
>>> version of Eclipse.
>>> Achim
> *** Date: Donnerstag, 10. Juli 2008 14:21:57 Deutschland
> *** Platform Details:
> *** System properties:
> awt.toolkit=sun.awt.windows.WToolkit
> eclipse.buildId=I20080617-2000
> eclipse.commands=-os
> win32
> -ws
> win32
> -arch
> x86_64
> -showsplash
> -launcher
> -name
> Eclipse
> --launcher.library
> -startup
> 3.4\eclipse\plugins\org.eclipse.equinox.launcher_1.0.100.v20 080509-1800.jar
> -clear
> -vm
> C:\Program Files\Java\jdk1.6.0_07\bin\..\jre\bin\server\jvm.dll
> eclipse.ee.install.verify=false
> eclipse.home.location=file:/C:/Program Files/Eclipse 3.4/eclipse/
> eclipse.launcher=C:\Program Files\Eclipse 3.4\eclipse\eclipse.exe
> eclipse.p2.data.area=@config.dir/../p2
> eclipse.p2.profile=SDKProfile
> eclipse.product=org.eclipse.sdk.ide
> eclipse.startTime=1215692432278
> eclipse.vm=C:\Program Files\Java\jdk1.6.0_07\bin\..\jre\bin\server\jvm.dll
> eclipse.vmargs=-Xms256m
> -Xmx1024m
> -Djava.class.path=C:\Program Files\Eclipse
> file.encoding=Cp1252
> file.encoding.pkg=sun.io
> file.separator=\
> java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
> java.awt.printerjob=sun.awt.windows.WPrinterJob
> java.class.version=50.0
> java.endorsed.dirs=C:\Program Files\Java\jdk1.6.0_07\jre\lib\endorsed
> java.ext.dirs=C:\Program
> Files\Java\jdk1.6.0_07\jre\lib\ext;C:\Windows\Sun\Java\lib\e xt
> java.home=C:\Program Files\Java\jdk1.6.0_07\jre
> java.io.tmpdir=C:\Users\Zenobios\AppData\Local\Temp\
> java.library.path=C:\Program Files\Eclipse
> 3.4\eclipse;.;C:\Windows\Sun\Java\bin;C:\Windows\system32;C: \Windows;C:\Wind
> ows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Programm e\ATI
> java.runtime.name=Java(TM) SE Runtime Environment
> java.runtime.version=1.6.0_07-b06
> java.specification.name=Java Platform API Specification
> java.specification.vendor=Sun Microsystems Inc.
> java.specification.version=1.6
> java.vendor=Sun Microsystems Inc.
> java.vendor.url=http://java.sun.com/
> java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
> java.version=1.6.0_07
> java.vm.info=mixed mode
> java.vm.name=Java HotSpot(TM) 64-Bit Server VM
> java.vm.specification.name=Java Virtual Machine Specification
> java.vm.specification.vendor=Sun Microsystems Inc.
> java.vm.specification.version=1.0
> java.vm.vendor=Sun Microsystems Inc.
> java.vm.version=10.0-b23
> line.separator=
> org.eclipse.equinox.launcher.splash.location=C:\Program Files\Eclipse
> org.eclipse.equinox.simpleconfigurator.configUrl=file:org.ec lipse.equinox.si
> mpleconfigurator\bundles.info
> org.eclipse.update.reconcile=false
> org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,JR
> E-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5,JavaSE-1.6
> org.osgi.framework.language=de
> org.osgi.framework.os.name=WindowsVista
> org.osgi.framework.os.version=6.0.0
> org.osgi.framework.processor=x86-64
> org.osgi.framework.system.packages=javax.accessibility,javax .activation,java
> x.activity,javax.annotation,javax.annotation.processing,java x.crypto,javax.c
> rypto.interfaces,javax.crypto.spec,javax.imageio,javax.image io.event,javax.i
> mageio.metadata,javax.imageio.plugins.bmp,javax.imageio.plug ins.jpeg,javax.i
> mageio.spi,javax.imageio.stream,javax.jws,javax.jws.soap,jav ax.lang.model,ja
> vax.lang.model.element,javax.lang.model.type,javax.lang.mode l.util,javax.man
> agement,javax.management.loading,javax.management.modelmbean ,javax.managemen
> t.monitor,javax.management.openmbean,javax.management.relati on,javax.managem
> ent.remote,javax.management.remote.rmi,javax.management.time r,javax.naming,j
> avax.naming.directory,javax.naming.event,javax.naming.ldap,j avax.naming.spi,
> javax.net,javax.net.ssl,javax.print,javax.print.attribute,ja vax.print.attrib
> ute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA,jav ax.rmi.ssl,javax
> .script,javax.security.auth,javax.security.auth.callback,jav ax.security.auth
> .kerberos,javax.security.auth.login,javax.security.auth.spi, javax.security.a
> uth.x500,javax.security.cert,javax.security.sasl,javax.sound .midi,javax.soun
> d.midi.spi,javax.sound.sampled,javax.sound.sampled.spi,javax .sql,javax.sql.r
> owset,javax.sql.rowset.serial,javax.sql.rowset.spi,javax.swi ng,javax.swing.b
> order,javax.swing.colorchooser,javax.swing.event,javax.swing .filechooser,jav
> ax.swing.plaf,javax.swing.plaf.basic,javax.swing.plaf.metal, javax.swing.plaf
> .multi,javax.swing.plaf.synth,javax.swing.table,javax.swing. text,javax.swing
> .text.html,javax.swing.text.html.parser,javax.swing.text.rtf ,javax.swing.tre
> e,javax.swing.undo,javax.tools,javax.transaction,javax.trans action.xa,javax.
> xml,javax.xml.bind,javax.xml.bind.annotation,javax.xml.bind. annotation.adapt
> ers,javax.xml.bind.attachment,javax.xml.bind.helpers,javax.x ml.bind.util,jav
> ax.xml.crypto,javax.xml.crypto.dom,javax.xml.crypto.dsig,jav ax.xml.crypto.ds
> ig.dom,javax.xml.crypto.dsig.keyinfo,javax.xml.crypto.dsig.s pec,javax.xml.da
> tatype,javax.xml.namespace,javax.xml.parsers,javax.xml.soap, javax.xml.stream
> ,javax.xml.stream.events,javax.xml.stream.util,javax.xml.tra nsform,javax.xml
> .transform.dom,javax.xml.transform.sax,javax.xml.transform.s tax,javax.xml.tr
> ansform.stream,javax.xml.validation,javax.xml.ws,javax.xml.w s.handler,javax.
> xml.ws.handler.soap,javax.xml.ws.http,javax.xml.ws.soap,java x.xml.ws.spi,jav
> ax.xml.xpath,org.ietf.jgss,org.omg.CORBA,org.omg.CORBA_2_3,o rg.omg.CORBA_2_3
> .portable,org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPacka ge,org.omg.CORBA
> .portable,org.omg.CORBA.TypeCodePackage,org.omg.CosNaming,or g.omg.CosNaming.
