analyziing XSDSimpleTypeDefinitions [message #33391] |
Fri, 21 November 2003 16:56  |
Ed,
You may recall from your response to my previous posting concerning
serializing XSDSimpleTypeDefinition instances to XMI, you mentioned that
certain computed features were not marked as transient and being output to
the XMI file (for example, validFacets in XSDSimpleTypeDefinition). To get
around this problem I mark computed features, like validFacets, to be
transient when a new XSDSimpleTypeDefinition instance is created. This
allowed me to my save simple xsd datatypes to an XMI file. One problem I
noticed is when reading the XMI file the XSDSimpleTypeDefinition instances
that are created have an empty list for validFacets. This list gets
populated when an XSDTypeDefinition is analyzed but the deserialization of
the datatype was not enough to trigger it. My work-around for now is to
force re-analyzing whenever the setBaseTypeDefinition is called. Is there a
better way?
Dennis
Re: analyziing XSDSimpleTypeDefinitions [message #33446 is a reply to message #33391] |
Sat, 22 November 2003 06:43  |
Dennis,
It would be best if you could just call XSDSchema.update at the end since doing
type analysis is a global operation that involves looking at the whole schema
and that's not likely something you want to do as you're building a big model...
dfuglsang wrote:
> Ed,
> better way?
> Dennis
Re: analyziing XSDSimpleTypeDefinitions [message #580994 is a reply to message #33391] |
Dennis,
dfuglsang wrote:
> Ed,
> better way?
> Dennis
FUDForum. Page generated in 0.04007 seconds
