Home » Eclipse Projects » Eclipse Platform » Viewer is busy
Viewer is busy [message #329776] Thu, 03 July 2008 10:16 Go to next message
I want to add a new row in my viewer at the end.
So I have this code:
Table tbl = viewer.getTable();
insertIndex = tbl.getItemCount();
viewer.setItemCount(insertIndex+1);
viewer.replace(newRow, insertIndex);
The problem is that it fails in the replace():
!MESSAGE Ignored reentrant call while viewer is busy. This is only logged
once per viewer instance, but similar calls will still be ignored.
java.lang.RuntimeException
at org.eclipse.jface.viewers.ColumnViewer.checkBusy(ColumnViewe r.java:763)
org.eclipse.jface.viewers.AbstractTableViewer.replace(Abstra ctTableViewer.java:1040)
com.jobisjob.grid.crud.CrudContentProvider.updateElement(Cru dContentProvider.java:273)
org.eclipse.jface.viewers.AbstractTableViewer$1.handleEvent( AbstractTableViewer.java:78)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1027)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1012)
at org.eclipse.swt.widgets.Table.checkData(Table.java:928)
at org.eclipse.swt.widgets.Table.checkData(Table.java:917)
at org.eclipse.swt.widgets.TableItem.getImage(TableItem.java:55 0)
org.eclipse.jface.viewers.TableViewerRow.setImage(TableViewe rRow.java:132)
at org.eclipse.jface.viewers.ViewerCell.setImage(ViewerCell.jav a:170)
org.eclipse.jface.viewers.ColumnLabelProvider.update(ColumnL abelProvider.java:38)
at org.eclipse.jface.viewers.ViewerColumn.refresh(ViewerColumn. java:145)
org.eclipse.jface.viewers.AbstractTableViewer.doUpdateItem(A bstractTableViewer.java:386)
org.eclipse.jface.viewers.StructuredViewer$UpdateItemSafeRun nable.run(StructuredViewer.java:466)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:880)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:17 5)
org.eclipse.jface.viewers.StructuredViewer.refreshItem(Struc turedViewer.java:1476)
org.eclipse.jface.viewers.AbstractTableViewer.replace(Abstra ctTableViewer.java:1043)
I don't understand it.
Any help please?
Re: Viewer is busy [message #329777 is a reply to message #329776] Thu, 03 July 2008 10:17 Go to previous messageGo to next message
I forgot to mention that the table is virtual.
David Perez wrote:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Any help please?
Re: Viewer is busy [message #329782 is a reply to message #329777] Thu, 03 July 2008 11:41 Go to previous messageGo to next message
Calling viewer.add(newRow) doesn't show this problem. :-)
> David Perez wrote:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Any help please?
Re: Viewer is busy [message #329786 is a reply to message #329782] Thu, 03 July 2008 13:35 Go to previous messageGo to next message
The problem with this alternative is that the viewer isn't updated.
Any hint from viewer gurus please...
Re: Viewer is busy [message #329808 is a reply to message #329776] Sat, 05 July 2008 16:08 Go to previous messageGo to next message
Could you please file a bug for this, ideally with a snippet with which we
can reproduce the problem?
Boris
"David Perez" <craquerpro@yahoo.es> wrote in message
news:22a787081cd5d4a1c21ef40b28bd13bc$1@www.eclipse.org...
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Any help please?
Re: Viewer is busy [message #329819 is a reply to message #329808] Mon, 07 July 2008 06:00 Go to previous messageGo to next message
Thanks Boris for your interest, I think I have solved it.
I have rewritten my code, and I don't have this problem anymore. :-)
> Thanks
> Boris
Re: Viewer is busy [message #329889 is a reply to message #329819] Wed, 09 July 2008 10:37 Go to previous messageGo to next message
Originally posted by: automatic.javalobby.org
I have run into the same problem with the replace(element, index) method on AbstractTableViewer. Can you post your work around here?
Scott
Re: Viewer is busy [message #329934 is a reply to message #329889] Thu, 10 July 2008 15:40 Go to previous message
Please please post a bug report with a reproduceable test case!!!!!!
Tom
> Scott
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Previous Topic:Re: ShowInMenu
Next Topic:Pre-populating External Tools
Current Time: Tue Jul 22 21:31:01 EDT 2025
Powered by FUDForum. Page generated in 0.07882 seconds