> NamingContextExtPackage,org.omg.CosNaming.NamingContextPacka ge,org.omg.Dynam
> ic,org.omg.DynamicAny,org.omg.DynamicAny.DynAnyFactoryPackag e,org.omg.Dynami
> cAny.DynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPacka ge,org.omg.IOP.C
> odecPackage,org.omg.Messaging,org.omg.PortableInterceptor,or g.omg.PortableIn
> terceptor.ORBInitInfoPackage,org.omg.PortableServer,org.omg. PortableServer.C
> urrentPackage,org.omg.PortableServer.POAManagerPackage,org.o mg.PortableServe
> r.POAPackage,org.omg.PortableServer.portable,org.omg.Portabl eServer.ServantL
> ocatorPackage,org.omg.SendingContext,org.omg.stub.java.rmi,o rg.w3c.dom,org.w
> 3c.dom.bootstrap,org.w3c.dom.css,org.w3c.dom.events,org.w3c. dom.html,org.w3c
> .dom.ls,org.w3c.dom.ranges,org.w3c.dom.stylesheets,org.w3c.d om.traversal,org
> .w3c.dom.views ,org.xml.sax,org.xml.sax.ext,org.xml.sax.helpers
> org.osgi.framework.vendor=Eclipse
> org.osgi.framework.version=1.4.0
> org.osgi.supports.framework.extension=true
> org.osgi.supports.framework.fragment=true
> org.osgi.supports.framework.requirebundle=true
> os.arch=amd64
> os.name=Windows Vista
> os.version=6.0
> osgi.arch=x86_64
> osgi.bundles=reference:file:org.eclipse.equinox.simpleconfig urator_1.0.0.v20
> 080604.jar@1:start
> osgi.bundles.defaultStartLevel=4
> osgi.bundlestore=C:\Program Files\Eclipse
> osgi.compatibility.bootdelegation=true
> osgi.configuration.area=file:/C:/Program Files/Eclipse
> 3.4/eclipse/configuration/
> osgi.framework=file:/c:/Program Files/Eclipse
> 3.4/eclipse/plugins/org.eclipse.osgi_3.4.0.v20080605-1900.ja r
> osgi.framework.beginningstartlevel=1
> osgi.framework.shape=jar
> osgi.framework.version=3.4.0.v20080605-1900
> osgi.install.area=file:/C:/Program Files/Eclipse 3.4/eclipse/
> osgi.instance.area=file:/D:/Eigene
> Dateien/Dokumente/Workspaces/Planmodeller/
> osgi.instance.area.default=file:/C:/Users/Zenobios/workspace /
> osgi.launcherIni=eclipse
> osgi.launcherPath=.
> osgi.logfile=D:\Eigene
> Dateien\Dokumente\Workspaces\Planmodeller\.metadata\.log
> osgi.manifest.cache=C:\Program Files\Eclipse
> 3.4\eclipse\configuration\org.eclipse.osgi\manifests
> osgi.nl=de_DE
> osgi.os=win32
> osgi.splashLocation=C:\Program Files\Eclipse
> osgi.splashPath=platform:/base/plugins/org.eclipse.platform
> osgi.syspath=c:\Program Files\Eclipse 3.4\eclipse\plugins
> osgi.ws=win32
> path.separator=;
> sun.arch.data.model=64
> sun.boot.class.path=C:\Program
> Files\Java\jdk1.6.0_07\jre\lib\resources.jar;C:\Program
> Files\Java\jdk1.6.0_07\jre\lib\rt.jar;C:\Program
> Files\Java\jdk1.6.0_07\jre\lib\sunrsasign.jar;C:\Program
> Files\Java\jdk1.6.0_07\jre\lib\jsse.jar;C:\Program
> Files\Java\jdk1.6.0_07\jre\lib\jce.jar;C:\Program Files\Java\jdk1.6.0_07\jre
> \lib\charsets.jar;C:\Program Files\Java\jdk1.6.0_07\jre\classes
> sun.boot.library.path=C:\Program Files\Java\jdk1.6.0_07\jre\bin
> sun.cpu.endian=little
> sun.cpu.isalist=amd64
> sun.desktop=windows
> sun.io.unicode.encoding=UnicodeLittle
> sun.jnu.encoding=Cp1252
> sun.management.compiler=HotSpot 64-Bit Server Compiler
> sun.os.patch.level=
> user.country=DE
> user.dir=C:\Program Files\Eclipse 3.4\eclipse
> user.home=C:\Users\Zenobios
> user.language=de
> user.name=Zenobios
> user.timezone=Europe/Berlin
> user.variant=
> *** Features:
> org.eclipse.cvs (1.1.0.v20080603-7C79E8M9EI99m9c9S) "Eclipse CVS Client"
> org.eclipse.draw2d (3.4.0.v20080115-33-7w3119163_) "Graphical Editing
> Framework Draw2d"
> org.eclipse.draw2d.sdk (3.4.0.v20080115-677-8082A5655G3B9B8x422_274A)
> "Graphical Editing Framework Draw2d Developer Resources"
> org.eclipse.draw2d.source (3.4.0.v20080115-33-7w3119163_) "Graphical Editing
> org.eclipse.emf (2.4.0.v200806091234) "EMF - Eclipse Modeling Framework"
> org.eclipse.emf.codegen (2.4.0.v200806091234) "EMF Code Generation"
> org.eclipse.emf.codegen.ecore (2.4.0.v200806091234) "EMF Ecore Code
> Generator"
> org.eclipse.emf.codegen.ecore.ui (2.4.0.v200806091234) "EMF Ecore Code
> Generator UI"
> org.eclipse.emf.codegen.ui (2.4.0.v200806091234) "EMF Code Generation UI"
> org.eclipse.emf.common (2.4.0.v200806091234) "EMF Common"
> org.eclipse.emf.common.ui (2.4.0.v200806091234) "EMF Common UI"
> org.eclipse.emf.converter (2.4.0.v200806091234) "EMF Model Converter"
> org.eclipse.emf.databinding (1.0.0.v200806091234) "EMF Data Binding"
> org.eclipse.emf.databinding.edit (1.0.0.v200806091234) "EMF Edit Data
> Binding"
> org.eclipse.emf.doc (2.4.0.v200806091234) "EMF Developer Guide"
> org.eclipse.emf.ecore (2.4.0.v200806091234) "EMF Ecore"
> org.eclipse.emf.ecore.edit (2.4.0.v200806091234) "EMF Ecore Edit"
> org.eclipse.emf.ecore.editor (2.4.0.v200806091234) "EMF Sample Ecore Editor"
> org.eclipse.emf.edit (2.4.0.v200806091234) "EMF Edit"
> org.eclipse.emf.edit.ui (2.4.0.v200806091234) "EMF Edit UI"
> org.eclipse.emf.mapping (2.4.0.v200806091234) "EMF Mapping"
> org.eclipse.emf.mapping.ecore (2.4.0.v200806091234) "EMF Ecore Mapping"
> org.eclipse.emf.mapping.ecore.editor (2.4.0.v200806091234) "EMF Ecore
> Mapping Editor"
> org.eclipse.emf.mapping.ui (2.4.0.v200806091234) "EMF Mapping UI"
> org.eclipse.emf.source (2.4.0.v200806091234) "EMF Source"
> org.eclipse.emf.transaction (1.2.0.v200805130238-23-8s733I3C59379I) "EMF
> Model Transaction Core"
> org.eclipse.emf.validation (1.2.0.v200805130238-35-9oA55S5J8H5ADM) "EMF
> Validation Framework Core"
> org.eclipse.emf.workspace (1.2.0.v200805130238-23-8s733I3C59379I) "EMF Model
> Transaction Workbench Integration Core"
> org.eclipse.gef (3.4.0.v20080115-677-8082A5696H274A) "Graphical Editing
> Framework GEF"
> org.eclipse.gef.sdk (3.4.0.v20080115-7B7E-97OK5c7PDdDMPMcHNPTM3CD)
