Home » Eclipse Projects » Eclipse Platform » Why I can't run Eclipse3.4 on Fedora9?
Why I can't run Eclipse3.4 on Fedora9? [message #329740] Wed, 02 July 2008 09:51 Go to next message
Hi all:
Today I download eclipse3.4 and I want to run it on Fedora9.It goes well
during the starting , but after I select a path for workspace ,the eclipse
doesn't display the workbench instead of a blank window(please see the
pictures)
I don't know why,so I run the eclipse3.3,it can go.
I think maybe the java version isn't suit for eclipse3.4.I uninstall the jdk
6 and install jdk1.5 (I type the "java -version" command in terminal ,it
shows that the current java version is 1.5.0_15), but I get the same result
: eclipse3.4 can't display workbench but a blank window.I want to view the
log file to know what's happen during eclipse3.4 starting,but I can't find
the ".metadata" directory in workspace,it means that eclipse3.4 doesn't
create that directory .
I upload some pictures , they can show what's happen.
Who can help me?
Thanks!
Re: Why I can't run Eclipse3.4 on Fedora9? [message #329750 is a reply to message #329740] Wed, 02 July 2008 10:54 Go to previous messageGo to next message
It sounds like https://bugs.eclipse.org/bugs/show_bug.cgi?id=239209
Can you get any further if you start eclipse with:
eclipse -data tmp_ws
That should create the tmp_ws where you can find the .metadata/.log file
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: Why I can't run Eclipse3.4 on Fedora9? [message #329754 is a reply to message #329740] Wed, 02 July 2008 15:25 Go to previous messageGo to next message
I suppose that you have a problem with Firefox 3.
You can try the following:
- remove Firefox 3 or install a newer version
- add the VM argument -Dorg.eclipse.swt.browser.XULRunnerPath=/dev/null
when starting eclipse
You can also take a look at this comment:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=235020#c2
Snjeza
Dart peng wrote:
> Hi all:
> pictures)
> Who can help me?
> Thanks!
Re: Why I can't run Eclipse3.4 on Fedora9? [message #329760 is a reply to message #329754] Wed, 02 July 2008 22:10 Go to previous message
Originally posted by: eclipseglory.hotmail.com
Thank you , I will try it
> Snjeza
> Dart peng wrote:
>> Hi all:
>> well during the starting , but after I select a path for workspace
>> ,the eclipse doesn't display the workbench instead of a blank
>> window(please see the pictures)
>> the jdk 6 and install jdk1.5 (I type the "java -version" command in
>> terminal ,it shows that the current java version is 1.5.0_15), but I
>> get the same result : eclipse3.4 can't display workbench but a blank
>> window.I want to view the log file to know what's happen during
>> eclipse3.4 starting,but I can't find the ".metadata" directory in
>> workspace,it means that eclipse3.4 doesn't create that directory .
>> Who can help me?
>> Thanks!
Previous Topic:PDE Build, test fragments, and build cycles
Next Topic:3.4 (Mac) very slow to show right-click (context) menu
Current Time: Mon Jul 21 22:19:42 EDT 2025
Powered by FUDForum. Page generated in 0.08588 seconds
