Home » Eclipse Projects » Eclipse Platform » toolbar contribution via IMenuService with custom source provider and expression
toolbar contribution via IMenuService with custom source provider and expression [message #329810] Sun, 06 July 2008 09:13 Go to next message
Hello!
I have a custom source provider for the variable activePerspectiveId, that
stores the id of the current active perspective (I use the one from
http://dev.eclipse.org/newslists/news.eclipse.platform/msg66 913.html).
Now I want to contribute an action to the main toolbar via the
IMenuService. This action should only be visible when one specific
perspective is active.
Here my snippet: http://pastey.net/90738
The problem is that when I switch the perspective, the action still is
visible in the toolbar. The expression doesn't seem to be correctly
evaluated again.
Am I missing something?
Kai
Re: toolbar contribution via IMenuService with custom source provider and expression [message #329849 is a reply to message #329810] Tue, 08 July 2008 11:13 Go to previous messageGo to next message
You need to override
org.eclipse.core.expressions.Expression.collectExpressionInf o(ExpressionInfo)
Mark the variables that you use (that's how things like the
IEvaluationService know to re-evaluate variables). Check out other
subclasses of Expression.
Also note, in 3.4 there is a variable provided for activePerspectiveId
(although with a longer name :-)
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: toolbar contribution via IMenuService with custom source provider and expres [message #329868 is a reply to message #329849] Tue, 08 July 2008 15:37 Go to previous messageGo to next message
Thanks for the help ... I'll try it.
Really, is there? And what is the name of it? It's not mentioned at
http://wiki.eclipse.org/Command_Core_Expressions (or is it?!).
> PW
Re: toolbar contribution via IMenuService with custom source provider and expres [message #329924 is a reply to message #329868] Thu, 10 July 2008 12:40 Go to previous message
That's a helper page ... org.eclipse.ui.ISources is the publishing API.
Paul Webster
Previous Topic:locations to download previous Eclipse SDK (3.2, 3.3,...)
Next Topic:Contributing Actions to an action set
Current Time: Sun Aug 31 15:56:23 EDT 2025
Powered by FUDForum. Page generated in 0.05705 seconds