> "Graphical Editing Framework GEF Developer Resources"
> org.eclipse.gef.source (3.4.0.v20080115-677-8082A5696H274A) "Graphical
> org.eclipse.gmf (1.1.0.v20080223-0300-7c7a-EWvhJvgb_r0Gh_dz08rmLgQ)
> "Graphical Modeling Framework"
> org.eclipse.gmf.examples (1.0.100.v20080512-1200-7_-EFAE8McIJXIwd49Ti5h)
> "Graphical Modeling Framework Examples"
> org.eclipse.gmf.runtime.notation (1.1.0.v20080223-0300-21-8s733I3C3G1597E)
> "GMF Notation Model Support"
> org.eclipse.gmf.tooling (2.1.0.v20080512-1200-7W7AE8NEHhHehDgG4tL3YcN)
> "Graphical Modeling Framework Tooling"
> org.eclipse.help (1.0.0.v20080603-7r7xEHJEJkZu5nE6Q4Qrtvu6JZ9L) "Help System
> Base"
> org.eclipse.jdt (3.4.0.v20080603-2000-7o7tEAXEFpPqqoXxgaBhhhq) "Eclipse Java
> Development Tools"
> org.eclipse.ocl (1.2.0.v200805130238-34-9oA55S5I6M7JBK) "Object Constraint
> Language (OCL) 2.0 Parser/Interpreter"
> org.eclipse.pde (3.4.0.v20080603-7T7U-E_EkMNrNKb39WcMC) "PDE"
> (3.4.0.v20080610-9I96EhtEm-T_5LxIsybz-3MdGZmOA3uwv7Ka_M) "Eclipse Platform"
> org.eclipse.rcp (3.4.0.v20080324a-989JERhEk-jWnd5IY8K5tjxB) "Eclipse RCP"
> org.eclipse.sdk
> (3.4.0.v20080522-7O7S-CHEp2gcoGjmFFomLz-d5M8NdvuPgDrH17jw0Mv he) "Eclipse
> Project SDK"
> org.eclipse.team.svn (0.7.1.I20080612-1500) "Subversive SVN Team Provider
> (Incubation)"
> org.eclipse.team.svn.nl1 (0.7.1.I20080612-1500) "Subversive SVN Team
> Provider Localization (Incubation)"
> org.eclipse.team.svn.resource.ignore.rules.jdt (0.7.1.I20080612-1500)
> "Subversive JDT Ignore Extensions (Incubation)"
> org.polarion.eclipse.team.svn.connector (2.0.1.I20080612-1500) "Subversive
> SVN Connectors"
> org.polarion.eclipse.team.svn.connector.svnkit (2.0.1.I20080612-1500)
> "Subversive SVN 1.4 SVN Kit Connector"
> *** Plug-in Registry:
> com.ibm.icu (3.8.1.v20080530) "International Components for Unicode for Java
> (ICU4J)" [Active]
> com.jcraft.jsch (0.1.37.v200803061811) "JSch" [Resolved]
> com.objfac.xmleditor (2.0.9) "XMLBuddy" [Starting]
> javax.servlet (2.4.0.v200806031604) "Servlet API Bundle" [Resolved]
> javax.servlet.jsp (2.0.0.v200806031607) "Java Server Pages API Bundle"
> [Resolved]
> javax.xml (1.3.4.v200806030440) "JAXP XML" [Resolved]
> net.sourceforge.lpg.lpgjavaruntime (1.1.0.v200803061910) "SourceForge LPG"
> [Resolved]
> org.apache.ant (1.7.0.v200803061910) "Apache Ant" [Resolved]
> org.apache.batik.bridge (1.6.0.v200805290154) "Apache Batik
> Bridge/GVT/Scripting" [Resolved]
> org.apache.batik.css (1.6.0.v200805290154) "Apache Batik CSS" [Resolved]
> org.apache.batik.dom (1.6.0.v200805290154) "Apache Batik DOM" [Resolved]
> org.apache.batik.dom.svg (1.6.0.v200805290154) "Apache Batik SVG DOM"
> [Resolved]
> org.apache.batik.ext.awt (1.6.0.v200805290154) "Apache Batik AWT Utilities"
> [Resolved]
> org.apache.batik.parser (1.6.0.v200805290154) "Apache Batik Parser"
> [Resolved]
> org.apache.batik.pdf (1.6.0.v200806031500) "Apache Batik PDF" [Resolved]
> org.apache.batik.svggen (1.6.0.v200805290154) "Apache Batik SVG Generation"
> [Resolved]
> org.apache.batik.transcoder (1.6.0.v200805290154) "Apache Batik Transcoder"
> [Resolved]
> org.apache.batik.util (1.6.0.v200805290154) "Apache Batik Utilities"
> [Resolved]
> org.apache.batik.util.gui (1.6.0.v200805290154) "Apache Batik GUI Utilities"
> [Resolved]
> org.apache.batik.xml (1.6.0.v200805290154) "Apache Batik XML" [Resolved]
> org.apache.commons.el (1.0.0.v200806031608) "Apache Commons JSP 2.0
> Expression Language Interpreter" [Resolved]
> org.apache.commons.logging (1.0.4.v20080605-1930) "Apache Commons Logging
> Plug-in" [Resolved]
> org.apache.jasper (5.5.17.v200806031609) "Apache Jasper 2 Plug-in"
> [Resolved]
> org.apache.lucene (1.9.1.v20080530-1600) "Apache Lucene" [Resolved]
> org.apache.lucene.analysis (1.9.1.v20080530-1600) "Apache Lucene Analysis"
> [Resolved]
> org.apache.xerces (2.9.0.v200805270400) "Apache Xerces-J" [Resolved]
> org.apache.xml.resolver (1.2.0.v200806030312) "Apache XmlResolver"
> [Resolved]
> org.apache.xml.serializer (2.7.1.v200806030322) "Apache XML Commons
> Serializer" [Resolved]
> org.eclipse.ant.core (3.2.0.v20080529) "Ant Build Tool Core" [Starting]
> org.eclipse.ant.ui (3.3.0.v20080529) "Ant UI" [Starting]
> org.eclipse.compare (3.4.0.I20080604) "Compare Support" [Active]
> org.eclipse.core.boot (3.1.100.v20080218) "Core Boot" [Starting]
> org.eclipse.core.commands (3.4.0.I20080509-2000) "Commands" [Resolved]
> org.eclipse.core.contenttype (3.3.0.v20080604-1400) "Eclipse Content
> Mechanism" [Active]
> org.eclipse.core.databinding (1.1.0.I20080527-2000) "JFace Data Binding"
> [Active]
> org.eclipse.core.databinding.beans (1.1.0.I20080508-2000a) "JFace Data
> Binding for JavaBeans" [Resolved]
> org.eclipse.core.expressions (3.4.0.v20080603-2000) "Expression Language"
> [Active]
> org.eclipse.core.filebuffers (3.4.0.v20080603-2000) "File Buffers" [Active]
> org.eclipse.core.filesystem (1.2.0.v20080604-1400) "Core File Systems"
> [Active]
> org.eclipse.core.jobs (3.4.0.v20080512) "Eclipse Jobs Mechanism" [Active]
> org.eclipse.core.net (1.1.0.I20080604) "Internet Connection Management"
> [Active]
> org.eclipse.core.resources (3.4.0.v20080604-1400) "Core Resource Management"
> [Active]
> org.eclipse.core.resources.compatibility (3.4.0.v20080604-1400) "Core
> Resource Management Compatibility Fragment" [Resolved]
> org.eclipse.core.runtime (3.4.0.v20080512) "Core Runtime" [Active]
> org.eclipse.core.runtime.compatibility (3.2.0.v20071008) "Core Runtime
> Plug-in Compatibility" [Active]
> org.eclipse.core.runtime.compatibility.auth (3.2.100.v20070502)
> "Authorization Compatibility Plug-in" [Active]
