Home » Eclipse Projects » Eclipse Platform » Code completion broken in Eclipse SDK?
Code completion broken in Eclipse SDK? [message #329535] Fri, 27 June 2008 07:48 Go to next message
For some reason, in the last couple RC builds and the 3.4 GA build of
the Eclipse SDK, I can't get code completion to work. It always says
there were no suggestions. What would cause this to break? This is on
Windows XP.
David
Re: Code completion broken in Eclipse SDK? [message #329548 is a reply to message #329535] Fri, 27 June 2008 12:31 Go to previous messageGo to next message
> Windows XP.
> David
Here's an example... if I have the following method:
public void foo(String string) {
System.out.println(string);
And I start a new line after the first line and type "string." and press
Ctrl+space, it offers none of the methods from the String class.
I have tried running Eclipse both with the IBM 1.5 JRE and a 1.6 JRE,
but neither seems to cause the code completion to work. Has anyone seen
this before?
David
Re: Code completion broken in Eclipse SDK? [message #329563 is a reply to message #329548] Fri, 27 June 2008 20:06 Go to previous messageGo to next message
This is a knonw issue in some cases, reset your code completion options
to the default and that will fix it.
>> on Windows XP.
>> Thanks,
>> David
> this before?
> David
Re: Code completion broken in Eclipse SDK? [message #329571 is a reply to message #329563] Sat, 28 June 2008 06:36 Go to previous messageGo to next message
Thanks, Francis. This is a result of me reusing a workspace from an
earlier build. Something happened in that earlier build and Eclipse
reset my code completion options (the ones on the Advanced tab). I just
clicked Restore Defaults and everything is working now.
Thanks again,
David
Re: Code completion broken in Eclipse SDK? [message #329683 is a reply to message #329571] Tue, 01 July 2008 06:10 Go to previous message
>> options to the default and that will fix it.
> reset my code
Not really. The problem is that previously you had Mylyn installed which
modified the settings and now Mylyn is probably no longer installed.
Dani
> completion options (the ones on the Advanced tab). I just clicked
> Thanks again,
> David
Previous Topic:Mouse controls not working with Ganymede
Next Topic:OpenEditor on an input object (instead of a file)
Current Time: Sat Aug 30 23:29:21 EDT 2025
Powered by FUDForum. Page generated in 0.03905 seconds
