Home » Eclipse Projects » Eclipse Platform » Ganymede keymap in pdf format
Ganymede keymap in pdf format [message #329620] Mon, 30 June 2008 08:00
Originally posted by: enzhao.gmail.com
Eclipse exports the keymap in csv format. Which is not the best format for
printing. I made a Ganymede keymap in pdf format. Can be downloaded from
my blog entry:
http://ningning.org/blog2/2008/06/29/eclipse-ganymede-pdf-ke ymap
For those who are interested, the blog also documents about how I made it
using latex and Groovy, with example code snippets. If you don't like the
layout, you can easily change it in the latex template in my blog, and run
whatever tex program you have to produce a new pdf/ps file.
Hope you like the keymap! :-)
Best Regards,
Ellen N. Zhao
Previous Topic:problems adding my own tests
Next Topic:Applying conditions to code templates (code generation)
Current Time: Fri Jul 18 01:51:41 EDT 2025
Powered by FUDForum. Page generated in 0.06866 seconds