> org.eclipse.core.runtime.compatibility.registry (3.2.200.v20080610) "Eclipse
> Registry Compatibility Fragment" [Resolved]
> org.eclipse.core.variables (3.2.100.v20080529-1300) "Core Variables"
> [Active]
> org.eclipse.cvs (1.0.100.v20080603) "Eclipse CVS Client" [Starting]
> org.eclipse.debug.core (3.4.0.v20080612) "Debug Core" [Active]
> org.eclipse.debug.ui (3.4.0.v20080529-1300) "Debug UI" [Starting]
> org.eclipse.draw2d (3.4.0.v20080529) "Graphical Editing Framework Draw2d"
> [Starting]
> org.eclipse.draw2d.doc.isv (3.4.0.v20080606) "Graphical Editing Framework
> Draw2d Documentation" [Starting]
> Framework Draw2d Developer Resources" [Resolved]
> org.eclipse.ecf (2.0.0.v20080611-1715) "Eclipse Communication Framework
> (ECF)" [Starting]
> org.eclipse.ecf.filetransfer (2.0.0.v20080611-1715) "ECF Filetransfer API"
> [Starting]
> org.eclipse.ecf.identity (2.0.0.v20080611-1715) "ECF Identity API"
> [Starting]
> org.eclipse.ecf.provider.filetransfer (2.0.0.v20080611-1715) "ECF
> Filetransfer Provider" [Starting]
> org.eclipse.ecf.provider.filetransfer.ssl (1.0.0.v20080611-1715) "ECF
> Filetransfer Provider" [Resolved]
> org.eclipse.ecf.ssl (1.0.0.v20080611-1715) "Eclipse Communication Framework
> (ECF)" [Resolved]
> [Starting]
> org.eclipse.emf.ant (2.4.0.v200806091234) "EMF Ant Tasks" [Starting]
> org.eclipse.emf.cheatsheets (2.4.0.v200806091234) "EMF Cheat Sheets"
> [Starting]
> [Starting]
> Generator" [Starting]
> Generator UI" [Starting]
> [Starting]
> org.eclipse.emf.common (2.4.0.v200806091234) "EMF Common" [Active]
> org.eclipse.emf.common.ui (2.4.0.v200806091234) "EMF Common UI" [Active]
> [Starting]
> [Starting]
> Binding" [Starting]
> org.eclipse.emf.doc (2.4.0.v200806091234) "EMF Developer Guide" [Starting]
> org.eclipse.emf.ecore (2.4.0.v200806091234) "EMF Ecore" [Active]
> org.eclipse.emf.ecore.change (2.4.0.v200806091234) "EMF Change Model"
> [Starting]
> org.eclipse.emf.ecore.change.edit (2.4.0.v200806091234) "EMF Change Edit"
> [Starting]
> org.eclipse.emf.ecore.edit (2.4.0.v200806091234) "EMF Ecore Edit" [Active]
> [Starting]
> org.eclipse.emf.ecore.xmi (2.4.0.v200806091234) "EMF XML/XMI Persistence"
> [Active]
> org.eclipse.emf.edit (2.4.0.v200806091234) "EMF Edit" [Active]
> org.eclipse.emf.edit.ui (2.4.0.v200806091234) "EMF Edit UI" [Starting]
> org.eclipse.emf.example.installer (1.0.0.v200806091234) "EMF Example
> Installer" [Starting]
> org.eclipse.emf.examples.library (2.4.0.v200806091234) "EMF Extended Library
> Model Example" [Starting]
> org.eclipse.emf.examples.library.edit (2.4.0.v200806091234) "EMF Extended
> Library Edit Example" [Starting]
> org.eclipse.emf.examples.library.editor (2.4.0.v200806091234) "EMF Extended
> Library Editor Example" [Starting]
> org.eclipse.emf.exporter (2.4.0.v200806091234) "EMF Model Exporter"
> [Starting]
> org.eclipse.emf.importer (2.4.0.v200806091234) "EMF Model Importer"
> [Starting]
> org.eclipse.emf.importer.ecore (2.4.0.v200806091234) "EMF Ecore Importer"
> [Starting]
> org.eclipse.emf.importer.java (2.4.0.v200806091234) "EMF Annotated Java
> Importer" [Starting]
> org.eclipse.emf.importer.rose (2.4.0.v200806091234) "EMF Rose Importer"
> [Starting]
> org.eclipse.emf.mapping (2.4.0.v200806091234) "EMF Mapping" [Starting]
> [Starting]
> Mapping Editor" [Starting]
> org.eclipse.emf.mapping.ecore2ecore (2.4.0.v200806091234) "EMF Ecore to
> Ecore Mapping" [Starting]
> org.eclipse.emf.mapping.ecore2ecore.editor (2.4.0.v200806091234) "EMF Ecore
> to Ecore Mapping Editor" [Starting]
> org.eclipse.emf.mapping.ecore2xml (2.4.0.v200806091234) "EMF Ecore to XML
> Mapping" [Starting]
> org.eclipse.emf.mapping.ecore2xml.ui (2.4.0.v200806091234) "EMF Ecore to XML
> org.eclipse.emf.mapping.ui (2.4.0.v200806091234) "EMF Mapping UI" [Starting]
> org.eclipse.emf.source (2.4.0.v200806091234) "EMF Source" [Resolved]
> org.eclipse.emf.transaction (1.2.0.v200805130238) "EMF Model Transaction
> Core" [Starting]
> org.eclipse.emf.transaction.ui (1.2.0.v200805130238) "EMF Model Transaction
> UI" [Starting]
> org.eclipse.emf.validation (1.2.0.v200805170232) "EMF Validation Framework
> Core" [Starting]
> org.eclipse.emf.validation.ui (1.2.0.v200805130238) "EMF Validation
> Framework UI" [Starting]
> org.eclipse.emf.validation.ui.ide (1.2.0.v200805130238) "EMF Validation
> Framework UI IDE" [Starting]
> org.eclipse.emf.workspace (1.2.0.v200805130238) "EMF Model Transaction
> Workbench Integration Core" [Starting]
> org.eclipse.emf.workspace.ui (1.2.0.v200805130238) "EMF Model Transaction
> Workbench Integration UI" [Starting]
> org.eclipse.equinox.app (1.1.0.v20080421-2006) "Equinox Application
> Container" [Active]
> org.eclipse.equinox.common (3.4.0.v20080421-2006) "Common Eclipse Runtime"
> [Active]
> org.eclipse.equinox.frameworkadmin (1.0.0.v20080430-1750) "Equinox Framework
> Admin" [Active]
> org.eclipse.equinox.frameworkadmin.equinox (1.0.0.v20080529-1225) "Equinox
> Framework Admin for Equinox" [Active]
> org.eclipse.equinox.http.jetty (1.1.0.v20080425) "Jetty Http Service"
> [Starting]
> org.eclipse.equinox.http.registry (1.0.100.v20080427-0830) "Http Service
> Registry Extensions" [Resolved]
> org.eclipse.equinox.http.servlet (1.0.100.v20080427-0830) "Http Services
> Servlet" [Starting]
> org.eclipse.equinox.jsp.jasper (1.0.100.v20080427-0830) "Jasper Jsp Support
> Bundle" [Starting]
> org.eclipse.equinox.jsp.jasper.registry (1.0.0.v20080427-0830) "Jasper Jsp
> Registry Support Plug-in" [Starting]
> org.eclipse.equinox.launcher (1.0.100.v20080509-1800) "Equinox Launcher"
> [Resolved]
> org.eclipse.equinox.launcher.win32.win32.x86_64 (1.0.100.v20080509-1800)
