Home » Eclipse Projects » Eclipse Platform » Content types with 'multiple' extensions
Content types with 'multiple' extensions [message #329764] Thu, 03 July 2008 06:47 Go to next message
I originally posted this in the webtools group, but they suggested I try
here.
I'm using Ganymede, on Fedora Core 9, 64 bit.
I was just trying to edit a file using the XML editor, the file does not
end .xml or any of the other xml content types that are listed by default.
The dialog that came up told me to add the content type for this file, so
I did. I added "*.jnlp.in" under xml and I also added *.jnlp while I was
there.
I went back to the file, and tried again. It still wouldn't open, same
exact message comes up. If I rename the file to end with just .jnlp, it
works fine and opens up in the XML editor. If I add Test.jnlp.in (the full
name of the file) to the content types, tried again, and it opened right
up. I just cannot have a 'complex' file extension it seems.
So, I guess my question is: is there a way to get this to work?
Alternatively, is there any way to simply turn off content type checking?
I mean, does the XML editor really care what the extension of my file is
so long as it can be parsed as XML? I don't mind having to go to a file
and say "Open with XML editor" each time, if it will actually work.
Thanks a bunch,
Eugene
Re: Content types with 'multiple' extensions [message #329766 is a reply to message #329764] Thu, 03 July 2008 07:40 Go to previous messageGo to next message
Eugene,
My guess would be that the extension matcher just looks for the last "."
in the file name and for abc.jnlp.in would find ".in" which would match
only against "*.in".
Eugene Marcotte wrote:
> try here.
> not end .xml or any of the other xml content types that are listed by
> default. The dialog that came up told me to add the content type for
> this file, so I did. I added "*.jnlp.in" under xml and I also added
> *.jnlp while I was there.
> it works fine and opens up in the XML editor. If I add Test.jnlp.in
> (the full name of the file) to the content types, tried again, and it
> opened right up. I just cannot have a 'complex' file extension it seems.
> checking? I mean, does the XML editor really care what the extension
> of my file is so long as it can be parsed as XML? I don't mind having
> to go to a file and say "Open with XML editor" each time, if it will
> actually work.
> Thanks a bunch,
> Eugene
Re: Content types with 'multiple' extensions [message #329768 is a reply to message #329766] Thu, 03 July 2008 08:23 Go to previous messageGo to next message
That sounds pretty logical. Do you think this qualifies as a bug or is
that the desired approach?
Is there no way around it other than putting the full filename or the .in
extension, which i was hoping to avoid since there are several other .in
files that are not XML :)
Thanks for your quick reply!
Eugene
Ed Merks wrote:
> Eugene,
>> try here.
>> actually work.
>> Thanks a bunch,
>> Eugene
Re: Content types with 'multiple' extensions [message #329773 is a reply to message #329768] Thu, 03 July 2008 09:16 Go to previous messageGo to next message
Eugene,
I think it's more working as designed. I could have a file like a.b.c.d
so where exactly does the the file name end and the extension begin? I
think the typical/standard definition is that only the last segment
starting with "." is the extension.
> .in extension, which i was hoping to avoid since there are several
> other .in files that are not XML :)
> Eugene
> Ed Merks wrote:
>> Eugene,
>> "." in the file name and for abc.jnlp.in would find ".in" which would
>> match only against "*.in".
>>> Hi,
>>> try here.
>>> by default. The dialog that came up told me to add the content type
>>> for this file, so I did. I added "*.jnlp.in" under xml and I also
>>> added *.jnlp while I was there.
>>> same exact message comes up. If I rename the file to end with just
>>> .jnlp, it works fine and opens up in the XML editor. If I add
>>> Test.jnlp.in (the full name of the file) to the content types, tried
>>> again, and it opened right up. I just cannot have a 'complex' file
>>> extension it seems.
>>> having to go to a file and say "Open with XML editor" each time, if
>>> Thanks a bunch,
>>> Eugene
Re: Content types with 'multiple' extensions [message #329789 is a reply to message #329773] Thu, 03 July 2008 17:53 Go to previous messageGo to next message
Makes sense.
Out of curiosity, since it is limited to extensions or whole filenames,
then what is the point of supporting a "wildcard"? Could you just have a
checkbox for each content type to say "extension" vs "full name."
I don't want to sound too cynical but letting me type wildcards makes me
want to actually have it match the wild cards :)
Oh well, I'll just add *.in and live with it for now :)
See ya and thanks for listening!
Eugene
Ed Merks wrote:
> Eugene,
>> Eugene
>> Ed Merks wrote:
>>> Eugene,
>>>> Hi,
>>>> try here.
>>>> extension it seems.
>>>> Thanks a bunch,
>>>> Eugene
Re: Content types with 'multiple' extensions [message #329794 is a reply to message #329789] Fri, 04 July 2008 07:55 Go to previous message
Eugene,
Comments below.
> Makes sense.
> filenames, then what is the point of supporting a "wildcard"? Could
> you just have a checkbox for each content type to say "extension" vs
> "full name."
Yes, I always found having to specify the * a little odd but I guess the
"*." is a reasonable syntactic way to distinguish it from a full file name.
> me want to actually have it match the wild cards :)
Seems a reasonable expectation, but keep in mind that this would in
practice require pattern matching against each pattern-based content
type rather than a table look up based on extension only or file name only.
The path of least resistance. :-P
> Eugene
> Ed Merks wrote:
>> Eugene,
>> a.b.c.d so where exactly does the the file name end and the extension
>> begin? I think the typical/standard definition is that only the last
>> segment starting with "." is the extension.
>>> is that the desired approach?
>>> the .in extension, which i was hoping to avoid since there are
>>> several other .in files that are not XML :)
>>> Eugene
>>> Ed Merks wrote:
>>>> Eugene,
>>>> last "." in the file name and for abc.jnlp.in would find ".in"
>>>> which would match only against "*.in".
>>>>> Hi,
>>>>> I try here.
>>>>> does not end .xml or any of the other xml content types that are
>>>>> listed by default. The dialog that came up told me to add the
>>>>> content type for this file, so I did. I added "*.jnlp.in" under
>>>>> xml and I also added *.jnlp while I was there.
>>>>> tried again, and it opened right up. I just cannot have a
>>>>> extension of my file is so long as it can be parsed as XML? I
>>>>> don't mind having to go to a file and say "Open with XML editor"
>>>>> Thanks a bunch,
>>>>> Eugene
Previous Topic:Re: Can't add extras p2 update site
Next Topic:Why doesn't the Eclipse console stream?
Current Time: Mon Jul 21 23:56:29 EDT 2025
Powered by FUDForum. Page generated in 0.08603 seconds
