Home » Eclipse Projects » Eclipse Platform » Project.create out side workspace
Project.create out side workspace [message #329553] Fri, 27 June 2008 14:14 Go to next message
Originally posted by: sursubra.cisco.com
If i create project inside workspace the resource plugin create a project
folder with the project name i gave then the contents are created inside my
project folder. If i create project outside the workspace and it is not
creating the project folder inside the non workspace location i gave.I tried
JDT, Plugin Project all of them have the same behaviour. I beleive the
resource plugin should create project folder in the non-workspace location
also. Is this intented behaviour?. I am not quite getting why they created
differently.
Suresh Subramanian
Re: Project.create out side workspace [message #329558 is a reply to message #329553] Fri, 27 June 2008 14:29 Go to previous message
You can create a project in the workspace while pointing it to a
location in the file system outside the workspace dir. See
org.eclipse.core.resources.IProject.create(IProjectDescripti on,
IProgressMonitor) and IProjectDescription
Or are you trying to create a project that points to an existing source
tree?
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Previous Topic:Folding a list
Next Topic:build.bat on the srcInlcuded.zip using
Current Time: Thu Jul 17 19:33:07 EDT 2025
Powered by FUDForum. Page generated in 0.47915 seconds