> "Equinox Launcher Win32 X86_64 Fragment" [Resolved]
> org.eclipse.equinox.p2.artifact.repository (1.0.0.v20080609-0850) "Equinox
> Provisioning Artifact Repository Support" [Starting]
> org.eclipse.equinox.p2.console (1.0.0.v20080514-1900) "Equinox Provisioning
> Console" [Starting]
> org.eclipse.equinox.p2.core (1.0.0.v20080530-1237) "Equinox Provisioning
> Core" [Active]
> org.eclipse.equinox.p2.director (1.0.0.v20080604) "Equinox Provisioning
> Director" [Active]
> org.eclipse.equinox.p2.director.app (1.0.0.v20080604) "Equinox Provisioning
> Director Application" [Starting]
> org.eclipse.equinox.p2.directorywatcher (1.0.0.v20080505-1850) "Equinox
> Provisioning Directory Watcher" [Active]
> org.eclipse.equinox.p2.engine (1.0.0.v20080522-1735) "Equinox Provisioning
> Engine" [Active]
> org.eclipse.equinox.p2.exemplarysetup (1.0.0.v20080427-2136) "Equinox
> Provisioning Exemplary Setup" [Active]
> org.eclipse.equinox.p2.extensionlocation (1.0.0.v20080523-0001) "Extension
> Location Repository Support" [Starting]
> org.eclipse.equinox.p2.garbagecollector (1.0.0.v20080506-1939) "Provisioning
> Garbage Collector" [Active]
> org.eclipse.equinox.p2.jarprocessor (1.0.0.v20080514-1900) "Equinox
> Provisioning JAR Processor" [Resolved]
> org.eclipse.equinox.p2.metadata (1.0.0.v20080514-1900) "Equinox Provisioning
> Metadata" [Active]
> org.eclipse.equinox.p2.metadata.generator (1.0.0.v20080604) "Equinox
> Provisioning Metadata Generator" [Starting]
> org.eclipse.equinox.p2.metadata.repository (1.0.0.v20080604) "Equinox
> Provisioning Metadata Repository" [Active]
> org.eclipse.equinox.p2.reconciler.dropins (1.0.0.v20080611) "Dropin
> Reconciler Plug-in" [Active]
> org.eclipse.equinox.p2.touchpoint.eclipse (1.0.0.v20080529-1225) "Equinox
> Provisioning Eclipse Touchpoint" [Starting]
> org.eclipse.equinox.p2.touchpoint.natives (1.0.0.v20080505-1850) "Equinox
> Provisioning Native Touchpoint" [Starting]
> org.eclipse.equinox.p2.ui (1.0.0.v20080530-1237) "Equinox Provisioning UI
> Support" [Active]
> org.eclipse.equinox.p2.ui.sdk (1.0.0.v20080605-1731) "Equinox Provisioning
> Platform Update Support" [Active]
> org.eclipse.equinox.p2.updatechecker (1.0.0.v20080427-2136) "Equinox
> Provisioning Update Checker" [Active]
> org.eclipse.equinox.p2.updatesite (1.0.0.v20080529-1800) "Update site
> repository adapter bundle (Incubation)" [Starting]
> org.eclipse.equinox.preferences (3.2.200.v20080421-2006) "Eclipse
> Preferences Mechanism" [Active]
> org.eclipse.equinox.registry (3.4.0.v20080516-0950) "Extension Registry
> Support" [Active]
> org.eclipse.equinox.security (1.0.0.v20080512-1800) "Equinox Java
> Authentication and Authorization Service (JAAS)" [Active]
> org.eclipse.equinox.security.ui (1.0.0.v20080603-1810) "Equinox Security
> Default UI" [Active]
> org.eclipse.equinox.simpleconfigurator (1.0.0.v20080604) "Simple
> Configurator" [Active]
> org.eclipse.equinox.simpleconfigurator.manipulator (1.0.0.v20080427-2136)
> "Simple Configurator Manipulator" [Active]
> org.eclipse.gef (3.4.0.v20080526) "Graphical Editing Framework GEF"
> [Starting]
> org.eclipse.gef.doc.isv (3.4.0.v20080606) "Graphical Editing Framework GEF
> org.eclipse.gef.examples.ui.pde (3.4.0.v20080226) "Graphical Editing
> Framework Example Plug-ins" [Starting]
> Editing Framework GEF Developer Resources" [Resolved]
> org.eclipse.gmf (1.0.0.v20080425-1959) "Graphical Modeling Framework"
> [Starting]
> org.eclipse.gmf.bridge (1.1.0.v20080528-1052) "GMF Models Bridging Plug-in"
> [Starting]
> org.eclipse.gmf.bridge.trace (1.0.100.v20080425-1959) "GMF Models Bridge
> Tracing Plug-in" [Starting]
> org.eclipse.gmf.bridge.ui (1.1.100.v20080417-1610) "GMF Tooling UI"
> [Starting]
> org.eclipse.gmf.bridge.ui.dashboard (2.0.0.v20080417-1610) "GMF Dashboard"
> [Starting]
> org.eclipse.gmf.codegen (2.1.0.v20080610-1132) "GMF GenModel and Code
> Generation" [Starting]
> org.eclipse.gmf.codegen.edit (2.1.0.v20080610-1132) "GMF GenModel Edit
> Support" [Starting]
> org.eclipse.gmf.codegen.lite (1.1.100.v20080507-1326) "GMF Pure-GEF Code
> Generation Plug-in" [Starting]
> org.eclipse.gmf.codegen.lite.ui (1.1.0.v20080425-1959) "GMF Pure-GEF Code
> Generation UI" [Starting]
> org.eclipse.gmf.codegen.ui (1.1.0.v20080512-1200) "GMF Code Generation UI"
> [Starting]
> org.eclipse.gmf.common (1.1.1.v20080610-1132) "GMF Tooling Commons Plug-in"
> [Starting]
> org.eclipse.gmf.ecore.editor (2.0.100.v20080610-1132) "ECore Sample Diagram
> Plugin" [Active]
> org.eclipse.gmf.examples (1.0.100.v20080425-1959) "Graphical Modeling
> Framework Examples" [Starting]
> org.eclipse.gmf.examples.runtime.common.service (1.0.100.v20080425-1959)
> "GMF Service Example Plug-in" [Starting]
> org.eclipse.gmf.examples.runtime.diagram.decorator (1.0.100.v20080425-1959)
> "GMF Diagram Decoration Example Plug-in" [Starting]
> org.eclipse.gmf.examples.runtime.diagram.geoshapes (1.0.100.v20080425-1959)
> "GMF Geometric Shapes" [Starting]
> org.eclipse.gmf.examples.runtime.diagram.layout (1.0.100.v20080425-1959)
> "GMF Diagram Services Layout Example Plug-in" [Starting]
> org.eclipse.gmf.examples.runtime.diagram.logic (1.0.200.v20080425-1959) "GMF
> Logic Shapes" [Starting]
> org.eclipse.gmf.examples.runtime.diagram.logic.model
> (1.0.100.v20080425-1959) "GMF Logicsemantic Model" [Starting]
> org.eclipse.gmf.examples.runtime.diagram.logic.model.edit
> (1.0.100.v20080425-1959) "GMF Logicsemantic Edit Support" [Starting]
> org.eclipse.gmf.examples.runtime.diagram.logic.model.editor
> (1.0.100.v20080425-1959) "GMF Logicsemantic Editor" [Starting]
> org.eclipse.gmf.examples.runtime.emf.clipboard (1.0.100.v20080425-1959) "GMF
