Code that was compiling in 3.3.2 doesn't compile in 3.4 [message #329636] |
Mon, 30 June 2008 14:16  |
I'm working with a target platform of about 700 plug-ins.
When I create a new plug-in in Eclipse 3.3.2 that depends on some of those
plug-ins every thing works fine.
In Eclipse 3.4, on the other hand, I'm getting a lot of duplicate JARs
under the plug-ins dependencies library. That, of course, causes the code
not to compile with the following error (this is one example):
Cannot nest 'C:Program
Files/IBM/Director/lwi/runtime/USMiMain/eclipse/plugins/com. tivoli.twg.libs_1.0.0/classes'
inside library 'C:Program
Files/IBM/Director/lwi/runtime/USMiMain/eclipse/plugins/com. tivoli.twg.libs_1.0.0'
Re: Code that was compiling in 3.3.2 doesn't compile in 3.4 [message #329708 is a reply to message #329664] |
Tue, 01 July 2008 11:34   |
"Alon" <allonr@il.ibm.com> wrote in message
news:ded317995142bc5a40d15b468147623e$1@www.eclipse.org...
> It's happening for me on all the plug-ins in my workspace (7).
> I searched a lot in Bugzilla without success. I thought of opening a
> defect on this because I can't work with 3.4 at all :(
"Happening for you on all your plugins" is, sadly, not the same as
"reproducible in a way that others can work on". For a bug report to be
useful, it is not enough to report the problem, you need to find steps that
can let someone else reproduce it. This may be easy, or it may be hard -
ironically, most of the "it doesn't work at all" cases are hard to
reproduce, because obviously for the vast majority of users it *does* work.
If you can start with a fresh workspace and try to figure out the minimal
steps that need to be done to make it show the problem you're experiencing,
that will help. Without that there's not much anyone can do other than be
sympathetic.
Or, hopefully Chris' response will be all you need.
FUDForum. Page generated in 0.08216 seconds
