Home » Eclipse Projects » Eclipse Platform » How to override the "run" command
How to override the "run" command [message #329546] Fri, 27 June 2008 10:55 Go to next message
Originally posted by: cguibert.axway.com
Hello
I would like to override the default behavior of the "run" command in
Eclipse.
I would like to add some checks (specific to my plugin) before the normal
behavior of the run command.
Does anyone know how I could achive that ?
I think I should implement an IActionDelegate class in my plugin. Is it
correct ? How should I proceed ?
Thanks for your help
CG
Re: How to override the "run" command [message #330004 is a reply to message #329546] Fri, 11 July 2008 21:14 Go to previous message
CG wrote:
> Hello
> Eclipse.
> normal behavior of the run command.
> Regards
> CG
I'm not sure you'll be able to easily override or extend the run. But it
would be fairly straightforward to add a builder.
Alex
Previous Topic:Missing required bundle is active!
Next Topic:Update of JFace TreeViewer fails
Current Time: Sat Jul 12 11:35:59 EDT 2025
Powered by FUDForum. Page generated in 0.02981 seconds