> Clipboard Support Example Plug-in" [Starting]
> org.eclipse.gmf.examples.ui.pde (1.0.200.v20080425-1959) "GMF Examples
> Plug-in" [Starting]
> org.eclipse.gmf.graphdef (2.0.100.v20080528-1052) "GMF Graphical Definition"
> [Resolved]
> org.eclipse.gmf.graphdef.codegen (2.0.100.v20080528-1052) "Graphical
> Definition Code Generator" [Starting]
> org.eclipse.gmf.graphdef.codegen.ui (1.0.100.v20080425-1959) "Graphical
> Definition Code Generator UI Support" [Resolved]
> org.eclipse.gmf.graphdef.edit (2.0.100.v20080610-1132) "GMFGraph Edit
> Support" [Starting]
> org.eclipse.gmf.graphdef.editor (1.0.1.v20080610-1132) "GMFGraph Editor
> Plugin" [Starting]
> org.eclipse.gmf.map (2.1.0.v20080521) "GMF Mapping Model" [Starting]
> org.eclipse.gmf.map.edit (2.1.0.v20080610-1132) "GMF Mapping Edit Support"
> [Starting]
> org.eclipse.gmf.map.editor (1.0.0.v20080425-1959) "GMF Mapping Diagram
> Plugin" [Starting]
> org.eclipse.gmf.runtime.common.core (1.1.0.v20080425-1959) "GMF Common Core"
> [Starting]
> org.eclipse.gmf.runtime.common.ui (1.1.0.v20080512-1200) "GMF Common UI"
> [Starting]
> org.eclipse.gmf.runtime.common.ui.action (1.1.0.v20080425-1959) "GMF Common
> UI Action" [Starting]
> org.eclipse.gmf.runtime.common.ui.action.ide (1.1.0.v20080425-1959) "GMF
> Common UI Action IDE" [Starting]
> org.eclipse.gmf.runtime.common.ui.printing (1.1.0.v20080425-1959) "GMF
> Printing" [Starting]
> org.eclipse.gmf.runtime.common.ui.printing.win32 (1.1.0.v20080612-1355) "GMF
> Printing for Win32" [Resolved]
> org.eclipse.gmf.runtime.common.ui.services (1.1.0.v20080612-1229) "GMF
> Common UI Services" [Starting]
> org.eclipse.gmf.runtime.common.ui.services.action (1.1.0.v20080507-2230)
> "GMF Common UI Action Services" [Starting]
> org.eclipse.gmf.runtime.common.ui.services.dnd (1.1.0.v20080425-1959) "GMF
> Common UI DND Services" [Starting]
> org.eclipse.gmf.runtime.common.ui.services.dnd.ide (1.1.0.v20080425-1959)
> "GMF Common UI DND IDE Services" [Starting]
> org.eclipse.gmf.runtime.common.ui.services.properties (1.1.0.v20080425-1959)
> "GMF Common UI Properties Service Framework" [Starting]
> org.eclipse.gmf.runtime.diagram.core (1.1.0.v20080425-1959) "GMF Diagram
> Core" [Active]
> org.eclipse.gmf.runtime.diagram.ui (1.1.0.v20080610-1132) "GMF Diagram UI"
> [Starting]
> org.eclipse.gmf.runtime.diagram.ui.actions (1.1.0.v20080603-1553) "GMF
> Diagram Actions" [Starting]
> org.eclipse.gmf.runtime.diagram.ui.dnd (1.1.0.v20080425-1959) "GMF Diagram
> Browse" [Starting]
> org.eclipse.gmf.runtime.diagram.ui.geoshapes (1.1.0.v20080503-1740) "GMF
> org.eclipse.gmf.runtime.diagram.ui.printing (1.1.0.v20080501-1739) "GMF
> Diagram Printing" [Starting]
> org.eclipse.gmf.runtime.diagram.ui.printing.render (1.1.0.v20080425-1959)
> "GMF Diagram UI Printing Render Plug-In" [Starting]
> org.eclipse.gmf.runtime.diagram.ui.properties (1.1.0.v20080603-1553) "GMF
> Diagram UI Properties" [Starting]
> org.eclipse.gmf.runtime.diagram.ui.providers (1.1.0.v20080503-1740) "GMF
> Diagram Providers" [Starting]
> org.eclipse.gmf.runtime.diagram.ui.providers.ide (1.1.0.v20080425-1959) "GMF
> Diagram Providers IDE" [Starting]
> org.eclipse.gmf.runtime.diagram.ui.render (1.1.0.v20080603-1553) "GMF
> Diagram UI Render Plug-In" [Starting]
> org.eclipse.gmf.runtime.diagram.ui.resources.editor (1.1.0.v20080425-1959)
> "GMF Diagram UI Resources Editor Plug-In" [Starting]
> org.eclipse.gmf.runtime.diagram.ui.resources.editor.ide
> (1.1.0.v20080425-1959) "GMF IDE Editor" [Starting]
> org.eclipse.gmf.runtime.draw2d.ui (1.1.0.v20080610-1132) "GMF Draw2d
> Additions" [Starting]
> org.eclipse.gmf.runtime.draw2d.ui.render (1.1.0.v20080507-2230) "GMF Draw2d
> Image Rendering Additions" [Starting]
> org.eclipse.gmf.runtime.draw2d.ui.render.awt (1.1.0.v20080603-1553) "GMF
> Draw2d Image AWT based Rendering Additions" [Starting]
> org.eclipse.gmf.runtime.emf.clipboard.core (1.1.0.v20080425-1959) "GMF EMF
> Clipboard Support" [Starting]
> org.eclipse.gmf.runtime.emf.commands.core (1.1.0.v20080425-1959) "GMF
> Commands" [Starting]
> org.eclipse.gmf.runtime.emf.core (1.1.0.v20080425-1959) "GMF Modeling
> Service Layer" [Starting]
> org.eclipse.gmf.runtime.emf.type.core (1.1.0.v20080425-1959) "GMF EMF Type
> Core" [Starting]
> org.eclipse.gmf.runtime.emf.type.ui (1.1.0.v20080425-1959) "GMF EMF Type UI"
> [Starting]
> org.eclipse.gmf.runtime.emf.ui (1.1.0.v20080516-1748) "GMF MSL UI"
> [Starting]
> org.eclipse.gmf.runtime.emf.ui.properties (1.1.0.v20080425-1959) "GMF EMF UI
> Properties Providers" [Starting]
> org.eclipse.gmf.runtime.gef.ui (1.1.0.v20080503-1740) "GMF GEF Additions"
> [Starting]
> org.eclipse.gmf.runtime.lite (1.0.0.v20080425-1959) "GMF Pure-GEF Runtime"
> [Starting]
> org.eclipse.gmf.runtime.notation (1.1.0.v20080507-1326) "GMF Notation Model
> Support" [Starting]
> org.eclipse.gmf.runtime.notation.edit (1.1.0.v20080507-1326) "GMF Notation
> org.eclipse.gmf.runtime.notation.providers (1.1.0.v20080425-1959) "GMF
> Notation Metamodel" [Starting]
> org.eclipse.gmf.tooldef (2.0.0.v20080417-1610) "GMF Tooling Model"
> [Starting]
> org.eclipse.gmf.tooldef.edit (2.0.0.v20080610-1132) "GMF Tooling Edit
> Support" [Starting]
> org.eclipse.gmf.tooling (2.1.0.v20080425-1959) "Graphical Modeling Framework
> Tooling" [Starting]
> org.eclipse.gmf.validate (1.1.0.v20080603-1553) "GMF Validation" [Starting]
> org.eclipse.gmf.xpand (1.1.0.v20080528-1052) "GMF Xpand Template Engine"
> [Starting]
> org.eclipse.gmf.xpand.editor (1.0.0.v20080425-1959) "GMF Xpand Editor
> Plug-in" [Starting]
> org.eclipse.help (3.3.100.v20080610) "Help System Core" [Active]
