[Eclipse 3.4] Using multiple configurations with a shared installation [message #329532] |
Fri, 27 June 2008 06:43  |
Up to Eclipse 3.4 I've been using to start Eclipse the following way:
eclipse -configuration <cfg_path> -data <wsp_path>
I'm using number of configuration areas setup with different
extension location sets. I eventually run:
eclipse -initialize
of the main shared configuration to improve startup time (as
suggested in the documentation [1]) but I haven't really seen much
improvement, if at all.
Now with the Eclipse 3.4 release I observe I can no longer use this
approach. If I specify a -configuration different from the shared
one I get a workbench with some minimal set of features ("Resource",
"Team Synchronizing" and "Debug" - no "Java").
FWIW, I've noticed an additional "p2" directory gets created in the
same parent directory of the configuration directory location I've
specified.
Is it possible (and how) to use multiple configurations with a
shared installation of Eclipse 3.4?
[1]
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.user/tasks/running_eclipse.htm
Stanimir
FUDForum. Page generated in 0.10930 seconds