> org.eclipse.help.appserver (3.1.300.v20080507) "Help Application Server"
> [Starting]
> org.eclipse.help.base (3.3.100.v20080617) "Help System Base" [Starting]
> org.eclipse.help.ui (3.3.100.v20080521) "Help System UI" [Starting]
> org.eclipse.help.webapp (3.3.100.v20080528) "Help System Webapp" [Starting]
> org.eclipse.jdt (3.4.0.v20080603-2000) "Eclipse Java Development Tools"
> [Resolved]
> org.eclipse.jdt.apt.core (3.3.100.v20080513-1235) "Java Annotation
> Processing Core" [Active]
> org.eclipse.jdt.apt.pluggable.core (1.0.100.v20080407-1345) "Java Compiler
> Apt IDE" [Active]
> org.eclipse.jdt.apt.ui (3.3.100.v20080407-1345) "Java Annotation Processing
> UI" [Starting]
> org.eclipse.jdt.compiler.apt (1.0.100.v20080513-1235) "Java Compiler Apt"
> [Resolved]
> org.eclipse.jdt.compiler.tool (1.0.100.v_874) "Java Compiler Tool Support"
> [Resolved]
> org.eclipse.jdt.core (3.4.0.v_874) "Java Development Tools Core" [Active]
> org.eclipse.jdt.core.manipulation (1.2.0.v20080603-2000) "Java Code
> Manipulation Functionality" [Active]
> org.eclipse.jdt.debug (3.4.0.v20080604) "JDI Debug Model" [Starting]
> org.eclipse.jdt.debug.ui (3.3.0.v20080603) "JDI Debug UI" [Starting]
> org.eclipse.jdt.doc.isv (3.4.0.v20080612-1340) "Eclipse JDT Plug-in
> Developer Guide" [Resolved]
> org.eclipse.jdt.doc.user (3.4.0.v20080612-1340) "Eclipse Java development
> user guide" [Resolved]
> org.eclipse.jdt.junit (3.4.0.v20080603-2000) "Java Development Tools JUnit
> support" [Starting]
> org.eclipse.jdt.junit.runtime (3.3.0.v20080603-2000) "Java Development Tools
> JUnit runtime support" [Resolved]
> org.eclipse.jdt.junit4.runtime (1.0.200.v20080603-2000) "Java Development
> Tools JUnit4 runtime support" [Resolved]
> org.eclipse.jdt.launching (3.4.0.v20080529-1300) "Java Development Tools
> Launching Support" [Active]
> org.eclipse.jdt.ui (3.4.0.v20080603-2000) "Java Development Tools UI"
> [Active]
> org.eclipse.jface (3.4.0.I20080606-1300) "JFace" [Active]
> org.eclipse.jface.databinding (1.2.0.I20080515-2000a) "JFace Data Binding
> for SWT and JFace" [Resolved]
> org.eclipse.jface.text (3.4.0.v20080603-2000) "JFace Text" [Resolved]
> org.eclipse.jsch.core (1.1.100.I20080604) "JSch Core" [Starting]
> org.eclipse.jsch.ui (1.1.100.I20080415) "JSch UI" [Starting]
> org.eclipse.ltk.core.refactoring (3.4.0.v20080603-2000) "Refactoring Core"
> [Active]
> org.eclipse.ltk.ui.refactoring (3.4.0.v20080605-1800) "Refactoring UI"
> [Active]
> org.eclipse.ocl (1.2.0.v200806091438) "Object Constraint Language (OCL) 2.0
> Parser/Interpreter" [Starting]
> org.eclipse.ocl.ecore (1.2.0.v200805130238) "OCL 2.0 Binding for Ecore"
> [Starting]
> org.eclipse.osgi (3.4.0.v20080605-1900) "OSGi System Bundle" [Active]
> org.eclipse.osgi.services (3.1.200.v20071203) "OSGi Release 4.0.1 Services"
> [Resolved]
> org.eclipse.osgi.util (3.1.300.v20080303) "OSGi Release 4.0.1 Utility
> Classes" [Resolved]
> org.eclipse.pde (3.4.0.v20080603) "PDE" [Active]
> org.eclipse.pde.api.tools (1.0.0.v20080529-1150) "API Tools" [Starting]
> org.eclipse.pde.api.tools.ui (1.0.0.v20080603) "API Tools UI" [Starting]
> org.eclipse.pde.build (3.4.0.v20080604) "Plug-in Development Environment
> Build Support" [Starting]
> org.eclipse.pde.core (3.4.0.v20080604-2000) "PDE Core" [Active]
> org.eclipse.pde.doc.user (3.3.0.v20080611-1530) "PDE User Guide" [Resolved]
> org.eclipse.pde.junit.runtime (3.4.0.v20080529-1800) "PDE JUnit Plug-in
> Test" [Resolved]
> org.eclipse.pde.p2.ui (1.0.0.v20080604-2000) "PDE p2 UI" [Starting]
> org.eclipse.pde.runtime (3.4.0.v20080530-1200) "PDE Runtime" [Starting]
> org.eclipse.pde.ui (3.4.0.v20080530) "PDE UI" [Active]
> org.eclipse.pde.ui.templates (3.4.0.v20080514-1500) "PDE Templates"
> [Starting]
> org.eclipse.platform (3.3.100.v200806172000) "Eclipse Platform" [Resolved]
> org.eclipse.platform.doc.isv (3.4.0.v20080613-1330) "Eclipse Platform
> Plug-in Developer Guide" [Resolved]
> org.eclipse.platform.doc.user (3.4.0.v20080612-1340) "Eclipse Workbench User
> Guide" [Resolved]
> org.eclipse.rcp (3.4.0.v20080507) "Eclipse RCP" [Starting]
> org.eclipse.sdk (3.4.0.v200806172000) "Eclipse Project SDK" [Starting]
> org.eclipse.search (3.4.0.v20080603-2000) "Search Support" [Starting]
> org.eclipse.swt (3.4.0.v3448f) "Standard Widget Toolkit" [Resolved]
> org.eclipse.swt.win32.win32.x86_64 (3.4.0.v3448f) "Standard Widget Toolkit
> for Windows" [Resolved]
> org.eclipse.team.core (3.4.0.I20080605) "Team Support Core" [Active]
> org.eclipse.team.cvs.core (3.3.100.I20080605) "CVS Team Provider Core"
> [Starting]
> org.eclipse.team.cvs.ssh (3.2.100.I20080604) "CVS SSH Core" [Starting]
> org.eclipse.team.cvs.ssh2 (3.2.200.I20080604) "CVS SSH2" [Starting]
> org.eclipse.team.cvs.ui (3.3.100.I20080604) "CVS Team Provider UI"
> [Starting]
> (Incubation)" [Resolved]
> org.eclipse.team.svn.core (0.7.1.I20080612-1500) "Subversive SVN Team
> Provider Core Plug-in (Incubation)" [Active]
> org.eclipse.team.svn.core.nl1 (0.7.1.I20080612-1500) "Localization
> org.eclipse.team.svn.help (0.7.1.I20080612-1500) "Subversive SVN Team
> Provider User Guide Plug-in (Incubation)" [Resolved]
> Provider Localization (Incubation)" [Resolved]
> "Subversive JDT Ignore Extensions (Incubation)" [Resolved]
> org.eclipse.team.svn.ui (0.7.1.I20080612-1500) "Subversive SVN Team Provider
> UI Plug-in (Incubation)" [Active]
> org.eclipse.team.svn.ui.nl1 (0.7.1.I20080612-1500) "Localization
> org.eclipse.team.ui (3.4.0.I20080604) "Team Support UI" [Active]
> org.eclipse.text (3.4.0.v20080605-1800) "Text" [Resolved]
> org.eclipse.ui (3.4.0.I20080610-1200) "Eclipse UI" [Active]
> org.eclipse.ui.browser (3.2.200.v20080507) "Browser Support" [Starting]
> org.eclipse.ui.cheatsheets (3.3.100.v20080508) "Cheat Sheets" [Starting]
> org.eclipse.ui.console (3.3.0.v20080529-1300) "Console" [Active]
> org.eclipse.ui.editors (3.4.0.v20080603-2000) "Default Text Editor" [Active]
> org.eclipse.ui.externaltools (3.2.0.v20080514-1542) "External Tools"
> [Starting]
> org.eclipse.ui.forms (3.3.100.v20080611) "Eclipse Forms" [Starting]
> org.eclipse.ui.ide (3.4.0.I20080606-1300) "Eclipse IDE UI" [Active]
> org.eclipse.ui.ide.application (1.0.0.I20080603-2000) "Eclipse IDE UI
> Application" [Resolved]
> org.eclipse.ui.intro (3.2.200.v20080610) "Welcome Framework" [Starting]
> org.eclipse.ui.intro.universal (3.2.200.v20080508) "Universal Welcome"
> [Starting]
> org.eclipse.ui.navigator (3.3.100.I20080606-1300) "Common Navigator View"
> [Starting]
> org.eclipse.ui.navigator.resources (3.3.100.I20080606-1300) "Navigator
> Workbench Components" [Starting]
> org.eclipse.ui.net (1.0.0.I20080605) "Internet Connection Management UI"
> [Active]
> org.eclipse.ui.presentations.r21 (3.2.100.I20080512-2000) "R21 Presentation
> Plug-in" [Starting]
> org.eclipse.ui.views (3.3.0.I20080509-2000) "Views" [Active]
> org.eclipse.ui.views.log (1.0.0.v20080522-2200) "Log View" [Active]
> org.eclipse.ui.views.properties.tabbed (3.4.0.I20080527-2000) "Tabbed
> Properties View" [Starting]
> org.eclipse.ui.win32 (3.2.100.v20080408-0800) "Eclipse UI Win32
> Enhancements" [Resolved]
> org.eclipse.ui.workbench (3.4.0.I20080606-1300) "Workbench" [Active]
> org.eclipse.ui.workbench.compatibility (3.2.0.I20080509-2000) "Workbench
> Compatibility" [Resolved]
> org.eclipse.ui.workbench.texteditor (3.4.0.v20080603-2000) "Text Editor
> Framework" [Active]
> org.eclipse.update.configurator (3.2.200.v20080417) "Install/Update
> org.eclipse.update.core (3.2.200.v20080515) "Install/Update Core" [Active]
> org.eclipse.update.core.win32 (3.2.100.v20080107) "Install/Update Core for
> Windows" [Resolved]
> org.eclipse.update.scheduler (3.2.100.v20080404) "Automatic Updates
> Scheduler" [Active]
> org.eclipse.update.ui (3.2.100.v20080318) "Install/Update UI" [Starting]
> org.junit (3.8.2.v20080602-1318) "JUnit Testing Framework" [Resolved]
> org.junit4 (4.3.1) "JUnit Testing Framework Version 4" [Resolved]
> org.mortbay.jetty (5.1.14.v200806031611) "Jetty WebServer" [Resolved]
> org.objectweb.asm (3.1.0.v200803061910) "ASM" [Resolved]
> SVN Connectors" [Resolved]
> "Subversive SVN 1.4 SVN Kit Connector" [Active]
> org.sat4j.core (2.0.0.v20080602) "SAT4J Core" [Resolved]
> org.sat4j.pb (2.0.0.v20080602) "SAT4J Pseudo" [Resolved]
> org.w3c.css.sac (1.3.0.v200805290154) "W3C CSS SAC" [Resolved]
> org.w3c.dom.smil (1.0.0.v200806040011) "W3C SMIL DOM" [Resolved]
> org.w3c.dom.svg (1.1.0.v200806040011) "W3C SVG DOM" [Resolved]
> *** User Preferences:
> #Thu Jul 10 14:21:57 CEST 2008
> /configuration/org.eclipse.equinox.p2.artifact.repository/re positories/file\
> :_C\:_Program\ Files_Eclipse\
> 3.4_eclipse_configuration_org.eclipse.osgi_bundles_60_data_l istener_11498082
> 44_/version=1.0.0
> /configuration/org.eclipse.equinox.p2.metadata.repository/re positories/file\
> :_C\:_Program\ Files_Eclipse\ 3.4_eclipse_.eclipseextension/version=1
> /configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\
> :__download.eclipse.org_technology_gmf_update-site_releases_ site.xml/name=ht
> tp\://download.eclipse.org/technology/gmf/update-site/releas es/site.xml
> @org.eclipse.ui.editors=3.4.0.v20080603-2000
> /configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\
> :__download.eclipse.org_tools_mylyn_update_e3.4/isSystem=fal se
> @org.eclipse.debug.ui=3.4.0.v20080529-1300
> :__download.eclipse.org_stp_updates_/isSystem=false
> @org.eclipse.core.net=1.1.0.I20080604
> :__download.eclipse.org_technology_gmf_update-site_releases_ site.xml/descrip
> tion=
> 3.4_eclipse_configuration_org.eclipse.osgi_bundles_66_data_l istener_19257299
> 51_/isSystem=true
> :__download.eclipse.org_technology_dltk_updates_/isSystem=fa lse
> 3.4_eclipse_/type=org.eclipse.equinox.p2.artifact.repository .simpleRepositor
> y
> :__www.polarion.org_projects_subversive_download_eclipse_2.0 _update-site_/na
> me= http\://www.polarion.org/projects/subversive/download/eclips e/2.0/update-
> site/
> /instance/org.eclipse.gmf.runtime.emf.core/referenced.path.v ariables=
> :__download.eclipse.org_technology_emft_updates_/enabled=fal se
> :__update.eclipse.org_updates_/enabled=true
> :__download.eclipse.org_tools_mylyn_update_extras/url=http\://download.eclip
> se.org/tools/mylyn/update/extras
> :__download.eclipse.org_webtools_updates/url=http\://download.eclipse.org/we
> btools/updates
> /instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.custom_ templates= <?xml
> version\="1.0" encoding\="UTF-8" standalone\="no"?><templates/>
> :__download.eclipse.org_technology_gmf_update-site_releases_ site.xml/version
> =1
> /instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .compliance=1.6
> :__download.eclipse.org_tools_buckminster_updates/isSystem=f alse
> 3.4_eclipse_p2_org.eclipse.equinox.p2.core_cache_/suffix=art ifacts.xml
> :__download.eclipse.org_releases_ganymede/name=Ganymede
> :__update.eclipse.org_updates_/url=http\://update.eclipse.org/updates/
> :__download.eclipse.org_modeling_emf_updates_releases_/enabl ed=true
> :__download.eclipse.org_datatools_updates/enabled=false
> :__download.eclipse.org_technology_emft_updates_/url=http\://download.eclips
> e.org/technology/emft/updates/
> @com.objf
Current Time: Sun Aug 31 15:57:05 EDT 2025
Powered by FUDForum. Page generated in 0.07170 seconds
